Question about Hunter 33201 Humidifier
Manual vapor - Hunter 33201 Humidifier
Need online instruction manual for hankscraft humidifier model 240
I found this. There are no manuals available on line.
Here we have a used working HANKSCRAFT / GERBER COOL VAPOR HUMIDIFIER Model 240 WITH INSTRUCTION MANUAL and STEAMED CLEANED. This humidifier, by Gerber, has a 1 3/5 Gallon Capacity, and produces cool vapor for up to 18 - 20 hours in low, medium or high settings. The humidifier works great , does not have the directional nozzle included but does come with a copy of the instructions.
http://www.ebay.ca/itm/331790662762
Dec 03, 2016 | Humidifiers
Where do the vapor pads go
most humidifiers have an area near the vaor outlet to set the vaor pads. as the vapor comes out it creates an effect that allows the essence of the vapor to be released and rides along with the vapor. see if there is a flat spot or an area that the pads would sit. Please always keep manuals or instructions. I keep mine in a file in the drawer that is easy to find them. I just label it "MANUALS".. If I replace a unit I find the instructions and toss them
Feb 27, 2015 | Vicks Ultrasonic V5100 Humidifier
Where can i get a new water tank cap for vicks model V745A?
This is a POSSIBLE answer: I found the manual at the Vicks site, read through it, but it did not mention replacement parts at all. However, at the very end of the manual was this paragraph, which might serve as a way for you to get what you need. Quoting the manual:
If you have any questions or comments, call the Kaz Consumer Service Department at 1-800-VAPOR-1-2 or, e-mail consumerservice@kaz.com or, write to Kaz, Consumer Service
Department, P.O. Box 544, Hudson, NY 12534, explaining just how the product is operating. Specify model number. Our Consumer Service Representative will advise you how to correct the problem yourself, or will ask you to return the product for repair or replacement.
Aug 02, 2014 | Vicks Warm Mist V745A 1 Gallon Humidifier
Vicks Vaporizer V188 Manual Instructions I have lost mine Thanks Alan
You can view, download and print the instruction manual in PDF format by clicking this link.
On the page which opens, click on the "Download" button to download and save the manual.
Please note: Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Thanks for using FixYa.
Sep 11, 2011 | Vicks Warm Steam Vaporizer 1.5 Gallon...
My vaporizer is making a quiet bubbling/gurgling noise. This is only the second time that I've used it, but I can't seem to find the instruction manual. What could this mean?
That is very normal...the sound is the water being turned to steam which is the "vapor" that comes out...
Everything is okay and perfectly normal.
heatman101
Mar 30, 2010 | Vicks V150 Humidifier
I can't see my vapor.
Suspect that you may need to run white vingar through it and clear the atomizer. You should see mist all the time even when the humidity level is reached.
Jan 14, 2010 | Kaz 4100 1 Gallon Humidifier
Looking for manual instructions to clean vaporizer with vinegar
all you need is a capful of vinegar mixed into the water and it will clean it like new again
Feb 21, 2009 | Bionaire Warm Mist BWM0400-U Humidifier
Hunter 33201 Humidifier Logo
29 people viewed this question
Top Hunter Humidifiers Experts
jdthefixer
ka4iup
ka4iup
Vernon Taylor
Are you a Hunter Humidifier Expert? Answer questions, earn points and help others
