Question about 1998-2003 XJ-Series Supercharged Rear Back Coil Spring Set Suspension Damper
No compression the light came on that said restriction it started back a time or two but now seems like it has no compession
    Sergeant:
  • 311 Answers
Best chance of a precise answer to that question is at http://www.jaguarforums.com/forum/xk8-xkr-17/
Helpful people, and they can answer EVERY Jag question, every model. Join, read the "New Member" instructions, and ask away.
If i were to guess, I would venture it to be a clogged cat convertor. Great instructions on that forum on how to service one by soaking it in citric acid (vitamin "C'). Works better than replacing with aftermarket unit.
Posted on Jul 28, 2014
I have an old 028 stihl av super electrical quickstop have rebuilt the carb on it put new gas new spark plug is turning over but not starting please help Dan from NY
due to age , id start by seeing if it has any spark in plug , remove plug wire and insert 1/4 bolt , arrange near by a metal bolt or other item (not handle ) and do not hold bolt near item
turn ign switch on (don't bother with choke) and pull engine over several times , observe 1/4 bolt for blue sparks (dim lights if necessary )
no spark present , trouble shoot ign system farther
spark present - remove and clean plug with good solvent
add a little bit of engine start fluid to plug hole and reinstall plug and wire , attempt to start engine , nothing - compession problem or shorted plug if it sputters but doesn't start then its a carb problem , troubleshoot carb (clean it )
Apr 14, 2015 | Stihl Garden
Wont start
pull a spark plug out and crank itover to see if theres compression. Or perform a compession test. If you pull the plug out, and turn it over it should blow air our...strong. If it doesn't, look to the timing belt. If it went from running to not running over night, could be that. check the simple things first. fuel, spark, compression, timing, for starters.
Apr 06, 2014 | 1997 Mazda 626
Compress rear brake calipers on 2004 freestar
many fords have "spin in" caliper pistons.
Your local auto parts store sells the tools you need. (Multi sided for different sizes)
You insert the tool and spin the caliper piston back in. (many times, they are hard to start turning but should be easy once you get started)
Make sure the cap is off the brake master cylinder so the brake fluid and rise up as you screw in the pistons.
Hope this solves your problem.
Feb 02, 2013 | 2004 Ford Freestar
2001 mazda mx5 no compession timing marks perfect spark plug holes have 20 psi vacuum
Possible you broke a camshaft or one of the cam gears is not connected to the camshaft ?
Can you watch the starter turn the cam via the timing belt ?
Jun 27, 2012 | 2001 Mazda MX-5 Miata
I purchased new byke one month before but its not getting start, i tryed kiker also its take more then 10 times
Make sure you have Spark at the sparkplug and that your sparkplug is in good condition with proper gap.
Makle sure fuel is getting to carbs, by loosesing the carb drain screw - fuel should flow out.
if your getting fuel, tighten the drain screw back and turn the motor over.
make sure key switch is on and on/off switch is on.
if motor doesn't start, spray a very little of carb cleaner spray into air filter box.
if motor starts and dies that means that your carbs are getting gas but the jets are clogged and not allowing fuel to go through the carb, pull your carbs off, disassemble, soak, rinse, blow out with compressed air, make sure you can see through the jets, reassemble and your bike will run.
If your getting fuel through carbs and you have good spark, then pull your spark plugs and do a compession test. You must have at least 100 psi compression, if not your rings are bad, or you have a stuck valve.
If no compression:
You can check and adjust your valve clearance, only when the motor is cold.
Do this and then recheck your compression. If compression comes up. Your motor with run.
If still no compression. Then you must take the top end apart and see why.
Have your head inspected to make sure valves are seating.
Check your piston ring end gap.
You will find it to be one or the other to cause your loss of compression. Fix and repair.Reassemble.
a 2 stroke motor with no compression is usually a blown head gasket.
Dec 11, 2010 | 1989 Honda CBX 250
Runs like the devil, but only when I get a chance after "many" pulls on the starter handle, some times she/he just refuses, even after using ample starter fluid. Should I change the plug...
compression ratio is bad. when you try and start the engine it warms up and the machine
gets tighter and the compession goes up then the engine starts ... you ran it on gas without oil and
rings are starting to go out... buy a new one...
Nov 05, 2010 | Mantis Little Wonder Tiller/Cultivator...
Suddenly started smoking white smoke and seems to be losing power
White smoke is coolant being burnt. That with your lose of power would suggest a bad head gasket. A compression test could confirm it. Hope this helps.
Nov 25, 2009 | 1995 Plymouth Voyager
1988 yamaha 200 sounds like theres water in the gas but isn't
Sounds like either the timing has jumped, the stator plate is loose,or the reed valves are bad.More likely the reed valves.
Please take time to rate this fixya
May 14, 2009 | Yamaha RD 250 Motorcycles
Will not start
Homelite leaf blowers that use whats called a half crankshaft system are prone to many problems. Whats a half crank system you ask? If there is a small aluminum plate that attaches to the side of the engine by the gas tank you have one of these. Usually held on with 4 small bolts. I just got rid of a Homelite Vac Attack 2 that had spark and compression but the compression checked low about 75 should be 90 or better. What happened, a head bolt came loose and the engine ran lean causing the fragile rings on the piston to heat up and when that happens they loose their outward spring that seals against the cyclinder walls. A simple compression check using a gauge and not your finger will tell you that. Other causes could be less than normal spark, or maybe the exhaust port under the muffler has carbon build up or the muffler is plugged up also Check all bolts, and nuts to make sure they are tight.
Glenn
St. Paul, MN
Apr 15, 2009 | Homelite Consumer Products MightyLite...
Rough running, erratic spark
Run a compression test on the cylinders.If reading is low on any drop a little engine oil into the pot. If compression rises you have compession ring problems. Remove all plugs before you try this and place leads away from engine.
Mar 04, 2009 | 2000 Ford Ranger SuperCab
1998-2003 XJ-Series Supercharged Rear Back Coil Spring Set Suspension Damper Logo
61 people viewed this question
Top Jaguar Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Spyro Matiatos
Spyro Matiatos
Arnie Burke
Arnie Burke
Are you a Jaguar Vehicle Part and Accessory Expert? Answer questions, earn points and help others
