Question about Gold N Hot 'N Hot GH9271 Professional Portable 1200 Watt Hard Bonnet Dryer
Closing the dryer once done with use
I can't figure out how to close the dryer. It doesn't want to fold from the hinge connecting the hood.
  • 1,340 Answers
Might be a spring has popped off or a bushing issue. search for you local electric motor repair shop, these guys are for the most part are firing on all 8 cylinders and are glad to help a damsel in distress.
Jay the pool pump motor repair guy in longwood Florida 32750
Posted on Feb 08, 2014
Remove a hood from a 2006 nissan altima
absolutely not. first thing, carefully remove the washer hoses. there are four bolts on the hinges. just remove front two completely then slowly remove rear two while someone else holds the other side of hood. the hood itself is relatively light.when reinstalling, keep the hood bolts slightly loose and bring down the hood slowly, not letting it close. when you can position the hood straight, tighten a bolt on either side then close the hood. if it closes and opens while being evenly gapped on both sides tighten all four bolts. then replace the washer hose and done.
Nov 13, 2013 | Nissan Altima Cars & Trucks
Switch_bypass to dryer door
You will have to take apart the dryer. First UNPLUG IT from the wall. Then pry up the top, gently - it is pressed on with plastic push screws. The top should fold all the way backwards, have something to support it so it doesn't break off. You should be able to see the switch now close to the top, inside the dryer. Unplug both wires then connect them. You can either electrical tape them together or hard wire them. Be sure the wires do not dangle too low as to touch anything. Tape up all connections on the wires. Replace the top, plug in and it should work.
Oct 21, 2011 | Kenmore 62602 Electric Dryer
I have a sears kenmore elite refrigerator. It is a side by side. The doors don't line up when closed. The freezer side is about 1/4" higher. It looks funny when closed.
there are plastic spacers located at the hinge on the bottom of these units, and they break after wear and tear , they are also beveled so they help the door close,, check to see if yours are in good order, if not you'll have to replace them,, to do this you remove the top hinge,, its just a couple of screws that hold the hinge on under the plastic deco cap ,, once you've done that Lift the door off the lower hinge,, install the spacers, and place the top hinge back once the door is reset
Aug 25, 2011 | Kenmore Side by Side Refrigerator
The hinge part of the toilet seat installed alright---but once the seat was connected to the tank, i tried to open the lid and it just fell off---the quiet close "dowels" for lack of a better...
Hi, Please don't take this the wrong way but did you install the hinges the right way? I fit bathroom suites for a living and have done this a few times wrong by putting the left hinge on the right side and vice verser. Sometimes the instructions are not very clear in explaining which side is left on the seat, as a result even though the toilet seat is closed, the springs are set backwards and are in fact in the up position. Double check the instructions once more, and just have a look on the hinges and seat because sometimes they have a small 'L' sticker on the hinge and an 'L' sticker on the seat and lid to correspond which hinge goes on which side. Hope this is of help to you.
Jan 11, 2011 | Kohler Toilet Seat - Elongated Front Quiet...
How do I get the top cover off the freezer door and switch it to open the opposite way?
Duct tape the door closed.
Keep all washers and plastic grommets. make screw holes in opposite side accessible IE remove plastic grommets.
Remove the lower hinge remove the upper hinge.Install lower hinge just as it came off and then do the upper hinge. tighten down the hinges then see if the door needs adjusting by opening it and closing it and watching for the door gasket to keep folded properly.
Insert the plastic grommet covers in the original holes and you should be done.
Sep 22, 2009 | Refrigerators
52 saccaner error
52 Scanner Error Perform the following to troubleshoot a 52 scanner error:
  1. Verify that the toner door is completely closed. If the door is not closed, the printer will not allow the laser shutter to operate and will present the error “52 Scanner Error” or “Door open or no print cartridge”.
  2. Verify that the black connecting link to the toner door hinge is properly attached. If the latch is not properly attached (Figure 1), snap the hinge in place, close the toner door, and power-cycle the unit. Figure 5: Black toner door latch c00162195.jpg
  3. Verify that the inner toner door is properly positioned. Snap the door back into place at the two inner door-locking mechanisms (Figure 2). Figure 6: Inner door locking mechanisms c00162197.jpg
  4. Verify that the door hinge and upper ring are not broken. If either are broken, the unit will need to be returned to HP or a local service provider for service using the applicable warranty, support pack, or contract option. Figure 7: Door hinge and upper ring c00162200.jpg
May 28, 2009 | HP LaserJet 3055 All-In-One Printer
I have a Whirlpool Oven #SF395LEE* (RB26126336) accubake Systems. Today the oven door came off and I need to know how to put it back on. I do not see this over on your list. Can you help? Thank...
ok wht you have to do is grab the hinge with pliers or your hand and fold the hinge to the open position,carefull this hinge has some pressure to it and you dont want to pinch your skin ,once the hinge is open,you want to take a screw or strong nail and stick it thru the hole that is between the top of the hinge and bottom in the center put the nail thru the hole and let the hinge close slow i,it will hold the hinge 3/4 open,now hook the door on it will be 3/4 open once you feel it latch on the door open the door all the way pull the nails out and close the door ,it takes a little practice but youll get it remember to use the nail to hold the hinge open,youll see the hole on the hinge
Jul 13, 2008 | Whirlpool RBS245PDS Electric Single Oven
I lifted it by its door and its came off, not broke though
Jul 09, 2008 | Gaggenau EB388 Electric Single Oven
Dryer door won't close
You probably bent the hinges if you can't see an actual crease in the door. Just pull the screws out of the hinge where it meets the door, and using a large pair of channel locks manipulate the hinge back to it's proper alignment, stopping to put door back on every once in a while to check it. Simple as that. You may have to flip unit over on it's back if the mounting screws for the hinges are not accessible.
Jan 28, 2008 | Whirlpool LEQ9858P Electric Dryer
Kenmore dryer door
Yes u need a phillips head screw driver take the door hinge off and the whole door comes off there are i think six small screws around the plastic take only those off then the plastic will seperate from the metal frame then all you do is switch door hinge sides and reverse the removal no beware once switched u have a very good chance that the door will not close the same or as well as before u have to play with the adjustment of the hinge the best u can after that u can grab the door close to the hinge and very gently but firmly pull up on the door to adjust it but do beware that the hinge can and will break under to much pressure
Feb 23, 2007 | Kenmore 94832 / 94834 / 94836 Gas Dryer
Gold N Hot 'N Hot GH9271 Professional Portable 1200 Watt Hard Bonnet Dryer Logo
309 people viewed this question
Top Gold N Hot Health & Beauty Experts
Robin Hill
Robin Hill
Jeff Tilburn
Jeff Tilburn
Are you a Gold N Hot Health and Beauty Expert? Answer questions, earn points and help others
