Question about Kitchen Ranges
GE OVEN/RANGE JSP28G0P2BG
Sirs:  Oven does not reach operating temperature.  e.g., When setting is 325F, the dial readout is about 70 degrees low.  Adjusting the control +/- 35 does not help.  When oven reaches the set point, the relay shuts off the heating element and indicates that the 325F has been reached, even though the actual temperature is about 250F.  The temperature sensor resistance is 1091 ohms, close to the 1100 ohm specs.  Possibly the oven control itself is bad.  I was not able to locate the part in the shopping list. Can you help?  Do you have any other troubleshooting suggestions?  If not, do you have a part number and place to obtane the oven control:  Oven is:  GE JSP28G0P2BG, SN # VG281454Q.  Thanks,  Dave
  • audiobrad Nov 24, 2007
    Just replaced the sensor on my Kenmore 790.9622 because it would not preheat higher than 350. Unfortunately this did not solve the problem. Despite setting the oven to, say, 425, it only preheats to 350 - almost like it is ignoring my temp setting and defaulting to the 350 initial setting.
2 Suggested Answers
  • 58 Answers
SOURCE: Oven does not maintain temperature. Part 2
sometimes when they get hot that is when they fail
Posted on Oct 31, 2007
GE electric oven won't stay hot
Google GE electric oven Model number: ? Manual
Jan 15, 2018 | GE Ovens
How to Fix Code F3 on GE Oven
Hi
Thanks for using FixYa. Error F3 in your range/oven means oven temperature sensor circuit failure. To resolve this issue you’ll have to check the oven temp. sensor circuit if the reading is more then 1100ohms then it should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 03, 2010 | GE Ovens
My Frigidaire FGFL67DBF gas oven does not reach the temperature set. I tried to calibrating the control, but it did not work. Any suggestions?
I believe that you have a convection oven.... by design, convection ovens built by GE come up to temperature....at 25 degrees below the set level .... when the Convection function is enabled.
Oct 15, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Self Cleaning Gas Range F2 Error, happens at 400 degrees and turns oven off any advice?
Your oven temperature sensor must be replaced. It is located in the oven compartment up high, may be right or left side depending on model. Smaller than a pencil about 3&1/2 inches long.
Jul 25, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Amana Range, AER5515QAW
could be a bad bake element, bad temperature sensor, or control board problem
what does the oven readout display for temperature? if the readout agrees with the actual oven temperature ... it is probably the element
if the oven readout displays a much higher temperature it may be the temperature sensor (the probe in the oven cavity) or the control board
the temperature sensor can be tested by measuring its resistance with power off and unplugged from the control board, should be about 1100 ohms at 75F
If the sensor is good, then it is probably the control board ... in which case we can repair it for you at www.fixyourboard.com
Jul 20, 2009 | Amana AER5515QA Electric Kitchen Range
GE XL44 gas range, oven dial doesn't have "lite"?
Set the oven for the desired temperature. It will cycle on and off at that temperature.
It will lite automatically.
Feb 27, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Kenmore gas oven temp not accurate. Could be high, can be low.
the oven themperature needs to be calibrated, the set screw it's in side of the oven knob when you remove it in the senter of the shaft there is a very small screw, turn it , beon that replace the thermostat.
Dec 06, 2008 | Kitchen Ranges
Sep 18, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Spectra XL Oven does not maintain oven temperature
I have the exact problem. We had the ignitor replaced 2 already and it works for 18 months and stops. Occasionally, it the oven won't even start to heat. I am ready to throw it out.
Sep 14, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra JGBP85WEB5WW Range
It sounds as if you might have a problem with the gas valve for the oven. This is something that I would not reccomend that you try and fix yourself.
Aug 12, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
172 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
