Question about Whirlpool Calypso GVW9959K Top Load Washer
Error code ( FE ) on my samsung washing machine model wd8602r8u
4 Suggested Answers
  • 234 Answers
SOURCE: FE error is displayed in my whirlpool washing machine what to do?
How do you know this is a generic problem for all whirpool washers?
What I can tell you is: ever since electronic controls were placed with appliances (dishwhrs, dryrs, wshrs, frigs,etc) there was this new age of error and fault codes that would lock-up the electronics. I always recommend people buy the mechanical control appliances because you do not have these interim problems. Mechanics justs keep ungoing, and if it will fail some day, you usually have a warning period, and it is more likely to be cheaper to repair than electronic controls.
Aside from all that, your owners manual should have a section in the rear that says trouble shooting; this usually has some of the standard error/fault codes and it can tell you what it stands for. Most errors can be eliminated by unplugging this electric cord and waiting 1 minute for the ciruit board to reset itself. The usual causes are: out of balance load that shook the machine too much, an overfill of water level, and overload of too much heavy close that caused the machine to strain the engine, or a short temporary power interuption while the machine was operating. Try the plug rest method and pay better attention to the load/overload. Hope all will be good. Macgivor
Posted on Oct 04, 2009
blueextc3221
  • 15935 Answers
SOURCE: error code ( IE ) on my samsung washing machine model wa13g7q1
1E - WATER PRESSURE SWITCH ERROR
* Generated Frequency Signal of WATER LEVEL (WIL) SIW (KHz)
Normal Level = Abnormal W/L Frequency
Low Level = 30.00 Khz
High Level = 15.00 Khz
If the same signal is detected for more than 5 seconds, it is a PRESSURE SWITCH Error. When this error occurs the drain pump will operate for 3 min. and the display will show 1 E indicating a pressure switch error.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 21, 2010
blueextc3221
  • 15935 Answers
SOURCE: whirlpool washing machine model wfw9500tw01
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Error E1 for washing machine
Lots of info on E1 for different makes.
  • How to repair a Samsung washing machine with error code E1 ... https://www.quora.com/How-do-I-repair-a-Samsung-washing-machine... How do I repair a Samsung washing machine with error ... If your Samsung Washing Machine is showing error code E1 then ... How do I clear bosch washing machine error ...
  • E1 error in washing machine? ' Yahoo Answers https://in.answers.yahoo.com/question/index?qid=20131129013237AA7oiKP
    • RESOLVED
    • 7 POSTS
    • 6 TOTAL ANSWERS
    2013-11-29 · E1 error in washing machine? ... Haier washing machine error code E1? LG Wave Series Washer LE error message? Washing machine error code? ...
  • My washing machine is displaying an error code. What does ... www.samsung.com/my/support/skp/faq/1033803 My washing machine is displaying an error ... E1. Water supply error. ... · Check that the level of the drain hose is not lower than the base of the washing machine.
  • Related searches for Error E1 for washing machine
  • Samsung Washing Machine 4E and E1 Fault - Help & Advice https://www.northlondonappliancerepairs.co.uk/error-codes/samsung...
    • 4.3/5
    • 46 RATINGS
    Samsung Washing Machine 4E and E1 Fault. Samsung washing machine Not filling in allocated time error code 4E and E1 Fault.
  • Help & Troubleshootings - Haier ZA Products Website www.haier.com/za/help_and_troubleshootings/faq/washing_machine Help & Troubleshootings. ... Too much water in the washing machine ... Error Code-control panel display "E1" Question : Error Code-control panel display "Lock"
  • Samsung washing machine error code 4E and E1 Fault Not ... www.youtube.com/watch?v=cFlnxeB0P0g
    • BY HOW-2-REPAIR.COM
    • 9 MIN
    • 19K VIEWS
    2015-11-24 · Video embedded · ... machine-error-code-4e-and-e1-fault-not-filling-in-allocated-time/ Samsung washing ... Samsung washing machine error code 4E and E1 ...
  • Samsung washing machine error code 4E, E1, Fault Not filling www.how-to-repair.com/help/samsung-washing-machine-error-code-4e... Samsung washing machine Not filling in allocated time error code 4E and E1 Fault This is essentially a fill timeout error which will normally mean that either the ...
  • Hoover error code E1 - White Goods Help www.whitegoodshelp.co.uk > ... > Washing Machine Error Codes Hoover error code E1. ... You need to watch the washing machine to see when it aborts to get an idea which of the three areas to look at.
