Question about Electrical Supplies
Kubota av5500 my generator runs fine and it wasn't too long ago i used it now i start it and it runs but it doesn't generate
  • 18 Answers
SOURCE: Generator runs, but does not generate electricity
Reset / tickled? There are resistors and diodes in the end of the alternators rotor (the bit in the middle that spins) If these look ok visually then change the capacitor which is a barrel shaped object usually with 4 prongs on the end. Without a capacitor the genset will not produce a voltage.
Posted on Sep 19, 2008
  • 2976 Answers
SOURCE: My generator starts but not give 220 volts power
Check the voltage regulator and any fuses or breakers.
Posted on Jul 02, 2009
jan mczeal
  • 632 Answers
SOURCE: generator starts but does not generate power
  1. Check for any blown fuse and replace. It can be traced directly from the output lines.
  2. Check field excitation. The field excitation is supplied by the battery to the excitation coil through a pair of carbon brushes. If the brushes are worn out, no excitation field is supplied and no output is generated. Replace carbon brush if found worn-out.
  3. Use an analog multitester to check the continuity of the carbon brush and the field coil.
Posted on Sep 25, 2009
  • 251 Answers
SOURCE: Lombardini diesel generator starts and runs fine but no elecpower
remove the covering panel and expose the internals , check for loose/disscontected push on ( lucar ) connectors , if these are fine it is most likely the excitation capacitor is deffective , replace with exactly the same value/voltage rating/duty cycle . the capacitor is usual 1 or up to 3 cylindrical tubes with 2 wires comming from them , always take a note of exactly what wires you have taken off :) hope this helps
Posted on Oct 20, 2009
  • 4 Answers
SOURCE: 5500 generator stopped producing eletric after
First check with the dealer and see if it is still under warranty. If it is not, make sure nothing is blocking the air flow around where the control modules are located. This could cause the voltage regulator and other electronic parts to overheat. Next check the brushes and make sure they are free of any dust or build up preventing them from making contact.
If everything is OK the next thing I would do is change the voltage regulator.
Posted on Nov 25, 2009
Have a Kubota A450-3-120 generator will start but won't run
The main jet in carb is clogged and needs to be cleaned out. It is starting on the fuel used for priming and once that runs out (almost immediately) unit will shut down for lack of fuel delivery.
Jan 15, 2017 | Electrical Supplies
GL 11000 starts & runs fine but puts out 90v. Will occasionally jump to 110v but then returns to 90. Unit is for standby power & has about 1200 hrs.
Phillip, Plug something Big into it (shop heater), to put under load for a half hour, and then check it.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Feb 25, 2016 | Kubota Generator - GL Series - 2-Pole...
Car won't start. it tries to turn over, but just doesn't .battery replaced several months ago so it's not that. The red "GEN" light pops up. Is that the generator signal? Manual doesn&
Interesting. They haven't used generators in over 50 yrs.
But yes that was the warning light for the generator.
If you have a volt meter that would tell you what the system is doing.
If the engine will not crank, and the battery is fully charged, you would need to check the connections at the starter for voltage and ground.
And the red warning lights would normally come on until the engine starts.
Jan 13, 2013 | 1996 Jeep Cherokee Sport
My Makita G5500r power generator doesn't have smooth Idle?
sounds like the carb needs to be cleaned inside any fuel the was left in the carb goes bad and it never runs it all out
Sep 06, 2012 | Electrical Supplies
I need a down loadable manual for my kubota GL11000 diesal generator
Kubota GL11000 and Kubota GL7000 Manual http://www.pacifictoolcompany.com/index.php?main_page=index&cPath=13_127
Sep 30, 2011 | Miller 907068 MILLER TRAILBLAZER PRO 350D...
Not generating power from EF4600DE Yamaha
Way low voltage. How is the rpm?
Aug 07, 2009 | Electrical Supplies
D1105 kubota engine on generator overheating
Can you tell if it's really hot (water temp) ? Could be a bad sensor.
Jun 23, 2009 | Miller 907068 MILLER TRAILBLAZER PRO 350D...
Electrical Supplies Logo
48 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
