Question about Tablets & eReaders
LE1700 can't connect to internet
Motion Computing LE1700 Tablet can see wireless connections, but when I try to connect to my personal wireless, it will "acquire," but then...nothing. It just stops, does nothing. No internet. In my set-up for the tablet, it tells me I have no Wireless broadband. How can this be when I SEE the connections available? I'm scratching my head here.
    Sergeant:
  • 303 Answers
Try resetting your internet modem and wireless router by unplugging them wait 30 seconds then plug in modem let it boot then the router. You can also try restarting the tablet and see if that helps.
Posted on Feb 08, 2014
2 Suggested Answers
SOURCE: connecting tablet to internet
I have no connection on my android tablet and when I try to connect it keep say authentication problem
Posted on Jul 11, 2013
Show me how to restore my tablet to factory settings?
Hi Anonymous.
Looking about, the manual for this system
https://www.motioncomputing.com/downloads/User_Docs/LE1700/LE1700UserGuide_vista.pdf does not talk about how to reset the system. There is mention of a reset for a CL900 system by pressing the SAS, Battery Status, and Power buttons at the same time
http://support.motioncomputing.com/kb/KnowledgebaseArticle10597.aspx?Keywords=LE1700+Reset I can't verify this will work on the 1700.
Your most direct answer may come from calling the Motion Computing technical help line:
1-866-322-9783, option 9.
7am-8pm M-F CST
Good Luck!
D
Nov 23, 2015 | Motion Computing LE Tablets & eReaders
Don't know what Enter HDD Password means?
It means that you must enter a password to access the Hard Disk Drive
May 01, 2013 | Motion Computing LE1700 (EB844523252)...
Hard drive disappeared
this is a common problem on these le1700's. Can you hear the micro drive spinning up when you turn on the tablet? If you hear clicking the drive may have gone bad. If the drive is heard spinning up and doing normal whirr's and clicks it may be the connectors need to be reseated on the drive. Opening the panel for the drove and removing the 4 screws allows you access to the drive and the delicate ribbon cable attached to it. Carefully reseat the drive, or have a person that knows about zif (zero insertion force) drives reseat it for you. If it's still not working it's possible the cable itself went bad. ONLY OEM cables seem to work on these- the aftermarket ones are iffy. Also they type of drive seems to be important as well- Toshiba or Hitachi micro drives are o.k., but a micro ssd ziff seems to have less compatibility issues in my experience.
Apr 17, 2013 | Motion Computing Motion LE1700 Tablet PC...
Motion LE1700 Tablet PC repair
If the tablet is turning on, but not booting into your os then there is most likely a problem with the hard drive. If the computer doesn't turn on at all then the battery or charger may not work.
Apr 02, 2013 | Motion Computing LE1700 Tablet PC
Motion Computing LE1600 Tablet PC won't charge.
know of similar problems. either the cable and connection end you have or the receiving end in the tablet. can be diagnosed by getting replacement charging cable. if the problem goes away then its the cable if not it is probably the receiving end in the tablet
Apr 05, 2012 | Motion Computing LE1600 Tablet PC
My power slide button on my motion LE1700 does not power up my tablet, this is my second one this has happened too. I have sent if off for fixing and last time they charged myself 400pounds for a complete...
those are generic B.S. answers. The power switch is a flat tab that has two prongs on the rear side that interface a very small slide switch on the mother board. The mini slide switch has a plastic piece that sticks out about 3mm and the plastic part is unfortunately not very strong. the slide return spring may have become detached as well- this indicates major trauma to the slide switch in some way- and the repair is expensive because the parts are not readily available- hence the 400 price tag for a whole new board. Nowadays these tablets are dirt cheap. I'm guessing by how old this post is you have moved on to a newer tablet- if not I'll work with you to get it fixed- at a lot less as well.
May 19, 2011 | Motion Computing Motion LE1700 Tablet PC...
Need to install new os for motion computing m1400 can anyone help
I suggest Windows XP Pro...
You can open a lot more programs than what you can on Windows Vista with the same amount of RAM etc....
Or you could go for Vista.
Is there a CD Drive does it connect to PC?
I have no idea how to work these.
If it connect's through USB Insert a Windows XP disk into your Drive reboot your PC and install it to remove able Drive.
If you want to ensure that it does not scrub your PC copy then disconnect your PC's Hard Drive.
Sorry if I make no sense I am tired.
Hope it help's.
-Tom.
Jul 14, 2009 | Motion Computing M1400 CENTRINO 1.1G 512...
PC shuts down when accessing wireless network
Check in Device Manager to see if there is a problem with the Wireless Network Adapter. If you see a Yellow! or a RedX, then right-click on the network adapter see what the status of it is. It has a troubleshooting section. The only part of your wireless adapter that could possibly shut down the computer would be the driver.
Dec 27, 2008 | Motion Computing M1400 CENTRINO 1.1G 512...
Tablets & eReaders Logo
64 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