  • Jul 01, 2016 | Washing Machines
    I get an FE code on my samsung WD0704RQQ short time after setting the machine on dryer mode. Please help as my manual doesnt have the code and its meaning.
    http://appliancejunk.com/forums/index.php?topic=17042.0
    I SUGGST REMOVING POPWER, SHUT OFF BREAKER, THEN RESET, IF IT DOESNT HELP IT WOULD NEED SERVICE
    Apr 14, 2016 | Samsung Washing Machines
    What does the E3 code mean on the 540 model and is there a fix?
    Troubleshooting the "E3" error code in Maytag MAH6700 ...
    fixitnow.com/.../troubleshooting-the-e3-error-code-in-maytag-mah6700-...
    Feb 20, 2011 - These codes in your (made-by-Samsung) Maytag washer might pop up during the ... In fact, the E3 error code means that the Machine Control wants to make the motor spin but won't do it because it's getting a weird reading from the tachometer.... MAH6700 and MAH8700 models (they use the same motor).
    I have a samsung frontload washing machine. A code E3 is ...
    www.shopyourway.com > Denise LaGrasse > Questions
    Mar 15, 2014 - My samsung front loader is not working. do not no what E3 means. ...code F26 mean on a Kenmore Elite model 110.4708 washing machine?
    How To Fix 3E Error Code On A Samsung Washing Machine
    www.appliancerepairlesson.com/.../how-to-fix-3e-error-code-on-a-samsu...
    May 15, 2015 - Samsung uses the 3E error code to indicate a drive motor tach fault. ...If you're handy, you can fix your Samsung front load washing machine error code ....My samsung frontload washer shows e3 and the drum does not turn ...
    Jan 06, 2016 | Washing Machines
    Based on my experience, the same thing happens to me as you have mentioned that it happens every end of a cycle. I doubt if it was a fan error or a frequency error. for me, its just a simple overload for the autodrying. for example on my model. the manual says autodrying cotton-cupboard dry must be max 3 kg. since you cannot measure your wet clothes and it sometimes exceed the 3kg autodrying, that is when the FE comes out. but when i remove some clothes or spin the laundry again and put it into drying, everything works fine. when i use the machine with minimal clothes say 2kg dry, the whole cycle up to drying work fine without FE errors.
    So i believe its just an error for drying overload. also the manual says nothing about FE nor Error code for drying overload.
    Hope this help.
    May 31, 2012 | Washing Machines
    What cause FE error on a samsung dryer
    We did some extensive research and somehow found a service manual for our Samsung unit online. According to its section 4-1 "Error Items and Diagnostic Codes" the following is the problem:
    (code) FE - (description) Power source frequency error - (Trigger) Invalid power source frequency - (Action taken) Check for: (a) Not using regular power source frequency (b) Invalid power frequency sense circuit.
    In other words, either the thing you have plugged your machine into is faulty, the electricity itself is of poor quality where you live, or the sensor within the unit is faulty and giving an erroneous error code.
    In our case, we had our machine hooked up to a cheap surge protector; which we thought might be the likely source of our problem in the light of the error code description above. So I tried connecting it to a commercial extension cord (I still got an FE code). So I tried moving the extension cord to another room's circuit, thinking maybe it was localized in the laundry room (I still got an FE code).
    So, I am guessing we either have a bad "power frequency sensor" or the problem is due to the terrible electricity we have where we live (i.e. that the power frequency fluctuates too much due to our local power company's poor system).
    Regardless, I hope this answer helps somebody with the "FE code" problem, now that you know what the code means.
    Oct 26, 2009 | Samsung WF203ANW Front Load Washer
    I have an error code "FE" apperaing in my samsung washer dryer, it appears in the spin cycle and is not in the manual. waht causes this error
    We did some extensive research and somehow found a service manual for our unit online. According to its section 4-1 "Error Items and Diagnostic Codes" the following is the problem:
    Oct 05, 2009 | Samsung WF203ANW Front Load Washer
    Samsung WD-J1255 Front loader Washer/dryer combo
    I have a similar problem with the FE Code. All i have manage to ascertain is that if you set the spin at 400 it will complete the cycle
    Nov 01, 2008 | Washing Machines
    Whirlpool Calypso GVW9959K Top Load Washer Logo
    37 people viewed this question
    Dan Webster
    Dan Webster
    Sal DeAngelo
