Question about Swingline Heavy Duty Stapler 30 160 Sheet Capacity GrayBlue
How to load staples - Swingline Heavy Duty Stapler 30 160 Sheet Capacity GrayBlue
How to load staples
Staples newly purchased will always be attached when purchased and that answers your question...wherever the device u are loading has a horizontal channel, there will be a loading window at the end. Take it apart by realeasing the cap or spring at the bottom and sliding the train of staples into the channel inside. Replace cap or spring lever to original position and secure. Stapler is now loaded.
Dec 12, 2015 | Electric Stanley Tre500 Staple Gun /...
How do i open the stanley tr110 staple gun to load the staples
Angelbabie...Like most things, it's pretty easy if you know how.
1.Release the loading latch located on the back end of the staple gun by pinching it with your thumb in a downward motion. This will release the catch and allow you to pull the loading slide out.
2.Hold the gun upside down (so the staple don't fall out) and place a stick of staples in the bottom of the channel which will be exposed once you pull back the loading slide.
3.Push the slide back in and make sure the latch is engaged. All good to go!
Happy stapling.
Mar 01, 2011 | Powerfast Stanley TR110 Light-Duty Staple...
How do you load staples
A piece comes out of the rear of the staple channel and the staples go in there.It is spring loaded to push staples to the front of the gun.
Oct 09, 2010 | Arrow CHROME STAPLE GUN ARROW IND....
Need help loading staples in my Stanley electric staple/nail gun
there should be a button / lever at the rear press it and it should open so as to insert the staples
Apr 05, 2010 | Stanley Staple/Nail Gun Elec
How do I load the staples in this staple gun?
Push in and down the silver color piece at the end of the gun. Pull piece and spring out. Load staples, end down. Reassemble.
Jul 07, 2009 | Arrow Fastener T27 Light Duty Household...
Can't load staples
Fire the stapler with the load chamber open and down, see if anything falls out. Point it in different positions and fire it, just make sure it cannot fire anything at you.
Apr 18, 2009 | Stanley Tools TRE550 Electric Staple/Brad...
LOAD IT
pull out the spring at the end of the gun. turn the staple gun upside down. Lay the staples in the track pointed side up, push in the spring slide so that it locks. You are ready to staple.
Nov 08, 2008 | Powerfast Stanley TR110 Light-Duty Staple...
Staple gun
Open the chamber and drop the staples upright in to the chamber do not try to load the staples by placing them on the strip that pulls out as you do with most staple guns.
Oct 26, 2008 | Stanley Bostitch Pc2000 Staple Gun Tacker...
Swingline Heavy Duty Stapler 30 160 Sheet Capacity GrayBlue Logo
24 people viewed this question
Top Swingline Office Equipment & Supplies Experts
Paul Bade
Stitch85
Level 1 Expert
Andrew Taylor
Andrew Taylor
Are you a Swingline Office Equipment and Supply Expert? Answer questions, earn points and help others
