Question about Bosch 24 in. SMU70 Built-in Dishwasher
No Water , pump running
Timer stays at initial # , pump motor heard, no water flows , same for all cycle settings . Water inlet switch works if powered but does not work when in the machine. Suspect circuit board issue ...Need to know the RESETTING sequence for this machine
  • earm0007 Feb 08, 2014
    Title is wrong the machine is Bosch SHU6802UC/U06 I think the resetting sequence will be the most useful info ....
    [ This may be a repeat post]... I found the instruction manual for this machine but it is useless..does anyone have a link , ( that works), for FREE REPAIR manual for the Bosch SHU6802UC/06 ... /U06 on the machine but it does not tend to work in search engines etc...
SOURCE: Bosch builtin 60cm SGV4313 dishwasher
many thanks however intend purchasing new machine
Posted on Sep 15, 2008
  • 39 Answers
SOURCE: bosch dishwaser
Hi francoisj
There might be water in the bottom pan under the dish washer. first turn off the power, then take the kick plate off and you should be able to feel if there is water in there. If there is remove all of it. you can do this one of 2 ways useing paper towel or my pulling out the dishwasher and tipping it 45 degrees. i recomend trying papertowel first and that should get you going again. hope this helps
brent
Posted on Sep 29, 2008
skrbin
  • 121 Answers
SOURCE: Bosch S9GT1B not taking water
check electro valve,water-level switch.
Posted on Feb 15, 2009
  • 36 Answers
SOURCE: Bosch SHU43C Dishwasher.
1-800-944-2904 That is Bosch Company. They will send out-- next day.
Posted on Mar 12, 2010
Macmarkus
  • 2605 Answers
SOURCE: My Bosch diswasher water inlet work fine, when the
Hi, it sound's like the wash motor is either seized or just stuck, let's hope it's the later. Bosch had issued a service tip about this problem several years ago titled "Loosening Frozen Impellers" strange choice of word's considering nothing is froze..at least you'd hope lol. I have a copy of it at home and I can likely post it later, ( I'm on my iphone presently ) but essentially what it say's is this...Remove the pump fitler ( inside the tub under the bottom rack ) locate the hole to your right down in the sump well, you should be able to see it with a flashlight or well lit area. Once you've located this hole ( it's providing access to the wash impeller without pulling the unit from the cabinet ) reach in with a 8mm nut driver and locate the end of the impeller and turn it clock-wise until it feel's to turn freely. Give it a test perhaps in a rinse cycle before you put all the filter and screen back together. It should be fine unless the motor is seized, we'll cross that bridge when we get to it, try the repair tip for now. Let me know how that help's and/or if you need further assistance. Thank's for visitng "fixya" for you repair tip's. If this is indeed helpful please rate the solution accordingly, if not, again please let me know. Thanks again and good luck. Macmarkus :)
Posted on Mar 26, 2010
Testimonial: "Many Thanks! but motor still not running Impeller turning free"
Agitater wont stop at start of cycle maytag mvwc6esww
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Jan 20, 2013 | Maytag MVWC6ESWW Washer
Washing machine filled up with cold water but will not work
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Jan 19, 2013 | Whirlpool Washing Machines
Washer won't drain or run thru any cycles.
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Jan 14, 2013 | GE WSXH208A Front Load Washer
Set cycles, push start and it shuts off
Jan 11, 2013 | Washing Machines
Tricity bendix 1400w will not start have heard 6 beeps
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Jun 27, 2012 | Tricity Bendix AW1400W Front Load Washer
Wwill not spin and motor stopped running
Jun 11, 2012 | Bosch Nexxt 100 Series WFMC1001UC Front...
I have a Whirlpool top loading washing machine model 3RLSQ8033SW. When set for a cycle it starts to fill with water but just continues to fill. I thought the timer might be faulty, but do you think it...
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven from the flow into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
So it seems that the pressure switch is not activated to cut off and hence the program does not move forward. you can check the vacuum control on the diaphragm of the pressure switch.
Thank you for using fixya.
Aug 12, 2011 | Whirlpool Clothes Washer Timer Knob -...
Siemens siwamat 6142 loops in cycle 1. my machine stays in cycle 1 (washing). after the timer goes down to 1 minute, the program restarts and it still stays in cycle 1. thanks!
Aug 09, 2011 | Washing Machines
Electrolux ewf 1087 when you turn on the on switch no control lights and a knocking sound coming from the door area
It is possible that the machine does not start off the cycle because there are errors or back feedback from the inputs. For the program to start up the main program controller must initiate the INLET valve to open up and allow water to flow into. If this does not happen then the voltage at the inlet valve must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.The noise when the machine is switched can be that drum or the motor interupting when switched on. So check the program timer unit before the cycle is initiated.
Jul 19, 2011 | Electrolux Washing Machines
Hello, I have an Estate Washer model # TAWS800JQ1. The unit will not fill at any cycle or water level setting. I have replaced the inlet valve with a new one, but still no water. After reading some...
Checking the ouput at the time of the cycle wil determine the fault of the program controller. Also the pressure switch can be checked by blowing air to see the switch click.
Jul 08, 2011 | Washing Machines
Dishwashers Logo
29 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
