Question about GE Profile GCG1580LSS 15" Built-In Trash Compactor with 1.4 cu. ft. Capacity, Hidden Controls & Remo...
Door is about 1 inch adjar and can't get it open. compactor will not run
It is just stuck and will not open.
3 Suggested Answers
SOURCE: GE Profile trash compactor is stuck
This has happened a couple times to me and the fix is fairly simple. The problem is the trash ram is pushing down on the edge of the metal of the trash compartment because the door is partially open. The solution is to back-up the ram the the door will close.
To back-up the ram, you will need to pull the compactor out from under your cabinets and unplug it. Turn the compactor on it's side to expose the bottom. There is a plate on the bottom that covers the motor gears. Remove the plate and turn the large gear counter-clockwise to back-up the ram screws (at least this is how it works on my model works). The gears are a little greasy so you may need to add some after messing with the gears.
Good luck.
Posted on Dec 25, 2008
SOURCE: Compactor ram stuck partially down & door open
We just had this same problem. Your problem is most likely abroken plastic gear found at underneeath the bottom of the compactor. Pull out the compactor and turn it upside down. Remove the bottom panel and that is where we found the broken gear. We were able to retract the ram and open the drawer by manually turning the drive chain using an ajustable wrench. Clockwise is compact, counter clockwise is retract.
Posted on Feb 21, 2010
Ge compactor stops after just starting
the running cycle for this type of trash compactor is a max of about 30secs. The fuller the bag is the shorter the cycle. However, if this is not how yours is running try checking to see if there is any trash stuck between the ram and the basket. Or make sure that the foot peddle is still staying in the "up" position.
Feb 27, 2012 | GE Stainless Steel Built In Trash...
I've got a GE trash compactor (GCG1580PSS). The door is stuck, presumably because the ram is stuck in the down position. If power is turned on, it will run until it shuts down (faint smell of...
Look up and down, may have an installation apparatus hooked into the counter top and the floor. Go to manualsonline.com to download owner's manual which should have installation information in it. Hope that helps..
Jul 19, 2011 | GE Profile GCG1580LSS 15" Built-In Trash...
I have a 1998 ford mustang convertible and the dinger that starts when you put the key in the ignition wont stop dinging. Please Help!!!!!!!!! Yesterday my driver side window wouldnt roll up so my...
It's likely one of the door switches is damaged causing the door open signal. It can also be caused by the key in the ignition, so don't rule out a faulty key insertion switch.
Have your husband or a mechanic test these parts for accurate functionality.
May 20, 2011 | 1998 Ford Mustang
Compactor ram stuck partially down & door open 2 inches. How do I get the ram to go back up & get the door closed?
Feb 03, 2010 | GE Profile GCG1580LSS 15" Built-In Trash...
1999 cougar door adjar lights
if u can not see the door ajar switches then thay are located in the latch assembleys of each door. if this is the case then buy a can of PB BLASTER at your local auto parts store and spray each latch assembley really good and close and open each door 10 to 15 times this will usually free up the stuck switch
Mar 23, 2009 | 1999 Mercury Cougar
Message says "door ajar" but no door open
Check the DOOR BUTTONS in the Jams One is giving the signal for Dome Light and usualy you can Just Roghly Push and reliece them and they get the right connection
Feb 11, 2009 | 2001 Mercury Mountaineer
Good luck.
Oct 21, 2008 | GE Profile GCG1580LSS 15" Built-In Trash...
Have a Viking trash compactor VUC181 that will not open. Appears latch is broke. How can I get it open?
I have had this same problem and found two causes. Latch was never the problem.
#1 - Ram not in full up position. To check remove top plate and attempt to run compactor - depressing microswitch when ram is at the top. If compactor will not run you can check the ram position by turning the primary screw drive with a ratchet wrench. When ram is at the top position attempt to open the compactor drawer. The stop microswitch seems to frequently bend out of alignment - check the microswitch positioning before resecuring top plate and adjust if necessary.
#2 - Can (or other debris) is wedged in between ram and drawer. Remove back cover and carefully inspect insides of the unit - use a flashlight. Pry out any debris that may impede the drawer from opening. Attempt to open the compactor drawer.
Good luck,
Jon B.
jbroccoli@aol.com
Oct 10, 2008 | Viking 24 in. Professional Series VUD141...
Stuck Trash Compactor
I can't get to the rear of the compactor. How do I get the front off to get to the rest of it?
Mar 14, 2008 | Dishwashers
GE Profile GCG1580LSS 15" Built-In Trash Compactor with 1.4 cu. ft. Capacity, Hidden Controls & Remo... Logo
81 people viewed this question
Top GE Kitchen Appliances - Others Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Sal De
Are you a GE Kitchen Appliances - Other Expert? Answer questions, earn points and help others
