Question about Olympus Cameras
I have an Olympus VG-16 and it has just recently started to play up. I have had it for at least 2 years and it's used on a daily basis. When I go to power it on the lens opens and closes twice and then the camera beeps a few times and then it turns off. I can't use it at all. Do you have any suggestions as to what may be the problem?
  • Olympus Master
  • 17,115 Answers
This could be the auto focus sensor that is not working that why the lens comes out and goes back twice. The other thing it could be is the range on the lens is not enough and it wont reach full extension. I would send it in. www.precisioncamera.com
Posted on Feb 08, 2014
SOURCE: the lens doesnt close, the camera beeps 3 times and shuts off.
Hi just had the same problem I freaked out and then read that about the lenses problem so I figured screw it if it is broke I have to go out and buy a new one anyway....BUT I yanked a LITTLE on the lens and poof fixed it....
Posted on Oct 17, 2007
  • 48 Answers
SOURCE: Problem with camera OLYMPUS SP 500 UZ
This sounds like a CCD issue in the camera. The CCD is the part in the camera that captures the image (the "digital film") if you will and converts it to a format the camera can read.
When they go bad a lot of times you will see weird colorations and/or stripes, very similar to what you are describing.
You can try eBay for a place to buy, or maybe check the manufacturer.
Posted on Dec 18, 2007
  • 3 Answers
SOURCE: Digital camera
I had almost similar problems with my A10 from day one. The camera shuts down before the battery is depleted, most of the time while I was operating the zoomlens. I bought a new battery, but that didn't solve it. Later I decided to take it apart as a last option. As my suspicion was the zoomlens I took out two crews of the motor that operates it. Now the motor has a bit more space to move. It seemed to be too tight against the gears so it could cause an overload. After that it worked perfectly. I made pictures for hours without having the same fault again. Be carefull too make notes where all the tiny screws belong of the casing. And maybe it will be enough to just loosen the motorscrews, but leaving them out will not make it fall out of it's place. I hope someone can use this information.
Greetings, Ron Timmermans.
Posted on Jul 25, 2008
pishta68
  • 593 Answers
SOURCE: olympus 8080 C 8080 wide zoom
It may have jumped a tooth, something like a car timing chain. The Zoom in this camera is a barrel that has 3 cams that rides inside another barrel that has "tracks" for the cams. The motor rotates the the outer barrel via gear teeth, forcing the inner barrel to extend or retract. There is a tab on the gear teeth that might index the position of the zoom lens. If this tab is in the wrong position, if the gear jumped a few teeth, the camera may not know where the zoom lens is in relation to the inner focusing lens, and cause the "zoom error" If that is the case, I can help you get it back into position. This is a theory, but does explain the tab on the gear and the constant zooming.
Posted on Sep 10, 2008
SOURCE: Olympus Stylus 710 Problem with lens
Turn on camera. Blurry pic. Wirly grinding noises. Blue screen.
Codes on blue screen:
5 f 0 8
5 e 0 2
5 f 0 8
5 e 0 2
Sometimes smacking the **** out of it fixes it. Today it doesn't seem to do the trick any more.
Suggestions?
Posted on Nov 27, 2009
I have an Olympus VG-120. How do I physically update the firmware on my Olympus VG-120 camera? Thanks.
Do you have your user guide or owner's manual? Read that thoroughly and you will have no problems. If you don't, get one from the manufacturer - search their website and download.
Nov 06, 2015 | Olympus Cameras
Olympus vg 170
Be sure you did not correct your exposure compensation.
Try to switch to automatic. See page 29 of the manual for how to set exposure compensation.
Link to manual Olympus manual VG-170
Nov 15, 2013 | Cameras
There is straight white line in my Olympus VG-110
Does the line appear only on the screen or on your photos or both ?
Jan 26, 2013 | Olympus Vg-110 12mp Digital Camera Silver...
IS OLYMPUS VG110 CAPABLE OF RECORDING SOUND
Yes. However, the camera cannot playback the sound when playing the video, and the optical zoom is disabled while recording sound.
For full details, see the "Recording sound when shooting movies" section on page 36 of the manual.
Sep 01, 2012 | Olympus Vg-110 12mp Digital Camera Silver...
Olympus vg-120 write protect
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
May 28, 2012 | Olympus Software VG-120 Digital Camera
My camera was on, it was low battery but was still using it, then it turned off and the lens was still open, and everything else. I Put it in charge and it still wont turn on and the lens wont close. Its...
ive got a vg 120/d-705 olympus digital camera.reg it to the computer.says leave it plugged in for 3 hours which i have done and no movement in the camera now.is it working or not or do i take it back to the shop where i bought it from.please help me.
Sep 01, 2011 | Olympus Software VG-120 Digital Camera
Red and blue
convergence amp ic going bad.
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 30, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Cameras Logo
32 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
