Question about Kitchen Ranges
WANT TO CHANGE OUT MY GAS STOVE WITH AN ELECTRIC RANGE. NEED TO KNOW WHAT 240 WIRE I NEED,ALSO WHAT AMP BREAKER I NEED.
  • Kitchen Ranges Master
  • 15,973 Answers
Where are you running it from? Distance from the box can have a lot to do with the size of the wire. The other thing is the amperage of the appliance. 20 Amps is common and you should use 10 guage wire in most cases.
Posted on Feb 08, 2014
4 Suggested Answers
JULIANFIX
  • 975 Answers
SOURCE: my kenmore electric range 9621 shut down
check inside the stove for some kind of fuse , also check with a multimeter set to OHMS the circuit breaker of the stove to see if theres continuity . hope it helps
Posted on Apr 21, 2008
jumptrout51
  • 3361 Answers
SOURCE: electric igniters dont shut off
Remember to turn the control knob past the "LITE" setting once the burner fires.
If that is not the issue you have one or more defective spark switches.
Each valve has its own switch wired in series with the others.
Posted on Mar 12, 2009
  • 351 Answers
SOURCE: a 120/240 40 amp receptacle adequte for installing
That power receptacle should be addequate for your unit, The ignition should get its power internally.
Posted on May 04, 2010
I have a new furnace and the breaker keeps tripping (20/30). It is a bryant westinghouse box. I think 200 amphes
1) You got a FIRE truck coming.
2) Wire is too small.
Problem is NOT circuit breaker.
3) Both 240Volt appliances on same breaker is a hazard, especially if space available in 200 amp service panel for more breakers.
4) Usually each 240V appliance has separate breaker.
5) Circuit breaker trips because of High heat on the wire.
If wire gets hot, it will start a fire inside the wall.
Electric code requires wire-size match breaker-size.
6) If you put larger amp breaker on same wire that is getting hot, then wire will get hotter.
Result: FIRE truck middle of night with folks jumping out window in glass-cut bare run across yard.
7) Each appliance has volts and watt rating on label.
EVERY appliance has label.
8) For example stove might be rated 8000 watts and 240Volt.
8000 watts divided by 240 volts = 33.3 amps
Stove would require 40 amp breaker and 8 gauge wire.
9) How to figure it out:
http://waterheatertimer.org/Color-codewire.html
http://waterheatertimer.org/How-to-install-a-subpanel.html
10) Do same calculation for new furnace.
12000 watt furnace divided by 240 volts = 50 amps.
Use 60 amp breaker and 6 gauge wire.
11) Summary: fixya wants you to be safe, and buy stuff showing in the ads.
Use a bigger breaker ONLY when bigger wire is also installed.
Call furnace installer, the installer should know to check safe wiring before installing.
Nov 04, 2012 | Bryant Westinghouse Bqc Quad Circuit...
I have a trailer house that has a 100 amp breaker box in it. I has gas for heat, water heater and stove. I am changing them to electric. Will I need to change the panel put to a 200 amp.
Its probably not a bad idea. Thats alot for a 100A panel to handle, a range needs a 50A, a water heater needs 30A, and the heat will need a 50A or a 60A breaker... Plus whatever else is in the house will be a bit more than the 100A service can handle. But if you don't have the money it will do for a while because for the most part they won't all be pulling at the same time. Word to the wise get at least a 30 space panel when you upgrade, I always install a 40 space panel because for the cost difference its well worth it for future needs because you'll fill it up quicker than you think and you'll have space for anything else you may want to add later on. Hope I helped
Dec 09, 2010 | Your One Source Homeline Circuit Breaker
How large a breaker do i need for this stove.? model rb787 50 amp is what i have now with 10 gauge wire
The recommended breaker for any electric oven isd 40 amps, though you could probably get away with a 30 amp breaker. Personally, I would go with the 40 amp breaker.
Dec 06, 2010 | Hotpoint RB787 Electric Kitchen Range
Broiler doesnt' turn on, does a viking range need a separate designated electric electrical breaker?
The documentation for this range calls for a 240 volt, 40 amp, dedicated circuit for the electrical supply on 30 & 36" ranges. 48 & 60" ranges require a 240 volt, 50 amp supply.
http://www.vikingrange.com/MEDIA_CustomProductCatalog/m2740207_F20533.pdf
Mar 08, 2010 | Viking VDSC365-6B Dual Fuel (Electric and...
Correct wire gauge and circuit breaker to use?
If it is only the oven that is electric and not the entire stove, the required wire size is 10/3 with ground and a 30AMP circuit breaker. If it is the entire stove then you need 50AMP range cable and a 50AMP breaker. If your doing your microwave also, you need a 20AMP breaker and the wire you need is 12/2 with ground.. If the current breaker you were running was 30AMP I would keep that for your oven and run new wire for your microwave.
Feb 23, 2010 | Kenmore 79383 Dual Fuel (Electric and Gas)...
My KitchenAid KGRA806PSS Stove's Burners won't light. And the stove gets up to 200 degrees but no further.
Bad power source. Not getting 240 volts to oven. reset breaker by turng off the back on for the stove. 240 volt double breaker. If this doesn't work problem will be where stove plugs in.
Feb 01, 2010 | KitchenAid KGRA806PSS Gas Kitchen Range
Fes330 roper stove power to stove ...ok no fault codes on display normal "stove on" lites....ok normal appearance except no heat from 4 eyes and oven below
you have no heat at all? K, pull stove out and check how many volts you have should be 240. Your elements work off 240 if you only have 120 coming to stove the lights will work jujst not your heat. You should have a double pole 40amp breaker If you only have 120 change the breaker
Aug 31, 2009 | Roper FES330 Electric Kitchen Range
GE glass top and oven are not heating?
I have an electric oven that is turning on but not heating up. The oven, broiler, & stove top are not heating up. Any easy solutions to this?
Jul 18, 2009 | GE Profile JKP18 Electric Single Oven
Electric service requirements
Number 6 wire and a 40-50 amp breaker. Anything smaller will overheat and become a fire hazard, especially at 139 feet.
May 11, 2009 | Whirlpool Kitchen Ranges
Going from gas to electric how do i install it
you will require a 40 amp breaker and 8/3 wire with ground which totals 4 wires and requires a 4 wire outlet.
make sure you purchase a receptacle that fits the plug on your range.
please mark this answer as a fixya! thanks
Mar 06, 2009 | Ovens
Kitchen Ranges Logo
41 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
