Question about ASUS 1025C-BBK301 Eee PC Netbook Computer / 10-inch Display Screen / Intel Atom N2600 1.6 GHz Dual-core Processor / 1GB DDR3
Battery not charging, need to find extra voltage load?
Battery went dead, bought new one. WOuld not charge. Replaced adapter. Still nothing. Orange light blinks normal because battery at 8% and holding that charge through 4 charge cycles. HPCUID says battery wear at 3%, but gradually decreasing charge voltage. Need to figure out where voltage is getting pulled: looked at motherboard, no damage, did the ACPI compliant uninstall/install method, nothing changed, updated BIOS, chipset, and all possible drivers, nothing. It still says on battery meter that it is "Plugged in, charging 8%" and the only thing changed through 4 overnight charges is the charging voltage went from 8.9V now at 7.4. Charge current/W =0. Power settings set to minimal usage/power saving. Only solution I found is DC-DC converter but not sure how to go about replacing it without having to replace entire motherboard. Again, the only thing wrong with entire setup is that battery wont charge beyond 8% and it shows 46000 of 48000 charge capacity with 3%wear. Any suggestions are helpful.
  • 2 more comments
  • gelly79512
    gelly79512 Feb 11, 2014
    Good with schematics, just can't find them on this model- ASUS E ee PC 1025C-bbk301, motherboard #60-OA3FMB1000...I have 2 batteries, the OEM went dead which started all the troubleshooting, the new one is the current problem, but will be able to exchange it once they test it in store...I'm concerned that after all that the problem still persists. So is there a schematic for this particular motherboard so I can test the right circuits and/or repair if necessary?
  • sharky633
    sharky633 Feb 13, 2014
    There is definitely a schematic or service guide for it, but they would normally be for a service techs eyes only, I have the details and will have a look for you as i do have access to all of Acer service guides (used to work for them) and let you know asap.
  • sharky633
    Sorry, that should have said, they must be available on the net somewhere...
  • sharky633
    You may be better off trying to find out who the board was made by as it will not be Asus, eg: all of Acer boards were manufactured by either Foxconn, Gigabyte or ECS and you can usually get a schematic from the real builders.
    Prodigy:
    An expert who has answered 500 questions.
  • ASUS Expert
  • 510 Answers
Hi gelly, unless the battery you have purchased just happens to be faulty (can you test with another) then i would suggest that the mainboard is faulty (charging circuit is not working as it should) and unless you are good with a diagram & soldering iron i would recommend taking to a good local tech. Hope this helps.
Posted on Feb 11, 2014
Damilare
  • 358 Answers
SOURCE: laptop battery not charging wanna know how to run without battery
The problem you described here shows that, the case is not likely to be a battery problem, but the laptop AC-Adapter (Charger) problem, because, the red light you are seeing shows that your battery has rundown, and even when you plug-in the adapter to AC, it still blinks red, showing that the AC-Power is not charging it. I would suggest that you get another Laptop AC-Adapter (The Charger), or try it with a friend's own first, then you'll see that the problem might not be with your battery but your AC-Adapter
Posted on Jul 10, 2009
  • 60 Answers
SOURCE: initial trouble charging EEE
Try taking out and putting back in battery. also check to see if contacts on battery has tape on them.
Posted on Jul 23, 2009
  • 8909 Answers
SOURCE: Problem with my EEEPC 1000HE
I would say that a new battery should fix your problem.
Posted on Feb 02, 2011
Testimonial: "Thanks, you are sure it's not an internal problem as there is no power when using mains?"
joegoldman
  • 335 Answers
SOURCE: ASUS EEE PC 1008P the system
Maybe try cleaning the battery contacts on the netbook. If it happens with both batteries, then it may just be bad contact between the battery and the laptop. An emery board, or a small piece of fine sandpaper can be used to clean the contacts on the netbook. Clean both sides of the contacts - do it gently as you don't want to sand down the metal, you just want to clean off any oxidization or corrosion on the terminals. If this doesn't help, it may be a bad charging circuit on the board (new netbook). You could also try charging with a different a/c adapter and see if the problem persists.
Hope this helps!
Joe
Posted on Jun 04, 2011
SOURCE: my asus eee pc 1000HE has the orange charge light blinking and says it's charging, but i've had it plugged in for days and it wont charge
your battery might be dead. just replace your battery.
Posted on Feb 17, 2012
Navigon 70 charging trouble
The battery probably needs to be replaced.
