Question about Polaroid P3000E Single-Sided ID Card Printer
I can't delete a print job from Polaroid P3000E card printer.
I tried to print a sample card when the card was not created in the card maker software. I now have a document in the print queue that I can't delete. I have tried powere own, unplug, turn off, and nothing will remove the print job.
I have try to delete a printing job and it will not print and will not allow anything to be print. However, I was able to delete the other jobs after the first job but the first job willnot delete
Sometimes if the printer cable is unplugged it will reset. Try that. Also the printer menu should include cancel print jobs. Is that cleared? I would also turn off computer for a moment, and turn back on. Thqat may clear the print job.....
Apr 19, 2014 | HP Photosmart C4100
Error 49.23F9
. Press CANCEL JOB to clear the print job from the printer memory. 2. Turn the printer off, and then turn the printer on. You can try reprinting the job to see if it was a temporary error. 3. If error persists, try printing a job from a different software application. If the alternate job prints, go back to the first application and try printing a different file. (If the message only appears with a certain software application or certainprint job, try upgrading the printer driver and / or firmware.) 4. If the message persists with different software applications and print jobs, disconnect all cables to the printer that connect it to the network or printer. Turn the printer off and delete the print queue. Then reboot printer AND computer, reconnect cables, and try printing again. 6. Remove all EIO devices from the printer (JetDirect cards, hard drives, etc.). If 49 error goes away, turn printer off, re-install EIO devices one at a time, and reboot printer each time to determine which EIO device is failing. 7. If printing still fails with all EIO devices removed, remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM-- printer won't function without this installed.) Turn the printer on with DIMMS missing. If the error no longer exists, install each DIMM one at a time, turn printer on, test printer. Replace a DIMM if you determine that it causes the error. 8. Remember to reconnect all cables that connect the printer to the network or computer. 9. If the error persists, replace the firmware DIMM. 10. If error persists, replace the formatter.
Mar 19, 2014 | HP CP3525N Color LaserJet Printer
Laserjet 2605 49 error
Error 49 is a firmware error. Try following these steps:
1. Press CANCEL JOB to clear the print job from the printer memory. 2. Turn the printer off, and then turn the printer on. You can try reprinting the job to see if it was a temporary error. 3. If error persists, try printing a job from a different software application. If the alternate job prints, go back to the first application and try printing a different file. (If the message only appears with a certain software application or certainprint job, try upgrading the printer driver and / or firmware.) 4. If the message persists with different software applications and print jobs, disconnect all cables to the printer that connect it to the network or printer. Turn the printer off and delete the print queue. Then reboot printer AND computer, reconnect cables, and try printing again. 6. Remove all EIO devices from the printer (JetDirect cards, hard drives, etc.). If 49 error goes away, turn printer off, re-install EIO devices one at a time, and reboot printer each time to determine which EIO device is failing. 7. If printing still fails with all EIO devices removed, remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM-- printer won't function without this installed.) Turn the printer on with DIMMS missing. If the error no longer exists, install each DIMM one at a time, turn printer on, test printer. Replace a DIMM if you determine that it causes the error. 8. Remember to reconnect all cables that connect the printer to the network or computer. 9. If the error persists, replace the firmware DIMM. 10. If error persists, replace the formatter.
Mar 10, 2014 | HP LaserJet 2605dn Printer
How solve error 49 on 4730mfp
it's a long one !
Dec 18, 2012 | HP LaserJet 4730mfp All-In-One Printer
Only prints first job - can't delete from que
Please try this approach instead:
1. Browse to Start -> Run... and type in NET STOP SPOOLER (this will stop the print spooler service)
2. Browse to your windows\system32\spool\PRINTERS\ folder. You should see files there ending in .SPL and .SHD created around the time you tried to print - delete these files.
3. Browse to Start -> Run... and type in NET START SPOOLER (this will restart the print spooler service)
4. Double click the printer icon in the lower-right corner of your taskbar to examine your print job queue and browse to View -> Refresh.
I hope this information has been helpful.
Dec 20, 2011 | Lexmark X6170 All-In-One InkJet Printer
PRINTER WILL NOT PRINT THERE IS A JOB THAT WON'T CLEAR. I TRIED DELETING THE JOB AND ALL IT SHOWS IS THE JOB DELETING AND THATS WHERE IT'S STUCK
To clear the print queue from stuck print jobs, try this approach instead:
Oct 02, 2011 | Lexmark X2500 All-In-One Printer
I'm trying to delete a print job and the job will not delete. I can not uninstall the printer software and reinstall it because the job is still trying to delete and un pluging it didnt work either. I...
Try turning off BOTH the printer and computer and unplugging the printer from the PC. Reboot PC and printer, then plug the printer to the PC. This should delete any remaining print jobs.
Jan 14, 2011 | Lexmark X2650 All-In-One InkJet Printer
Trying to record directly in with voice and seems to record the exisiting sample track delayed behind aswell as the vocals
What software are you using to record on. Some have sound on sound settings which must be changed to overwrite. Also try deleting sample track or creating a new project or file. If you can give more details I might can help you.
Oct 06, 2009 | Acer (54.AA806.001) Sound Card
Datacard SP25 only printing half of ID Card
it sounds like a driver error try to reinstall the software
Jul 08, 2009 | Datacard SP25 Printer
Operating software
You can get Polaroid ID Card Maker and you can design your own cards, etc. Works great with the FARGO printers.
Feb 27, 2009 | Fargo DTC525 ID Card Printer
Polaroid P3000E Single-Sided ID Card Printer Logo
65 people viewed this question
Top Polaroid Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Jerry Umali
Are you a Polaroid Office Equipment and Supply Expert? Answer questions, earn points and help others
