SOURCE: my vacuum kenmore canister smells
My guess would be a slightly loose belt - tight enough to spin the roller on a hard floor, but loose enough to slip (then get hot and stink) when the roller is having to work against the pile of a carpet. Worth buying and fitting a new belt without pausing to investigate further, simply because they're so cheap and you'll have to replace it sooner or later anyway. A.
SOURCE: No suction on Hoover Wind Tunnel.
Greetings from GoVacuum.com,
First this is a common problem on ALL bagless vacuum cleaners. Usually it takes longer then 1 day however.
Is there no suction in the suction hose, or is it not suctioning from the floor?
Most people buy a bagless vacuum once, then return to a bagged one after their bad experience, you are not alone!
Please give me the model number to your Hoover, (found on the bottom or the back of the vacuum on a foil label).
Thanks,
Chris Jones
GoVacuum.com
1-866-468-2288
[email protected]
SOURCE: hoover windtunnel vacuum roller brush doesn't
does the motor turn? if it does replace the belt.
SOURCE: Hoover U5780-900 Windtunnel Cyclonic Bagless
You probably need to change the belts. Here are the belts you need and the manual:
Hoover 5780-900 Belts
Manual
Testimonial: "Replaced the belts-- works GREAT!!! Thanks"
SOURCE: I have hoover WindTunnel Self Propelled Vacuum
Greetings from GoVacuum,
Here's a great video repair tutorial that we've put together to try and help you with the repair on your Hoover WindTunnel. I hope that this helps you with your repair. If you found this solution helpful, please rate this repair video by clicking on the 4 Thumbs Up Icons in the top right hand corner of my repair solution. Feel free to email me at [email protected] if you have any questions about the repair!
Video Repair of Hoover Windtunnel Belt Change
Thank you very much!
Chris Jones
GoVacuum.com
