NEED JAZZ ADC CONTROL BOARD TECH SHEET - Washing Machines
How do I force defrost cycle? On a M# FRS6R4EB2
If you refrigerator is not defrosting the most likely problem with your model is a defective defrost control 5303918476_Defrost_Control
26006599-0dvjad2l5mbclw2wzdpi5znd-3-0.jpg To initiate the defrost cycle in most Friggidaires (not a typo) with ADC:
To initiate defrost, depress the fresh food light switch 5
times in 6 seconds (light bulb must be working). To terminate
defrost, depress the fresh food light switch 5 times in 6 seconds.If the refrigerator won't go into defrost, verify that you have continuity in the defrost heater and defrost thermostat. If they check out good, but you aren't getting 120vac from the ADC board,replace the ADC board.
If your refrigerator uses a mechanical timer for defrost control, then you still need to check the continuity of the defrost heater and thermostat. If they're both good, replace the defrost timer.
BTW, all the foregoing applies to other brands, too. Even the part link for the mechanical defrost timers can be used for all brands so equipped. The only real difference is in the ADC control and the procedure for initiating defrost. For more about that, see this page.
Link=> HERE
APPLIANCE 911
Dec 13, 2015 | Refrigerators
How to progam main control board on Amana refridgerator
The code instructions are on the tech sheet that is taped to the underside of your refrigerator.
Remove the grill along the front bottom of the refrigerator and look around under the cabinet for the tech sheet. It's usually in a bag or envelope taped to the front right underside of the refrigerator. From there, you just need to follow the instructions.
Oct 22, 2014 | Refrigerators
How to program a new circuit board?
I'll repost my previous answer to you, with some additional info:
Additional info: I found a YouTube video that will help you program the Jazz board on your Amana. Go to about the 6 minute mark and start watching from there:
If you found this useful, be sure to write a testimonial for me.
Elite 4586
see this causes and fix it. God bless you
Door Switch
This can cause the washer to agitate but not go into the spin cycle. You will need to remove the door switch to check it. You will perform an ohm reading on the bottom terminals. The reading varies from manufacturers most Frigidaires is around 1500 ohms others like the whirlpool duet is checked at the main control board with the door closed should be around zero ohms. You will need to refer to the tech sheet or service manual for the proper reading.
Main Control Module / CCU
The main control unit is the circuit board located behind the console. If the door switch tests good the main control is usually the problem. Check all connections for a goood tight fit. You will need to refer to the tech sheet or service manual to check this further. The main control is easy to replace.
Motor Control Module
The motor Control Module is located inside the cabinet down near the motor. This recieves the signals from the main control module then relays this information to the motor. Check all connections sometimes a communcation problem is just a loose connection. The Motor Control Module is easy to replace. To check this further you will need to refer to your tech sheet or service manual.
Oct 11, 2012 | Kenmore Elite 45986 Front Load Washer
I have no power at the control board, no code is showing. Has 120V at the unit.
see this and replace if necessary. God bless you
Sep 27, 2012 | Samsung SM-DMR77LHS - SERVICE MANUAL
Looking for keypad combo to reset control board
the tech sheet for my refrigerator was found under the plastic cover over the top hinge. my model # is kbrs22kwms5
Mar 03, 2012 | KitchenAid KBFA20ER Bottom Freezer French...
Maytag side by side defrost problem. I am a tech with a maytag side by side that recently had the recall work done on the compresor relay and now the customer says ref. side is not cooling. Are these...
The ADC has failed and or the defrost thermostat has failed. It has a cal rod heater. They usually do not fail, but check continuity on it anyway. The ADC is in the control panel on the back right corner.
Jun 07, 2009 | Maytag MZD2766GES Side by Side...
Maytag PBF 2255 HEW refrigerator JAZZ board replacement issue
thats different I was thinking of something else the board you are talking about just controls the temp. controls this may be your problem call1-800-688-9900 maytag or 1-800-253-1301 whirlpool they can give you a better idea on the part number issue this may be the problem
Jan 10, 2009 | Maytag Refrigerators
My admiral fridge freezer suddenly stopped working -
I took the time to look up your Model # and you do have the right board. Jazz 14 Should just be a revision one higher than your origional. Describe to me exactly what happens when you try to program it. You may be missing one little step. Make sure you are doing every step exactly right. I too can miss one little confirmation stroke and it seems like it wont work. I Can email you the tech sheet for your model. This will show you how to test all the sensors, and the damper to determine why the FF side is getting too cold. I will also help on my end as much as i can
Nov 25, 2007 | Frigidaire FRS26R4C Side by Side...
Kenmore 596.75509400 bottom freezer
JH, did you notice if the freezer back panel was full of frost first time it started thawing? If so you may have a defrost problem. I've had 4 of these control boards (jazz boards) fail on this model in the last week. Behind the front grill, there should be a tech sheet that will show you how to run the componet tests at the control board. Part number for the board is 12002339. This board controls compressor, defrost, damper and fans. Catriver.
Aug 04, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Washing Machines Logo
104 people viewed this question
Top Washing Machines Experts
