Question about Metra 80-5511 1999 - 2000 FORD ESCORT ZX2 S/R Car Audio Radio Wire Harness
Shifter stuck in park
Starts but will not shift out of park
2001 pathfinder shifter is stuck in park. When I step on the brake it won't release the shifter. Would the problem be the shift lock relay?
Scott, Yes it could be the relay/solenoid faulty or weak. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
how to get out of stuck in park in pathfinder
Shift Lock Problem Phatfinder 2001
2001 pathfinder shift lock solenoid Google Search
Jun 04, 2016 | 2001 Nissan Pathfinder
HOW TO UNLOCK YOUR FORD TAURUS GEAR SHIFT
Search Results
    Ford Focus Questions - the car starts up but i cant get it out ...
    www.cargurus.com > Questions > Ford > Focus
    CarGurusJan 26, 2013 - the car starts up but i cant get it out of park the button on the shifterwont ... point the shift interlock will allow you to shift to neutral and other gears with ...That should expose your shift lock over ride button. .... Used Ford Taurus".
    97 Ford Taurus gear shift stuck in park - Car Talk
    community.cartalk.com/.../97-ford-taurus-gear-shift-stuck-in-park
    Feb 7, 2009 - Over the past week, it has been difficult to get the gear out of park. ... 97Ford Taurus gear shift stuck in park ... LOCK, then remove the key. 2.
    Why Wont My Car Shift Out of Park - Shifter Interlock ...
    ? 3:49
    https://www.youtube.com/watch?v=ZdDsfNrabsM
    Mar 21, 2014 - Uploaded by BleepinJeep
    Only problem is if it fails, you cant get your car out of park. ...Those interlocks seem like they might be a solenoid that slides alock pin out so that you can move the lever freely. .... Someone told me it was possibly the Passing gear cable ? ... Ford TaurusWon't Shift Out Of Park, Brake Lights Don't Work With ...
    Car stuck in Park, shifter won't move. - DoItYourself.com ...
Jan 18, 2016 | Ford Cars & Trucks
My 2007 toyota yaris shift lever is stuck on park, what could be the problem?
Shifter stuck in the Park position - YouTube
? 3:17
www.youtube.com/watch?v=-myhP6tRv4U
Jan 2, 2012 - Uploaded by iworkforbudlight
Short video on how to get your shifter out of park when it's stuck. This is for ... I'm assuming that's a Toyota ...
Shifting lever stuck in park - 2004 Toyota Camry - RepairPal
repairpal.com > Questions > Toyota > Camry > 2004 Toyota Camry
Aug 21, 2014 - my shifter got stuck in park,I read the book and read to take the little cover off by the shifter and push the botton to release the shifter. it worked fine ...Shifting lever stuck in park on 2004 Toyota Camry .... 2007 Toyota Camry ...Missing: yaris
Nov 05, 2015 | Toyota Cars & Trucks
The shifter will not move it looks like it is in park but it is not
The linkage is probably off have a friend come and check the cable on side of Trans and the middle of floorboard if ok then replace shifter assrmbly
Feb 16, 2014 | Cars & Trucks
Gear shifter stuck in park and car will not start
The can can't run. Why need to shift...?
If you want to shift anyway. Be careful if down or up hill the car will roll.
Here if need to shift away:
-Put key in ignition, turn to start, but do not start.
Now apply brake then shift.
Mai Lor
Feb 28, 2013 | Infiniti QX4 Cars & Trucks
Toyota Tercel stuck in gear
Its a gear shift issue.
The shifter needs to be inspected. The shifter assembly is got misaligned, it has to be open and realign.
There are many other possibilities. But if it was working right up till now and suddenly this occurred then its shifter assembly alignment issue.
Also i suggest you to refer these gear shift issues, which are mostly noticed. These are direct links with appropriate solutions to the specific problems of gear ****.
GEAR SHIFT ISSUES
Gear indicator Shows "3" Instead Of "D"?
http://whoisbyme.blogspot.in/2012/07/gear-indicator-shows-3-instead-of-d.html
2006 Chrysler 300c: Shifter Stuck in Park?
http://technoanswers.blogspot.in/2012/06/2006-chrysler-300c-shifter-stuck-in.html
1998 Ford Expedition: Will not Shift Out of Park?
http://schematicsdiagram.blogspot.in/2012/06/1998-ford-expedition-will-not-shift-out.html
Car will not move when in gear?
http://repairhelpcenter.blogspot.in/2012/02/car-will-not-move-when-in-gear.html
Mercedes-Benz transmission sticks in first gear?
http://technoanswers.blogspot.com/2012/01/mercedes-benz-transmission-sticks-in.html
Mercedes Benz not engaging in first gear?
http://technoanswers.blogspot.com/2012/01/mercedes-benz-not-engaging-in-first.html
Chrysler PT Cruiser only goes in First gear?
http://howtobyme.blogspot.com/2011/11/chrysler-pt-cruiser-only-goes-in-first.html
Car is stuck in park and the shift will not move?
