Question about Monster NCredible NTune On-Ear Headphones
Head phone snaped - Monster NCredible NTune On-Ear Headphones
Broken exhaust manifold bolts
basically the head has to be taken out the snaped bolts drilled out and retaped no other way unless there is loads of room in the engine bay modern car unlikley its probably an aloy head as well be very carfull if your doing it yourself if you go off to much you might break the walls of the head needing a new cylinder head hope this helps ivan uk
Oct 24, 2012 | 2006 Saturn Vue 2.2
TORQUED HEAD BOLTS TO 60LBS AND SNAPED HEAD BOLT IN HEAD. PLEASE GIVE ME TORQUE SPECS ON FORD 3.Ol 1999 tAURUS....mANUFACTURE DATE 5/99
inch pounds for startersget manual procedure is 6 6 step two step tighten lossen tighten long an short then loose n one at a time an retorque..need proceedure in front of you dealer or part store may copy or print off for you...
Mar 19, 2011 | Ford Taurus Cars & Trucks
Broke bo lt off in head how to get them out
you have some issues..... drill it out, re tap. i have snaped a few myself, you can also spay some good liquid penetrate to help
Sep 06, 2010 | Ford F-150 Cars & Trucks
Snaps are blurr when we switch off the flash....
Not familiar with this Camera, but does it have an Auto Flash setting which you can set so the camera will decide if flash is needed or not try this if it is available and see if that helps.
Apr 04, 2010 | Olympus FE-270 Digital Camera
Kia spotage
no remove the head then remove the camshaft ,turn the head upside down and fill the combustion chambers with oil and make sure the valves are sealing ,i do fell you only have bent valves
Dec 14, 2009 | 1995 Kia Sportage
Think my sim card as snaped in side can you
Yes remove the battery cover.You will see a battery and a sim .You often need to remove the battery before getting at the sim.
Check if sim is damaged.If it is phone your supplier e.g orange,tmobile for a free replacement.
Hope it helped.
Dec 09, 2009 | Cell Phones
Ryobi trimmer not spinning, the motor runs fine, I think the friction clutch is worn.
Either the cintrifugal clutch is not engaging(if that model has one). Or the drive cable is snaped, or the rotary head drive lug is stripped. Pull off the drive head(where the nylon cord goes) & behind it is a flexable cable that transmits drive from the motor to the drive head(bobbin).pull it out and see if its broken.Check The rotary drive head lug,its on the top of the drive head (bobbin) you removed.
hope this helps
Regards Andrew Porrelli
Dec 05, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
When ever I operating camera the photos are not saving in MC/PM
try doing restore factory setting before doing so save ur contacts messages everything in phone memory after restoring all phone memory wil be lost
Dec 16, 2008 | Sony Ericsson K550i Cellular Phone
Mk3 ford fiesta spark plugs
honestly fords have been notoreous for there not so well built heads. I would try to lubricate it with a penatrating oil (one that foams works better than wd40) and give it your best shot otherwise find someone who is selling the same head. Also note to put on some anti seize stuff to prevent it from happening again.
Oct 14, 2008 | Ford Escort Cars & Trucks
Monster NCredible NTune On-Ear Headphones Logo
62 people viewed this question
Top Monster Audio Players & Recorders Experts
Lawrence Oravetz
Phillip Hicks
Phillip Hicks
Bill Boyd
Are you a Monster Audio Player and Recorder Expert? Answer questions, earn points and help others
