Washing maching grinding during spin
Had machine just over a year already been fixed once now its making a horrible grinding noise when its on spin can I fix this myself?
  • 1,383 Answers
These side load washers are a joke, and after working on my first one, seeing what a bad design they are. I would junk it and get a top load. but hey if it's still under warranty have it fixed. LOOK it might have a recall also ? search the model number.. I myself wouldn't spend a dime on one of the stinky, smelly pos's good luck.
Jay the pool pump motor repair guy in longwood Florida
remember to thumbs up. thanks.. J
Posted on Feb 08, 2014
Testimonial: "its a haier hwmp55-918 and its a top loader"
  • 14 more comments
  • Jenn Duckmanton
    Jenn Duckmanton Feb 08, 2014
    it also doesnt have a agitater so it cant be that either im in nz and i dont really want to pay a guy $100 if i can do it myself :)
  • Jay Finke
    Jay Finke Feb 08, 2014
    it has a spindle on the back of the drum thts hooked to the spider assembly ther are 2 big bearings on this assembly that are not the easiest to remove and might have corrosion issues making them near impossible to replace all you can do is try. locate the parts list breakdown for this model and search for parts prices, when you get the unit apart you will find blocks of concrete, removing these make it much easier work on . and it will cost more than a hundred bucks to have a guy fix it, but you might do it yourself , for under a 100 maybe 40 if you lucky.
  • Jay Finke
    oh great now I see it's a top loader.. DUH bet the water pump is bad and tats a gravy fix on most washers and can cost in the 10's of dollars.. good glad it not a front load !
  • Jenn Duckmanton
    thats what got fixed last time the pump lol it was blocked with a 10c piece
  • Jay Finke
    you must be careful with bleach, it can cause major damage to seals in the washer, what it does is damage the rubber seals in the washer allowing water to get into the bearings. so if it is a belt dive , take off the belt and HAND TURN EACH pully, the one that feels crunchy is the problem. common problems arre too much chorien and leaving water with chemicals set in the unit. every once and awhile run BACKING SODA in a short load (smal) load to keep it fresh.
  • Jay Finke
    Remember; knowledge the only thing you can take with you when you die, so spread it around !. and any spelling errors are the fault OF my smart phone. hope I was of some help, over 50,000 people seen my tips, feel free to check out my other posts and see what a old farmer knows. "if i can't fix it - i
  • Jay Finke
    I'll break it try'n. "Jay..if you can have accurate pictures of what we are working on ! jay
  • Jenn Duckmanton
    ive tken te back cover off and found wht is making the noise just need to figue out how to fix it its a plastic white cog at the bottom
  • Jay Finke
    does it look like a LOVEJOY ?
  • Jenn Duckmanton
    http://ts4.mm.bing.net/th?id=H.503937656...
  • Jenn Duckmanton
    more like this
  • Jenn Duckmanton
    ill take a pic of it might be best
  • Jenn Duckmanton
    https://fbcdn-sphotos-b-a.akamaihd.net/h...
  • Jay Finke
    HUH NEW TO ME BUT IN THE SAME ballpark Iasssume. i'm sorry it's going on 4am my time and I'm pooped out, but any more pictures can be of great help., and remember what i told you "feeal the drives or imputes for that cruntchy sound. can no longer hold my eyes open.. GN.. Tlii 2 maro.. j
  • Jenn Duckmanton
    tyvm for yr help
  • Jay Finke
    Jay Finke Feb 11, 2014
    if it is a belt drive, take the belt off and fell the bearing by spinning the pully's, this will help you locate the problem
4 Suggested Answers
IrishDruid
  • 2712 Answers
SOURCE: Grinding noise from hell - no spin, no agitation (except my own!).
Please see the following link for all possible troubleshooting tips:
http://www.repairclinic.com/0088_11_1.asp#Level1_3
Hope that helps! Should you have any further questions,please feel free to post them here.
P.S. - If you find that the solution/answerI provided led you to, or resulted in a fix, please close the ticket with a FixYa!rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on Oct 04, 2008
  • 116 Answers
SOURCE: Squeaking/grinding/rattle noise during wash and spin
That sounds like a clutch problem - probably just worn and need replacement. Will definitely need to pull to find exact fault.
Regards
Posted on Nov 16, 2008
  • 27 Answers
SOURCE: The washing machine started making a grinding
sounds like a bearing... although it could be the water pump... water pump is an easy fix... bearing is not an easy fix... take the belt off the bottom of the pump (under the machine) and see if it spins freely by turning it w/ your hand... or if it seems really stiff... if it looks good then it's def. your bearing...
Posted on Jan 15, 2010
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Have a proforma toploader and is making a grinding noise in both wash and spin cycle. it is still draining and doing everything just making the noise.
We have a proforma toploader washing machine and when using the machine in makes a very loud grinding noise during the spin and wash cycle. On occassion it also does not spin the clothing out properly, however the machine is still usable.
Dec 29, 2010 | Maytag Performa PAV3200
While washing it makes a horrible "grinding?" noise and after draining the clothes are still wet and it will not spin. the horrible noise is on during all cycles. will not spin. HELP, please!!
Sound very much like something (coin etc) is stuck in the pump, have had a look online to see if I can find a diagram to check if there is a customer access filter for you to check. Unfortunately, I can't find one so if you have your owners manual see if there is any info. This will also be the answer to the spin problem as most w/m will not spin until all water has been expelled. Hope this helps.
Jul 07, 2010 | Kenmore 24032\24036 Top Load Washer
Maytag washer makes loud grinding noise during the spin cycle
if it's making a noise then either your drain pump bearing is going out or your thrust bearing is going out (assuming the noise happens in both spin and wash). Tip the washer backwards so that you can get underneath of it. Take the belt off and spin the pump pulley on the right side. This should spin effortlessly.
The middle pulley is the trustbearing pulley. Spin this--- one direction it should have a little bit of resistance--- the other should have more resistance
Aug 20, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Makes horrible noise during spin cycle only
The bearings have most likely gone bad. This is a very common problem with the front load washer when powder soap is used.
Jan 28, 2009 | GE WBVH6240F Front Load Washer
Whirlpool Duet Sport not running it makes clicks and it grinds
A common problem with noises from washing machines has been the under wire that may come out of small clothes. In the washer they can get stuck in one of the inner basket holes and make a scrapping noise, they can actually make there way into the pump and jam the pump, or make a terrible noise when the pump is running. Grab a flash light and have a peek inside the washer for this. Front load washers seem very common to this happen! If the tiny cloth is showing signs of fraying, may be best not to wash it in the washing machine, replace the cloth.=======
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Dec 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Cheers!
IrishDruid
Oct 04, 2008 | Washing Machines
Washing Machines Logo
88 people viewed this question
Top Washing Machines Experts
