Question about Efergy Energy Monitors Efergy Engage Hub Kit
Efergy engage hub do not connect to internet, confirmed internet is working. network light at bak is blinking. at top it is a power, signal, and network light. power has light but not the other two. router is a linksys smart router
I have the same issue as well (in New Zealand, using Orcon ISP-supplied hub). Have replaced hub, cable, changed port, etc with no luck. Online information indicated that it might be required to use a CROSSOVER CABLE for the Ethernet, but this did not solve the problem. Have phoned and emailed tech support with no response.
I've checked the DHCP and there is no IP address being requested by the hub. I have no outbound firewall on the router, no MAC filter defined for the DHCP, and other devices can DHCP and access the Internet fine.
Posted on Mar 30, 2015
  • Steve Shipway
    Steve Shipway Mar 30, 2015
    I plugged the device into a separate ethernet hub, which was then chained to the router. And it worked. I suspect there is an issue with the Ethernet autonegotiation in the Efergy hub?
Did you ever get a response as I have the same issue?
Posted on Feb 12, 2015
  • Mikkel Aronsen
    Mikkel Aronsen Feb 12, 2015
    Turns out my unit was in development mode, Called efergy customer service, they did a check and fixed it :)
Installed, great signal, won't stay connected, blinks on and off
Try reinstalling the drivers. Get an external powered usb hub and plug the adapter in to the hub. Get a cable to move the adapter away from your computer. Turn off all phones near your network adapter. RNX N1MAC
Jan 24, 2014 | Rosewill Wireless Adapter RNX-N1MAC IEEE...
Hi I have a RangeMax - and it has always been working fine. Last week I couldn't connect wirelessly, so I reset. Nothing. Now I've tried connecting wired through the hub - still nothing. The power is...
Can you please check the signal strength of the wireless router.
If you can log into the wireless router management page and check for the erros if any inside the logs.
Oct 30, 2010 | NetGear RangeMax WPN824 Router
My motorola SURFboard SB5101 has a on power light, a blinking recieve light, and an on PC/Activity light, with the other lights off. what is wrong with it?
The light pattern you have described indicates that the modem can not establish a connection to your internet service provider (ISP). This is typically do to a signal related issue. To trouble shoot the problem you will need to connect the modem directly to the main cable line where it first enters into the home. You will know when the modem establishes a connection by the top 4 lights becoming green. If at any point all 4 top green lights start to blink in sequence than you will need to contact your internet service provider to "unwall the modem". Remember most internet service providers require you to register your modem on there network. So if you have not all ready completed that process you will most likely not have access.
I hope that information above has helped is some way.
If possible please rate this solution.
Sep 01, 2010 | Arris SURFboard SB5101 Cable Modem
My motorola SB5101 cable modem is connected properly. The power light is green but the receive light is keep on blinking other lights was turn off (send, etc.). Does my modem has a problem?
This light pattern indacates that the modem can not establish a connection to your internet service provider (ISP). This is typically do to a signal related issue. To trouble shoot the problem you will need to connect the modem directly to the main cable line where it first enters into the home. You will know when the modem establishes a connection by the top 4 lights becoming solid green. If at any point all 4 top green lights start to blink in sequence than you will need to contact your internet service provider to "unwall the modem". Remember most internet service providers require you to register new modems on there network. So if you have not all ready completed that process you will most likely not have access. If you can not get a connection from the main line than there is a issue with either the modem or the signal coming into the home and you will need to contact your internet service provider.
Aug 29, 2010 | Arris SURFboard® SB5101 Cable Modem
Laptop shows good connection, but cannot connect.
May I recommend you download Network Magic (a Cisco Product - same as Linksys) and l.et NM run its routine on your connection. Google it.
Free top download and use for eval period. read the deal at the web site
I use the paid pro version and I love it.
Oct 22, 2009 | Linksys Wireless-G WRT54G Router
Don't have internet connection
This particular 8-port Ethernet switch/hub has auto-negotiation on both speed as well as MDI, MDI-X.  Therefore, the problem is not with your switch/hub, it's probably with the particular port that you're connecting it to on your Router.  Make sure that it's the LAN side, not the WAN side.
Mar 14, 2009 | Cnet CSH-800 8-Port Ethernet Switch
Connects to home hub but not internet?
belkin adapter has a signal says its on but wont connect to the internet helpppp
Oct 02, 2008 | Belkin (F5D7050) 802.11a/g/b Wireless...
Connecting campus wide networking to hub
Check the following:
Hardware First: Is Vista confirming LAN connection onn that PC, or is it showing disconnected cable?
Is the connection properties showing at least 100Mbps?
Are the RJ45 terminals okay?
Is the driver for the network card recognized by Vista and loaded?
If that is fine, then check the following in the network properties:
1. The IP address you are using
2. The gateway address: it must be the same as the gateway address in the other PCs accessing internet. Run and check
3. The Subnet mask. Use 255.255.255.0
4. HAve you Setup the Nework using the Setup Wizard, including Access INTERNET THROUGH A HUB THROUGH ANOTHER COMPUTER ON MY NETWORK?
Check those things and let us know. Ask for help from your network administrator about correct IP addresses on that LAN
Feb 26, 2008 | Compex MicroHub TP1008C Networking Hub
Dell Powerconnect 2016 All leds are on, solid no blinking.
Had same problem with my Dell Pwoerconnect 2016, power it on and all LEDs light up but nothing works.
The problem was traced to one or both output capacitors ( 10v 680uf ) on the ( tiny ) power supply.
Capacitor symptoms include bulging or rounded tops instead of flat like new one and the rubber plug in base of capacitor protruding.
Capacitors need to be replaced.
I have successfully replaced with 10v 1000uf and 10v 1200uf, both Rubycon and Sanyo brands.
Power to the switch board is now restored and the switch is able to function just fine.
Give it a go and see if it works for your Powerconnect.
BigAl
Jan 24, 2008 | Dell PowerConnect 2016 (pct2016)...
Efergy Energy Monitors Efergy Engage Hub Kit Logo
1,677 people viewed this question
Top Efergy Energy Monitors Cycling Experts
John Egan
John Egan
Are you an Efergy Energy Monitors Cycling Expert? Answer questions, earn points and help others
