Question about Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher
How to take apart Kenmore 665 - Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher
665.13049k110 kenmore dishwasher won't drain.
Check that the drain pipe exit point is higher than the water inlet and drain connection on the machine, thats a comin problem, also check and clean the drain pump situated at the front of the machine at the botom underneath the cover
Oct 03, 2017 | Kenmore Dishwashers
Why does my kenmore 665 dishwasher start pumping hot water even though its not turned on?
You might have a bad water valve, or a bad timer (especially if this dishwasher uses a mechanical timer - one that has a rotary dial in front).
Feb 24, 2015 | Kenmore 665
Kenmore 665 dishwasher problems
Check the door latch and switches.
Aug 22, 2014 | Kenmore Dishwashers
Kenmore2007 665-575-320 won't start,clean indicator stays on
Kenmore 665-1374 Dishwasher, suddenly front touch pad not working, at first would allow pot & pans, now no settings, with exceptions of drying settings
Jun 28, 2010 | Kenmore Dishwashers
My Kenmore 665 will not drain!
Here is a tip that I wrote that will help you with your problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
May 31, 2010 | Dishwashers
Kenmore portable dishwasher won't drain model # 665 17799990
Service person said is is not supposed to drain all the way. Something about it helps something not dry out.
Jun 24, 2009 | Kenmore Dishwashers
My kenmore ultra wash model #665 does not pump out water.
my model #665 dishwasher will not pump water into the unit
Apr 25, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Dishwasher pump not working
if you go here http://www.searspartsdirect.com/partsdirect/index.action and enter your model number without any spaces you can get a parts list on that page you will see show diagram it will give you a blueprint of the pump moter assembly
Jan 30, 2008 | Dishwashers
Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher Logo
16 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
