Question about Pantech flex p8010 at&t unlocked gsm phone
How do i block numbers on my at&t pantechflex?
I have an n13134 phone, is it possible to block a number ringing my phone ?
You're best bet is to always use the method provided by your carrier service. Per example- I have Verizon: My Verizon > My Plan & Services > Family Safeguards & Controls. My Plan & Services is located at the top of the page. Click View Details & Edit (located on the right in the Usage Controls section). Click Manage Blocked Contacts (located in theBlocked Contacts Summary section) to view blocked numbers. -- This is provided from their website.
----**This will prevent phone calls and voicemail from reaching you!
Oct 24, 2017 | Cell Phones
Chevy engine block identification numbers V0710FSC TEJ528846
Small Block Chevy Engine Block casting and code identification
www.nastyz28.com/sbchevy/sblock.html
Sep 14, 2012 - Small Block Chevy engine identification. Code identification, Casting Number info.
Chevy Casting Number identification - Block casting numbers
outintheshop.com/faq/casting/castings2.html Chevy Casting Number identification including Block casting numbers, cylinder ... 2-bolt Chevy II Nova Recessed filter .... 2 & 4-Bolt Mexico cast Crate engine.
Reference: Chevy Engine Block Casting Numbers - Chevy ********
www.chevyhardcore.com/news/reference-chevy-engine-block-casting-numbers/ Sep 19, 2013 - The engine block casting number for both BBC and SBC engines is found at the back of the block where the transmission mounts to the engine.
Chevy Identification Numbers - 73-87.com
www.73-87.com/chevy_ids/sbcid2.htm If you have a small block Chevy engine, and need to identify any parts you have laying around, or maybe the engine that is in your truck, I think you will find the ...
Chevrolet - Browse - Casting Numbers .info: engine blocks, heads ...
www.castingnumbers.info/site/browse/m/chevrolet 12562932, Category: Cylinder Heads Type: Big Block V8 Date: 1991-1995. Notes: oval port, open chamber, Gen.V, truck crate motor, 118cc chambers gm chevy ...
http://outintheshop.com/faq/casting/castings2.html
Jul 04, 2017 | Cars & Trucks
Got a motor don't know if its a 327 or 283 numbers GM 35 39700010 stamped on block tag # 639653 (1342)
Chevy Block Casting Numbers. Use these casting numbers to identify the block you have. ... 283. car & Truck 2-bolt. 3790721. 64-67. 327. 2-bolt Chevy II Nova Recessed filter. 3791362. 66-67. 327 ...... Vortec Truck L-35. 12554290. 350. 94-96.
Sep 25, 2015 | Cars & Trucks
Pantech flexp8010 wont power on
time to replace the battery perhaps
Sep 15, 2017 | Cell Phones
Hi, I have a nokia E71 and i want to block calls from a particular country code. Can call barring feature help me in blocking those numbers from calling me?
that will not help you to avoid calls from particular Number for that you should call your service provider they will charge you per month some amount & they will block that particular number which you give them.
Regards,
Harish
// Feel free to vote this answer with 4 thumbs up &
Testimonials //
Jul 17, 2011 | Nokia E71 Smartphone
Sir,\r\n my aircel sim is blocked & ask for the
You can get the puk code from aircel customer ....So just try to call toll free no...
Jun 25, 2011 | Nokia 1616 Cell Phone
No manual and am receiving unwanted calls at night just became threatening how do i block them
Using Call Block
If you subscribe to Caller ID, you can save phone numbers to the call block list. When a call comes in, the phone compares the received phone number to the numbers on the call block list. If the phone number is on the list, the phone replaces the caller's name with Call Blocked and disconnects the call. (The caller hears a reject tone.)
The call block list holds 20 entries, and all stations share the same list. You can add entries through the Call Blocking menu, by selecting Add Call Block in the CID menu, or by blocking incoming calls. (Only one station can edit the call block list at a time.)
Blocking incoming calls
  1. When the phone rings, wait until the display shows the Caller ID information (usually after the second ring).
  2. If you want to block the call and add this number to the call block list, press Block.
  3. When the phone asks you to confirm, press Menu/select or Block. Blocking an incoming call from an "Unknown" or "Private" number is the same as selecting Unknown Number or Private Number from the Call Blocking menu.
Call Blocking menu options
  1. With the phone in standby, open the menu and select Call Blocking.
  2. Choose one of these options:
  • Create New(Handset only) - Add an entry to your call block list. The phone will prompt you to enter a name & phone number.
  • Private Number(Handset only) - Block all calls from numbers reported by CID as "Private." (This does not count as one of the 20 entries.)
  • Unknown Number(Handset only) - Block all calls from numbers reported by CID as "Unknown". (This does not count as one of the 20 entries.)
Call block entry options
  1. With the phone in standby, open the call block list and find the entry you want.
  2. Press Menu/select to open the individual entry menu. Choose one of these options:
  • Edit(Handset only) - Edit this entry. The phone will prompt you to edit the name & phone number.
  • Delete - Erase this entry from the list & allow calls from this number.
Mar 20, 2011 | Uniden DECT21883 Trio Cordless Phone
How do i block messages and calls from a certain number??
Thanks for posting on fixya and we are pleased to help you at the earliest.
You can either call up the service provider of your SIM card and block the number or you can reject call with the following simple steps. To reject calls from certain numbers automatically, use the auto rejection. To activate the auto rejection and set up the reject list, 1. In Menu mode, select Settings ? Application settings ? Call ? All calls ? Auto reject. 2. Scroll left or right to On. 3. Select Reject list. 4. Press ? Add ? New. 5. Enter a number to reject and press . 6. Repeat steps 4-5 to add more numbers. 7. Select the check boxes next to the numbers. 8. Press ? Save. 9. Press .
Hope it helps you. Great time. I appreciate your valuable feedback.
Nov 03, 2010 | Samsung B3310 Cell Phone
Can i block a incoming call & incoming messages from a particular number in NOKIA 5130xpressmusic????? plz mail me kadkol.preeti@gmail.com
Hello sir,. can i block some incoming calls & msgs ; from some unknown numbers in NOKIA 5130xpressmusic????? plz mail me kasiram1988@gmail.com With Thanx & regards,. SKT.KaSi Ram
Oct 26, 2010 | Computers & Internet
Kx-TGA641T how does one unblock blocked number
http://ww2.justanswer.com/uploads/MCVGreg/2009-09-21_023145_KXTG9331-Remove-Blocked.pdf
Viewing/editing/erasing block call
numbers
1 {MENU} -> {#}{2}{1}{7}
2 {V}/{^}: Select the desired item.
~To exit, press {OFF}.
3 Proceed with the desired operation.
■ Erasing a number from blocked list:
{Erase} -> {Yes} -> {OFF}
you can also edit:
■ Editing a number:
{Edit} -> Edit the phone
number. -> {Save} ->{OFF}
Sep 28, 2009 | Panasonic Lands Phones
Pantech flex p8010 at&t unlocked gsm phone Logo
Top Pantech Cell Phones Experts
Computer Repairing
Computer Repairing
Jax Planet
Jax Planet
Abdul Mannan
Abdul Mannan
Are you a Pantech Cell Phone Expert? Answer questions, earn points and help others
