Question about Ulead GIF Animator 5.0 for PC
Ulead gif animator 5 won't open up - Ulead GIF Animator 5.0 for PC
How do you upload an animated gif in 9gag?
9gag.com/gag/18478/baby-instructions-all
Not sure of the above.
Jun 17, 2014 | 9gag.com
My samsung GT-C3222 won't read a pictures and videos from other phone when i send it via bluetooth it can't open
This phone record videos in 176 x 144 pixel resolution, 15 pictures per second. The video file is compressed with H.263 standard and formatted with MPEG4 header. In case the other phone uses a different format, or a higher resolution, your phone most probably will not be able to play the received video file.
Your phone can display JPEG, GIF, animated GIF, PNG, and WBMP type pictures. Other phones can display SWF (animated) pictures as well.
Sep 04, 2011 | Samsung Cell Phones
How to upload a GIF in Facebook?
Facebook doesn't allow animated GIF. You can upload a gif format file in Facebook just like the way you upload jpeg pictures.. BUT it will not be moving/animated.
Jun 15, 2011 | Computers & Internet
I'm using GIMP to try to create falling snow. The 1st snow image has snow covering the image, the 2nd has the snow moved down 12.5 pixels, the 3rd has the snow moved down another 12.5 pixels, etc. until I...
How are you playing it? are you trying to create an animated gif?
If so, do the following:-
Create a file, with each of your snow images as layers, then
File-> Save As.
Name the image, then go to "Select File Type."
Make it a .gif image, and then click save.
GIMP gives you the option of flattening it or creating an animated gif. Click the button that says "Save as Animation", and then click export.
Then you get to alter a few more variables in the next dialog box (- you can set the frame rate (a higher number makes the animation go faster) )
Then once saved, load it up in an internet browser, and it should work.
Once you've saved you're gif image, open it up in your image viewer. If your normal image viewer doesn't show the animation, try opening it in Firefox or Internet Explorer. You can do this by right clicking on the file, and selecting "Open With." Then choose your internet browser, and you're all set!
Dec 31, 2010 | GIMP
Can't save gifs
I had the same problem and googled a few forums with zero results.. so i found out what the problem was atleast for me... same error message when you try to save a GIF file "Unable to finish GIF Optimization process" What you need to do is this.
When you click on the Optimize tab you will get the same message again.. so click ok.. then at the very top second to the last icon is the Optimize Panel.. Click on it so the Optimize Panel comes up... then click on the Locate Palette tab.. and tic the "Preserve Local Palette" then you need to also tic the "Local Palette for all frames" once those two options are checked.. you will be able to save GIF files and the error goes away.. atleast for me this is what solved my problem..
Good Luck
Jan 30, 2009 | Ulead GIF Animator 5.0 for PC
Can't get animated gifs to work on LG Rumor (LX-260)
1. Make sure the animation is of proper size for the Rumour (176x220 or 220x176 pixels). 2. Try using rumkin.com's uploader instead (it even has a special send-to-SMS option made for Sprint).
Jan 21, 2009 | LG RUMOR Cellular Phone
How to animate gif in vb6 and to enter from one form to another?
you can generate the gif animation in adobe imageready and you can open it in the imagebox of the visual basic 6
Jan 10, 2009 | Microsoft Visual Basic 6.0 for PC
Samsung sgh d900i
Ulead gif animator program and some 240x320 pics...You create a animated gif from these pics....Upload to your phone this animated gif file and select it as wallpaper.... Because there is only one embedded UGO theme on D900i and you can't upload any themes.
Jul 12, 2008 | Samsung SGH-D900 Cellular Phone
2d Animated Frame
If you're using Photoshop, you can do so with an animated GIF image. Here's a tutorial: http://www.tutorialized.com/view/tutorial/How-to-make-an-animated-gif-image-only-on-photoshop/31955
Feb 07, 2008 | Adobe Photoshop 7.0 for PC
Ulead GIF Animator 5.0 for PC Logo
37 people viewed this question
Top Ulead Computers & Internet Experts
d3yavu3
 Grubhead
Grubhead
Sandrine Sims
Sandrine Sims
Level 1 Expert
Are you an Ulead Computer and Internet Expert? Answer questions, earn points and help others