Mar 04, 2014 | GPS
Nissan Altama Starter Relay electrical problems or a fuse?
Or the battery cables ! Do you know how to use a voltmeter ?
Starter Voltage Drop
Do you know how to do basic automotive electrical testing ?
How to voltage drop test starter motor circuit
Electric Testing Techniques You Need to Know Here is a place to view wiring diagrams ! http://www.bbbind.com/free_tsb.html
Apr 08, 2017 | 2004 Nissan Altima
Fatal Error:
It sounds like the port not the battery. You should take it someone to repair it. They are not expensive...
Dec 15, 2011 | Dell Inspiron Mini 10 Notebook
My sons power pack died leaving laptop with dead battery. small light flashing orange at the front .i bought a replacement power pack making sure it was for his model.plugged it in and nothing it wont...
You may have a DC connector problem:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
May 25, 2011 | Advent 4211c Notebook
My acer net book wont charge. It worked on my battery power but i dont want it to run out because when i plug in the charger, nothing happens. The orange light doesnt come on or anything. I have only had...
First of all, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Aug 25, 2010 | Acer Aspire One PC Notebook
Honda 1985 1200 Gold Wing
First have the battery(s) tested. A number of car parts places will do it free. The test must be under load. Voltage may be fine in a discharged battery. In a 1985 Gold Wing the problem may be in the ignition switch. have the switch checked out.
Jun 27, 2009 | 1985 Honda GL 1200 Interstate Gold Wing
08 650 executive, new battery but charging system doesn't charge
Your running off the battery until it dies. Check your chargng system. It should put out 13.0-14.5 volts. If not then the current will flow from what ever source has the most voltage. Thus, your dead battery. Try changing he voltage regulator and then check the stator next. Sometime stators can have burned section on them and reduce the voltage produced to the battery. Also check for really good connectin to the terminals. This can rob current and voltage by upt o 40%.
Apr 21, 2009 | Suzuki AN 650 Burgman Motorcycles
Battery Charge
The best way is to get a voltmeter and check the voltage of the battery with the truck running and not running. When the truck is running, the voltage across the battery terminals should be aboput 14.9 volts (showing the alternator is charging the battery). With the truck off, the battery voltage should be about 12 volts (showing that the battery is holding the charge). From there, you should be able to tell which is bad.
Aug 11, 2008 | 2002 Ford Escape
Open Questions:
Save Your Important Data Getting Lost With Cloud Backup Solution of Dataalign These days, not only businesses but individuals increasingly need access to their data on the go without thinking about storage and hardware maintenance costs. Online Cloud backup provides an efficient solution and is swiftly attaining popularity. Before cloud-computing, end users stored their personal data on computer's hard drives and memory cards. Unfortunately, computers and mobile phones require physical proximity to the device to allow access to the stored data and are far more vulnerable to damage and accidental deletion. Individual devices need diligent support and maintenance, and ensuring the security of the data remains a challenge. With, Server Cloud Backup Solution end users can upload documents, photos and videos to the cloud and then fetch them at their ease. This helps them save storage space on their computers and mobile devices. Furthermore, the cloud based structure allows end users to upgrade software more quickly - because software Cloud Backup publishing companies choose to offer Cloud Backup For Small Business web rather using traditional, tangible methods that involve discs or flash drives. Top software publishing companies have chosen to turn their business models to subscription based and they deliver their product offerings through cloud solutions. An online backup service isn't much capable if the process of restoring your data and getting back to being productive is not simple and quick. DataAlign offers a search tool to find a backed-up file. Also, the ability to replicate an entire folder-tree structure, helps with preventing bigger data losses. Versioning is another capability offered by DataAlign. This allows you to see earlier versions of a file in case you made Online Backup Pricing some undesired edits. This can also be termed as archiving function. You can set the number of versions and days you wish to keep any file and utilize the maximum available storage space. Using the version history, you can view the history of each file stored and undo mistakes, if required. Any accidental deletion of file from the computer and can be restored instantly as deleted files are backed up on the cloud. The moment the data is no longer required, you can setup a data destruction policy.
May 26, 2018 | Individual Computers & Internet
See all ASUS 1025C-BBK301 Eee PC Netbook Computer / Questions
ASUS 1025C-BBK301 Eee PC Netbook Computer / 10-inch Display Screen / Intel Atom N2600 1.6 GHz Dual-core Processor / 1GB DDR3 Logo
139 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
