Question about Axis Communications O2 Oxygen Sensor 0808 Harley Softail Rocker Lambda (015000101
Check engine like is on
Can you change the wire on an 02 sensor or 2001 ford expedition 5.4 engine
  • 1,358 Answers
Most of the o2 sensors are cheap on domestic cars and trucks, I did one on a honda while back and the sensor was 5 hundred bucks. most usa cars are about 20 to 100 bucks. just ask the guy at your local auto parts store on how to fix it.and what tools are needed. most of these are easy fixes.. good luck .. Jay
Posted on Feb 08, 2014
Where is the fuel regulator on a2006 ford expedition
    images for Where is the fuel regulator on a2006 ford ...
    More images for Where is the fuel regulator on a2006 ford expedition
    How to Remove Install Fuel Pressure Regulator - YouTube
    ? 5:47
    https://www.youtube.com/watch?v=rg7ftqJyQUg
    Oct 7, 2013 - Uploaded by MattHumanPizza
    A check of the fuel pressure regulator, as well as the removal and installation process is ... Yeah the regulators are sht on the 98/02 2.0 ford motor. .... Replacing a Fuel Pressure Regulator ona 2001 Chevy Silverado 1500 (5.3L) ... 2005 Ford explorer 4.0 V-6 engine Fuel Rail Pressure Sensor removal ...
Dec 15, 2015 | 2006 Ford Expedition
1999 Ford Expedition
99 and 02 have different motor 5.4-4.6 some early model have the same size engine check 02 for its size and 99 if they are the same you will only have to change the platinum..
Apr 15, 2014 | Ford Expedition Cars & Trucks
Replace all four oxgen seners on my ford expedition and even clear the codes 1151 and po155 with code scanner but still comes back on 5.4 4x4
You could have dirty injectors, a vacuum leak, faulty MAF sensor and/or a clogged catalytic converter. Most likely your 02 sensors were fine and didn't need to be replaced. Just because you have an sensor fault code does not mean the sensor is bad, in fact the majority of the time it's working just fine.
Jul 22, 2011 | 2001 Ford Expedition
Location of heated oxygen sensor - bank 2 sensor 1 on a 2001 ford expedition eddie bauer
You will be told that it is passenger side 02 sensor before the cat,, but it is not .. Drivers side right after the manifold is the one you are after.
Jul 31, 2010 | 2001 Ford Expedition
My 2002 Ford Expedition shakes when put in drive. In park it does not shake. What would cause this, spark plug wires, plugs, fuel filter?
Spark plugs and wires,
Bad or leaky vacuum line
Bad 02 sensors, (check engine light would likely be on)
If it doesn't do it at idle, then motors mounts should be good and the problem is one of the listed above.
Jul 22, 2010 | 2002 Ford Expedition
Check engine ligh on and then starts flashing
You are having a catastrophic misfire that will destroy the catalytic converter unless repaired soon. You may need a tune up or a 02 sensor repaiered but you will need scan tools to test what codes is being thrown.
Jun 24, 2010 | 2000 Ford Expedition
Reset ems (check engine light) on ford expedition
Try to remove positive baterry terminal for 20 minutes and install it nack. That will reset your ECU and it will run little rought tilll learn new change in 02 sensor.
Feb 19, 2010 | 2000 Ford Expedition
2001 Ford Expedition - starts, won't shift out of park, windows n
Check the #15 fuse in fusebox behind marked panel on left lower dash just below and left of steering column. This is only a 5 amp fuse but it controls a lot. This fixed our 2001 Expedition. 25 cents.
Dec 16, 2009 | 2001 Ford Expedition
Axis Communications O2 Oxygen Sensor 0808 Harley Softail Rocker Lambda (015000101 Logo
47 people viewed this question
Top Axis Communications Computers & Internet Experts
David Payne
David Payne
Are you an Axis Communications Computer and Internet Expert? Answer questions, earn points and help others
