Question about GE 7-5290 Clock Radio
Poor FM Radio reception - intermittent static
My GE Spacemaker under-cabinet FM radio has a signal reception problem. Static will increase, decrease or disappear intermittently, and the static changes or disappears depending on where I stand in relation to the radio. When there is no static, the sound quality is fine. Over 6 months, the problem has been steadily worsening
2 Suggested Answers
SOURCE: GE 7-5402 Spacemaker under counter radio - all static
fix
Posted on Feb 20, 2012
WHY DOES MY 2004 LINCOLN NAVIGATOR HAVE EXCESSIVE RADIO STATIC ON AM?
As suggested it could be underhood electrical interference. If the "static" changes with increased rpms (rev the motor to find out) chances are it is ignition related and could be literally everything from the alternator to the ignition coil through the distributor cap, but best bet is the spark plug wires (which if still original really should be replaced anyway) or the plugs themselves. If your am static doesn't change with engine revolutions and your fm works okay I would check antenna and the antenna connections at the base of antenna and back of radio. if you cant even get a clear signal on the most powerful AM station in your area, I would bet on some kind of break in the connection between radio and antenna. p.s. if you;ve anything plugged into cigarette lighter or other 12volt outlets in the vehicle unplug them before doing any of the rest!
May 19, 2014 | 2004 Lincoln Navigator
Fm works, am does not
Check the antenna connection. A poor connection will often be good enough for FM but make AM reception so bad the the radios auto-gain circuits will mute the output unlike old AMs that would just produce loud static in poor signal conditions.
Apr 17, 2014 | Car Audio & Video
AM and Fm radio reception poor. Suspect bad ground since radio and antenna have both been changed. The static sound while on AM increases when I press the accelerator. How do I isolate an intermitt
static sound on AM band can be reduced by the adding of a capacitor to the alternator terminal. Check the coax cable especially the outside braid is connected to the body for earth
Jan 07, 2014 | 2002 Toyota Highlander
Poor radio reception in 2008 toyota avalon
I had the same exact problem. Toyota changed the Amolifier that improved sound quality but not the FM Reception.
THE HARNESSES CONNECTING ANTENNA TO RECEIVER (TWO OF THEM) HAD IAASUES. REPACING THEM FIXD THE ISSUE. FM RECEPTION EXCELLENT NOW !!!!!!!
Apr 11, 2012 | 2008 Toyota Avalon
The AM/FM radio in my 2003 cadillac CTS faded to only static
check antenna cable connections at radio & antenna.suspect power antenna if equipped.
Sep 30, 2009 | 2003 Cadillac CTS
could be or the station you have on.in between towers you will get static.
Jul 15, 2009 | 2007 Mini Cooper S Convertible
!994 Park Avenue FM radio reception poor. AM signal OK
Check antenna connections at radio and antenna assy.. Poor connections will only receive AM and hardly any FM
Apr 06, 2009 | 1994 Buick LeSabre
SL100 static and bad FM reception
I have noticed various changes in my invehicle FM reception as well. There should be a external antenna that came with your car kit. This is precisely for these types of issues. It is designed to run along the windshield inside the car closest to the Cars radio antenna. It should plugin to the bottom of the cradle. Then tune it into a clean FM station (one that has no local station on it) and position the cradle and/or ext. antenna till you get the best reception in your vehicle. It could very well be that the antenna has come has loose on your car stereo backplane. You would probably notice decreased reception on regular AM/FM stations as well though.
Your wifi reception/functionality is a completely different animal and has no bearing on the FM transmitter in the car cradle. When your on wifi your not receiving signal from a sat. anymore just simply streaming internet audio like your computer.
Good luck.
Apr 08, 2008 | Sirius STILETTO 100 MP3 Player
Ge spacemaker radio model 7-5402 problem
OK, I found out what the problem is.
ON my GE 7-5402 Spacemaker under-cabinet radio, the FM was only static. I've opened it up and there is a component which is failing. When I used a heat gun on the circuit for about 5-10 seconds, it started working and it stopped again when it cooled off. After some time I isolated which component it was that needed the heat in order to work. Here's where to find it:
  1. Remove the top (25 screws of various length)
  2. With the LCD facing you, look to the right of the CD-drive close to the large aluminum cooling fin.
  3. There is a single transistor with markings of: "D2012" and "6:R".
This transistor is the problem and I believe if it is replaced, the FM radio should work. I'm going to try it and see what happens. I think I found the right one online for less than $1.
Hope that helps you guys!
Feb 10, 2008 | Audio Players & Recorders
GE 7-5290 Clock Radio Logo
62 people viewed this question
Top GE Audio Players & Recorders Experts
Greg Cann
Greg Cann
Carlos L. Burgos
Carlos L. Burgos
SHARCNET-USA
SHARCNET-USA
Are you a GE Audio Player and Recorder Expert? Answer questions, earn points and help others
