Question about KitchenAid -- 1440 Watts Convection Toaster Oven -- Model: Kco223cu
Can i use an ordinary wall plug for the 1440 watts
Or will this oven blow a fuse if other things ar e on the same breaker
Delonghi xr640 toasting-finished chime not working
follow this steps and fix it. God bless you
f the oven doesn't work at all, make sure the circuit breaker or fuse is on at the electrical service panel and test the electrical cord . If the oven doesn't work on its toaster and oven functions, test the main switch . As needed, check the fuse .
If the toaster function doesn't turn off unless the door is open, test the solenoid, the switch and if necessary, the thermostast.
Location of the typical toaster oven's thermal fuse.
If the toaster oven stays on when the door is opened, check the main switch . If the oven doesn't heat, test the heating elements.
Oct 27, 2013 | DeLonghi XR640 Retro 1500 Watts Toaster...
My Breville BOV800XL doesn't have any power.
My BOV800XL did the same thing. Of the three parts you mention the thermal fuse is by far the easiest to test and in my opinion the most likely to go out first. Check it with a meter. If you have trouble locating it read the FixYa solution for "The Breville BOV650XL will not power on." Check it for continuity like you would any fuse.
I found replacement parts at ereplacementparts.com. The thermal fuse assembly was $23 when I checked. Or you could just replace the actual fuse portion of the assembly with a comporable fuse such as http://www.mcmelectronics.com/product/NTE8213. Basically you need a 216*C thermal fuse. These can be had for less than $2 plus shipping. Buy a few just in case.
I just ordered my fuses today so I can't report on the success of my repair, but I am confident the new fuse will solve the problem.
Aug 30, 2012 | Breville BOV800XL 1800 Watts Toaster Oven...
Black & Decker toaster oven won't work
We've had many of these over the years...they seem to run along just fine, and then, one day, they quit. There is no fuse, but if it's the only thing plugged into that wall outlet, the one thing you might check is the circuit breaker on that line. To be sure, plug a lamp into the socket just to make sure you're getting electricity out of the wall.
Sorry to say, it may be time to purchase a new unit.
Sep 14, 2017 | Applica CTO6301 Toaster Oven
I had a house with old funky wiring. I'm pretty sure it caused me to blow a fuse in my toaster oven. Can you tell me where the fuse is located?
The manual mentions nothing about any user serviceable fuse or reset. "Funky" wiring in your home shouldn't cause an appliance to fail. Wiring that is in poor condition usually results in blown fuses or tripped circuit breakers in the service panel, heat in places it shouldn't happen and of course, fires.
It is very possible that the outlet is worn to the point that it doesn't make very good contact with the toaster's plug and has caused the toaster to fail to heat up. Try removing the toaster to a different outlet and try again. Check the original outlet with another appliance or lamp, etc. to see if it works or not. Also, check to be sure any ground fault outlet hasn't tripped.
If the toaster fails to work as expected in another outlet, there's little you can do to repair without jeopardizing your safety - especially if you're not familiar with appliance repair. These appliances aren't really meant for disassembly - manufacturers don't want to be liable for "repairs" that end with injuries, burns and death so the make them pretty hard to take apart. Even if you are successful, they make even harder to reassemble without it looking obvious that it has been disassembled.
Take it apart if you want - learn about how it works and buy a new one. These devices don't rely on rocket science and the controls are pretty simple - but it is an electrical device and electricity isn't a hobby. Be safe. Be smart.
BTW - I don't want your money - I just don't want you to get hurt.
Goiod luck!
Feb 18, 2011 | DeLonghi AR690 Retro 1500 Watts Toaster...
ELECTRONICS SEEM TO WORK (ON/OFF; TIMER; CLOCK; OPERATION SELECTIONS [TOAST, BAKE, ETC]) BUT ELEMENTS DO NOT LIGHT UP
check the resistance of the plug by turning the timer and temperature switch, if there's no resistance, open your unit and check the resistance of thermal fuse which is connected to line wire. it is look like resistor..if the thermal fuse is ok then check the resistance of heating element..
Sep 30, 2010 | Krups FBC2 1600 Watts Toaster Oven with...
Krups FBC2 Convection Toaster Oven Simply no power at all.
Having a toaster oven and a coffee maker on the same circuit is asking the breaker to trip in the house electrical panel, but I guess that you have learned the drill: only one appliance on at a time. Try moving the oven to the working side of the socket (the two socket sections can be spit apart and power each half from a separate house breaker and wiring). If the oven now works, check for a tripped breaker in the house panel. If the oven still doesn't work, look for a reset button near the cord entry point. Many heating type appliances have a thermal fuse that opens when things get too hot, but you need to get inside the cover where the cord enters.
Oct 11, 2009 | Krups FBC2 1600 Watts Toaster Oven with...
How to clean the inside walls of a delonghi alfredo toaster oven?
pour water in the pan with little detergent for dish,and heat it on 30 deg Celsius for about 30-50 minute,and wipe the walls with cotton rag.
Jun 29, 2009 | DeLonghi XU620 Alfredo Ultima Bake 'N'...
THERMAL FUSE BLOWN ON KITCHEN AID KCO100508 TOASTER OVEN. WHERE CAN I BUY A REPLACEMENT ? This Thermal fuse [ 206 degrees C ] is a ceramic housing mounted to a bracket near the oven wall. It contains a...
Thermal fuse is a one time safety device, order by specification. My Kitchen Aid toaster oven has one on the side with the controls marked 206c for 206 degrees Celcius when it blows, and marked with a part number that when Googled was found to be 2 amp. The fuse blows in this sequence: temperature first, then if that fails the regular fuse action will kill the circuit at 2 amps. I called electronic supply places around Los Angeles. $1. 25 later I have my part. Mouser electronics carries them for .44 cents. Placed the new one on the ceramic base of the old one, and am back to using my favorite toaster oven. Will not be using it for broiling again - that is when it got hot and quit on me.
May 28, 2009 | KitchenAid KCO1005OB 1400 Watts Toaster...
Fused plug
If it is a moulded plug you will need to chop it off and wire on a standard 3 pin plug(if you are qualifiedor capable of doing so ) If its in guarantee though do not do this. There must be a reason it blew the fuse. If in guarantee get it repaired under the terms of the guarantee.
Oct 22, 2008 | Krups FBC112 1600 Watts Toaster Oven with...
Toaster oven power failure
Call Cuisinart - that product has a 3-year warranty.
May 06, 2008 | Cuisinart TOB-175 1500 Watts Toaster Oven...
KitchenAid -- 1440 Watts Convection Toaster Oven -- Model: Kco223cu Logo
21 people viewed this question
Top KitchenAid Toaster Ovens Experts
Tom Chichester
Bill Boyd
Are you a KitchenAid Toaster Oven Expert? Answer questions, earn points and help others
