Optoma EP739 Multimedia Projector Logo
A
Anonymous Posted on Feb 07, 2014
Optima projector showing no signal - Optoma EP739 Multimedia Projector
I have an optima pro 1505 projector. No remote. It keeps asking for unlock code .how do I bypass or reset. again. W,O. REMOTE
To bypass or reset the unlock code on your Optima Pro 1505 projector without a remote, you may try the following steps:
  1. Turn on the projector and wait for the "Enter Password" prompt to appear.
  2. Press the "Menu" button on the projector itself.
  3. Navigate to the "Setup" or "Options" menu using the arrow buttons on the projector.
  4. Look for an option called "Security" or "Password" and select it.
  5. Depending on your projector model, you may need to enter a default password such as "1234" or "0000" to access the security settings.
  6. Once you are in the security settings, look for an option to disable or reset the password.
  7. Follow the on-screen instructions to disable or reset the password.
If none of these steps work, you may need to contact Optima customer support for further assistance.
1helpful
2answers
No picture
Hi, Possibly either of 2 reasons: 1. Your player is not sending any signal to the Optima meaning it is the one in question and not the projector; or 2. Your Optima lost its input signal, go through the signal source selection menu, try manual selection & set it to where your source/player is connected. Hope this works out for you, if not pls post again . Good luck and kind regards.
How do I get the image on my computer to show up on my projector. the projector is an Optima EP727
If you're using a laptop then look for the key that sends the image to the projector. Usually you have to connect the cable between the computer and laptop with both units powered down. That way when the PC boots it will see the projector is connected.
I have optima hd71- ceiling mount hooked to hdmi sattelit tv-and samsung home theatre - hd channels give me full screen- normal channels with 16:9 does not - have 2 vertical grey bars -tried all adjus
You're projector is most likely fine. Check your satellite box. Go to the menu and see how its set to display video. It may be trying to up-convert TV signals. Try different adjustments from there to see if you see any change.
Home cinema projector (panasonic) and blue ray player only show half an image
To me itcsounds like ypu have a 1080p signal, 1080i is what it accepts. The 1080p signal will only show up on half the screen. Switch blue ray player to 720p or 1080i output.
Optima Optima hd81 projector mounted on ceiling now picture is upside down
There is an option in the setup menus to re-orientate the picture, to flip it either vertically, horizontally or both to correct for the various installation options. You should be able to correct it quite easily :o)
3helpful
2answers
Optima EP719 won't power on - when power button
check that the lamp is on securly and that the cover is on securly too.
Hi! where can i purchase a 12 volt trigger cable for a motorized screen
Most projectors have a 1/8 inch (mono) or tip and sleeve female connector for screen trigger and output 12volts dc when the projector is powered up. So if the Optima screen has the optional trig in and it's 12 volts the cable is very easy to put together. Optima may have a cable available or you could spend just a few bucks at Radio Shack and your all set.
It shows no signal
Toshiba TDP-S8 projector cannot communicate from my laptop, it shows no signal. how can i fix it? thank you so much...
Top Optoma Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
john h
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