http://howtobyme.blogspot.com/2011/08/car-is-stuck-in-park-and-shift-will-not.html
2007 Ford Expedition: How to shift car in neutral with Dead Battery
http://www.howtorepairguide.com/2012/11/2007-ford-expedition-how-to-shift-car.html
2002 Nissan sentra will not go out of park mode?
http://technoanswers.blogspot.in/2012/02/2002-nissan-sentra-will-not-go-out-of.html
Nissan Sentra stuck in park?
http://technoanswers.blogspot.in/2012/02/nissan-sentra-stuck-in-park.html
Car will not come out of Park?
http://howtobyme.blogspot.com/2011/11/car-will-not-come-out-of-park.html
Automatic transmission will not go into high gear?
http://howtobyme.blogspot.com/2011/11/automatic-transmission-will-not-go-into.html
Car won't downshift sometimes?
http://schematicsdiagram.blogspot.com/2011/12/car-wont-downshift-sometimes.html
Buick Park Avenue: Transmission will Not shift into drive?
http://schematicsdiagram.blogspot.com/2011/12/buick-park-avenuetransmission-will.html
No First gear Starts In Second Gear
http://www.howtobyme.blogspot.com/2012/07/no-first-gear-starts-in-second-gear.html
Ford Taurus won't shift from park?
http://schematicsdiagram.blogspot.com/2011/12/ford-taurus-wont-shift-from-park.html
2006 Ford F150: Will Not Shift out Of Park?
http://technoanswers.blogspot.in/2012/06/2006-ford-f150-will-not-shift-out-of.html
Car Transmission will not go into Park mode?
http://schematicsdiagram.blogspot.com/2011/12/car-transmission-will-no-go-into-park.html
1998 Chrysler Voyager: Transmission Problem?
http://howtobyme.blogspot.in/2012/06/1998-chrysler-voyager-transmission.html
Shift indicator directly goes to 2nd when key is turned ON?
http://schematicsdiagram.blogspot.com/2011/12/shift-indicator-directly-goes-to-2nd.html
Third gear missing and engine losing power?
http://schematicsdiagram.blogspot.com/2012/01/third-gear-missing-and-engine-losing.html
Chevrolet silverado has whining sound in gear?
http://technoanswers.blogspot.com/2012/01/chevrolet-silverado-has-whining-sound.html
2002 Chevrolet Avalanche Z71: Gear shift Issue?
http://whoisbyme.blogspot.in/2012/06/2002-chevrolet-avalanche-z71-gear-shift.html
Hard to shift gears on Manual transmission?
http://technoanswers.blogspot.com/2012/01/hard-to-shift-gears-on-manual.html
Car hard shift at slow speeds?
http://technoanswers.blogspot.com/2012/01/car-hard-shift-at-slow-speeds.html
Transmission-Hard To Down Shift
http://technoanswers.blogspot.in/2012/07/transmission-hard-to-down-shift.html
Automatic transmission shift lever hard to move on cold mornings?
http://technoanswers.blogspot.com/2012/01/automatic-transmission-shift-lever-hard.html
2000 Nissan maxima shifts hard?
http://schematicsdiagram.blogspot.in/2012/02/2000-nissan-maxima-shifts-hard.html
Vehicle noticed sluggish delayed shifts while driving?
http://schematicsdiagram.blogspot.in/2012/03/vehicle-noticed-sluggish-delayed-shifts.html
2007 Hyundai Santa Fe: Will not Shift out of Park Mode?
http://schematicsdiagram.blogspot.in/2012/06/2007-hyundai-santa-fe-will-not-shift.html
These details will help.
Thanks.
Nov 28, 2012 | 1993 Toyota Tercel
My 2008 Chevy impala will not come out of park
The
shifter needs to be inspected. Its quite possible that The
There
suddenly this shifting problem occurred then its shifter
Also
the specific problems of gear shift
GEAR SHIFT ISSUES
Gear
Park?
gear?
Car won\'t downshift sometimes?
No
Ford Taurus won\'t shift from park?
is turned ON?
Issue?
mornings?
driving?
Park Mode?
Thanks.
Nov 26, 2012 | Cars & Trucks
2010 dodge grand caravan stuck in park with engine on
Check your brake lights, if the system doesn't get a brake lights on signal it will not release park, it is called the park lock system.
Nov 01, 2012 | 2010 Dodge Grand Caravan
Shifter on 95 buick riviera stuck in park
There is a "park lock cable" located in the steering column that releases the shifter after the ignition switch is turned to the on position. There is also a BTSI (brake trans shift interlock) solenoid that also releases the shifter when you press on the brake pedal. One of them is not functioning, are you able to turn the steering wheel after the car is started?
Nov 25, 2011 | 1995 Buick Riviera
When I start engine and depress brake pedal and go to move shift lever I can't depress shift lever button to move out of park. This will happen 6 times out 10.
2002 chevy trailblazer on neutral mode, trailblazer can be pushed easily,but shifter is stuck on park. vehicle will start.the push button on shifter will not engage
Sep 09, 2010 | 2002 Chevrolet TrailBlazer
Metra 80-5511 1999 - 2000 FORD ESCORT ZX2 S/R Car Audio Radio Wire Harness Logo
12 people viewed this question
Top Metra Car Audio & Video Experts
xxxxxx xxx
Are you a Metra Car Audio and Video Expert? Answer questions, earn points and help others
