Question about Panasonic KX-TG5771 Cordless Phone
Base station working deregister non-working handsets
Noggin
  • 944 Answers
SOURCE: Hard reset of KX-TCD580 Base
Go to this link; http://panasonic.co.uk/customer-Support/download-centre.asp and input "KXTCD580" in the search box - after a few disclaimer screens you get to the manual for your phone. page 29 details reset for the handset Page 32 details base unit reset Page 48/49 details cancelling handsets to the base Hope this helps, please post again if you are still having problems with your phone :)
Posted on Apr 01, 2007
SOURCE: DeRegistering a Damaged Cordless Phone????!!!!
If you are still looking for an answer on dereg of a handset, the manual says Menu - 0-0-2 then 3-3-5-OK then select the handset you want to cancel/deregister
Posted on Feb 17, 2008
leroyal
  • 2120 Answers
SOURCE: retrieve messge via 'non-base' handset while using speakerphone of base
No. Handsets must be inactive.
Posted on Nov 06, 2008
SOURCE: Can't register Panasonic KX-TG6051 handset
Press (menu 00, reg) an press locator for 3 secons--- than press ok in you phone.
Posted on Sep 29, 2009
SOURCE: DeRegistering a Damaged Cordless Phone???!!!!
I have a Panasonic KX-TG6700 base unit and KX-TGA670B handsets. We had a similar problem where we were no longer able to deregister the handset using the handset itself. We wanted to be able to use that slot that the broken phone was still occupyng. The solution that we found in the manual online was to hold down the intercom button for 3 seconds until the "in use" light turned on. Then press and hold the number of the extension you want to deregister until it beeps. At this point the base unit has freed that extension.
Posted on Jan 16, 2010
How do i deregister an orphaned AT&T TL92273 handset?
  • Press and hold handset locator on base station until 'in use' light comes on.
  • Press # on the handset and the phone registers itself to the base station.
I repeated the above procedure with my two remaining handsets and now I have a 6 handset cordless system for my home.
It's important to note that if you have a working base station you should use the standard instructions for deregistering the handsets. Each handset gets allocated a handset number by the base station, if you deregister using the special code detailed in this post then the reserved handset number on the base station is consumed and cannot be reclaimed; thus reducing the number of handsets the base station can support by 1. The special code is only for use when you have a handset that is orphaned from a lost or non-working base station. www.apparelstore38.com
Jul 14, 2017 | AT&T Lands Phones
Deregister AT&T SL82118 handset
The following is for the model ATT 5830.
Enter the following sequence on the base station including the * symbols.
**335782
This will deregister all handsets associated with that base station. Handsets can then be added back into the system by entering the base station ID into the handsets one by one. The base station ID is on the bottom of the base station itself.
Feb 06, 2014 | AT&T 5830 Cordless Phone
Deregister a ds6322-4 without the base
for the Vtech cordless phones model DS6322-4 models
In the handset press
*331734# and the menu button, yur handset will be deregistered.
Enjoy unlocking :-)
May 06, 2010 | Vtech Lands Phones
My phone says no link to base but I am right beside it.
Sounds like the antenna on the base station is not receiving, or the cordless handset is not transmitting -OR- the sets have never been registered to the base station (please look up registering to base station, if the set has never been registered)
Did the cordless set work before?
The base station or the handset may just have a hick up, I would un-plug the base station and leave it un-plugged... now get all the cordless set(s), and take out the batteries from the cordless set(s). Wait for about 15 seconds for all the power to drain out of the sets, then re-install the batteries.
Once all the cordless sets are back up and working, plug in the base station and wait for about 1 minute.
This forces the base station to re-establish and link between the base station and the cordless sets.
Good luck
May 11, 2009 | Panasonic KX-TGA101S Cordless Handset
I have a Vtech 2431 base station with 4 phones, one at the base station and 3 remotes, I need to replace one of the phones but I do not know how to reset the base station to remove all the phones...
This worked for me after lots of digging....If you have already tryed reregistering your handsets and can only get two-or three to work try this and deregister them and re-register. If your base model number is vt2431: Take the handset out of the base, press **335782 on the dial pad of the base. (do not have the line active or anything , just put the (2) stars and 335782 in (no spaces) on the base unit. This will de-register all of the handsets at one time. Then all you have to do is re-register handsets...
Mar 03, 2009 | Vtech Lands Phones
How to set up uniden phone to base
If the handset has previously worked with the base - press the hangup button and the # key at the same time on the handset for five seconds and follow the prompts to deregister the handset. (System reset - deregister HS - which handset) It will tell you that the handset is deregistered. Then put the handset onto the base and it will register the handset.
Dec 14, 2008 | Uniden 5.8GHz Expandable Cordless Phone...
How to clear all registrations from the base
One has to completely deregister all handset by pressing end and # keys together till complete de registration is shown on handset screen. if the de registration is not done as above stated method the hand set will not register will show connecting on hand set screen.
Jul 16, 2008 | Uniden TRU8885-2 Cordless Phone
Merging 2 siemens gigaset 4215 systems (one base with 2 phones + 2 phones)
If you're trying to get 5 handsets to work with one base, it won't work. The 4215 can only handle 4 handsets, the base handset plus 3.
When I had to replace the base of my 4 handset system, the base handset still worked. Therefore I had an extra handset which couldn't be used. So I decided to buy another base. Now I have 6 handsets which can be grouped 4,2 or 3,3.
Jun 15, 2008 | Siemens Gigaset 4215 Cordless Phone
TWX977 submersible unable to base register
push menu on base station - select register phone
push # sign on twx977 phone at the same time
phone will register on 9485 base station and unit
Sep 09, 2007 | Uniden TRU9485 Cordless Phone
Panasonic KX-TG5771 Cordless Phone Logo
22 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
