Question about Cuisinart CWC-1200 Wine Cooler
I'm looking for the resistor values for R37 and R38 on the Cuisineart circuit board HS-PS12V70W-11.
I've replaced the fuse, the two big caps, and an open diode. The fuses, however are burned, so I can't get the color codes.
    New Friend:
  • 14 Answers
R37 10 ohm 1/2 Watt
R38 2 ohm 1/4 watt
also change d12 1n4148
Posted on Jan 26, 2016
My pioneer sx-950 blows 6 amp main power fuse, can't find problem. Replaced six of the power amp o/p transistors, two resistors r35 and r37. no change. help, thanks for being there, geo
Hi George,
I think I'd be looking more closely at the AC / DC section of power supply end of things. Six amps at 120V is about 700 watts and is more than any single channel of the amp. Look at the rectifier for burnt diodes, filter caps for bulging / leaking / etc. Something trying to draw 700W is likely to be a larger component - so I'd look there.
Feb 05, 2015 | Pioneer Audio Players & Recorders
On a Faema Due expresso machine: Viewing the circuit board from the component side, with the two 0.1 uf caps on the left. The two pins on the left of the eight pin connector are completely burned from the...
The descripion you have send is only for the board. We need to know also how is the machine.
Is the machine working good up today and you have descover this after a fault?
If there was a fault what was that?
We need some of this information in order to get the whole picture and history of the machine.
Jul 27, 2011 | Vacuums
On the screen there is a green shadow on one side and a red shadow on the other side of every object in the scene
This tv has two big black ICs as convergence output on deflection circuit board that are defective and causing problem in tv, IC number is STK392-110
replace both ICs to solve tv problem, also chekc for faded color big resistor nearby these ICs or those got burn mark, replace these resistors with same value, aslo check cold/ dry solder joints in deflection circuit board and resolder these joint/ connections.
Thanks.
Jan 21, 2011 | Hitachi 65TWX20B 65" Rear Projection...
While replacing the caps on on the LCT32HA36 power supply i noticed a corroded solder joint the Z3 diode. When i attempted to re-solder it the trace came off the circuit board and I lost the R3XX surface...
The resistors are color coded.There should be 3 bands which are slightly separate from the 4th band.The 4th band is usually gold,silver,or i forget the third color which is actaually a %.The top 3 bands can tell me the value of the resistor.If you tell me all 4 colors I should be able to tell you the value,with the gold/silver/whatever as the fourth.The first one should be right near the end or top.The only 1 problem will be trying to determine the wattage rating but is usually very small within a circuit.Greg
Dec 17, 2010 | iLO LCT32HA36 Television
R38 Open Circuit what is value
What do you mean?
Its a low power PSU to use at modern board, 500W should be the minimum requirement for todays board!
Dec 10, 2010 | Antec SL300S 300W Power Supply (045176)...
What is the rating of the SMT fuse on the inverter board of a Dell 2000FP LCD monitor? The fuse is labeled F1 on the circuit board and is marked FT on the fuse itself. Thanks!
You can try this, solder in a 1/2watt 1 Ohm flame proof resistor (MOX, Metal Oxide) in place of the fuse (a lot of company use this instead of the fuse) just to see if it evevn come on or the resistor will get real hot if it has shorted out MOSFET. You should Ohm out the MOSFET and also check the value and the ESR of the two electrolytic caps, if they are bad it can cause the power supply to go into oscillation and draw too much current. i do this all the time so I do not waste my good fuse.
If it stay on then you can measure the DC voltage across the resistor then you can figure out how much the current draw is and then get the fuse with 25% higher than the current draw. I use PICO fuse for replacement.
http://s807.photobucket.com/albums/yy352/budm/PICO%20fuse%20by%20Littlefuse/
The replacement board is very expensive.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV, Monitors, Caps : http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitor kits: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Nov 04, 2010 | Dell 2000FP 20.1" LCD Monitor
Resistors burnt on power supply board on L1975NW lcd monitor looking for that power supply board
This monitor has common problem with caps went bad and it will take out the fure and MOSFET in the inverter circuit. Do you know which resistor is burnt out? I usually only have to replace the caps, MOSFET, and the fuse.
http://www.instructables.com/id/How-to-repair-a-Westinghouse-L1975NW-19quot-LCD-/
Jan 07, 2010 | Computers & Internet
Schematic (or just R10) for Rampage AMP522A Car Audio Amplifier
2 years later... I just picked one of these up at a yard sale... R10 is actually a diode. The code is buried, but ends in N1.
Hope this helps!
Sep 14, 2008 | Audiovox AMP522A Car Audio Amplifier
Cuisinart CWC-1200 Wine Cooler Logo
541 people viewed this question
Top Cuisinart Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Cuisinart Furniture Expert? Answer questions, earn points and help others
