Question about Kyocera FS-C2126MFP Printer
Add toner K
Keeps asking me to add toner K and I have replaced the cartridge 3 times now with no luck
Why does richo aficio 2016 copier keep asking for toner hen toner is full
As long as the toner sensor senses it is empty, it will keep telling this. Or the sensor is defect, or a cable came lose, or perhaps you only have to shake the toner cartridge a few times. Be aware it is open now.
Jul 16, 2014 | Ricoh Aficio 2016 All-In-One Laser Printer
There is no toner when there is in the toner cartridge
replace the image unit for that color and replace the toner cartridge with oem cartridge
Jan 30, 2014 | Konica Minolta magicolor 2430 DL Laser...
I have a SHARP al-1661cs copier/printer. i keep getting a "replace TD cartridge" message. I have replaced the cartridge and it still come on every couple of days. i take the cartridge out, shake it and the...
Are you having your cartridges refilled?
By "replace TD cartridge" message do you mean the little stack of 6 red dots on the control panel?
The sensor for this condition is contained within the toner cartridge. The sensor reads the mixture of developer to toner ratio and tells the machine to add toner when needed. If you are having this problem with 3 different toner cartridges then I would suspect the toner add drive system. If you are having just the 1 cartridge refilled and have had the problem with the last 3 refills then the cartridge itself may be the problem.
I'll let you repond then we will see if further info is required.
Thank You for using Fixya.
Mar 29, 2010 | Sharp AL-1661CS Laser Digital Copier
Our copystar 2030 keeps asking for toner. We just
Can be an ensemble of the reasons:
1. The Silent sensor which checks the concentration of the toner.
2 Check pulled of you film defensive with tubas?
3 During moving the toner track can be broken or littered.
4 Can be a value-added degree to concentrations of the toner in service programme inflexion
5 Can be sensor itself to concentrations
7 Sensors can be littered
8 If it is used developer, can be violated concentration developer to toner
This in a complicated way repairs with words.Sooner whole you should apply to service,forgive, but such fault it is difficult do advice, it is necessary all look the experienced specialist, you may lose much toners and break the track of the presenting the toner, apply to service. Good luck
Oct 07, 2009 | Copystar CS-2030 Copier
Studio 230 added a new toner cartridge
When adding toner to the developer unit, it will load from the toner. So, if toner is empty, it will ask for replacement. Normally u can hear noise from the toner when loading.
Mar 19, 2009 | Office Equipment & Supplies
Will not add toner
Reinsert cartridge and restart it by unplugging or powering off
It should refresh the memory
Good Luck
Jan 29, 2009 | Gestetner DSm515pfd Digital Copier -...
Gestetner 3222
Open the front door and close it and check if the display reads loading toner. Try this for 3 times.
If Add toner indicator is still there, check that you had removed the black cap of the toner, before you replaced the toner bottle.
Remove the bottle from the holder and check inside the neck of the holder if there is something blocking the toner supply. (sometimes the inner plastic cap of the previous toner is stucked in the neck).
Check and clean the toner bottle holder unit.
Another problem can be worn gears in the lower development unit and within the dev. bias roller.
Good luck and please rate me, thanks.
Jan 27, 2009 | Gestetner DSm622sp Digital Imaging System
Problem with aficio 1035
The developer should probably be changed in it. the cartridge should be inspected as well. Was there any toner spills?
Jun 21, 2008 | Ricoh Aficio 1035 Copier
I don't know how to remove and install toner for my sharp ar-337
If you go here:
http://www.sharpusa.com/files/cop_man_ar287_337_407.pdf
You can download the operation manual for that machine, on page 4-5 they explain how to replace the toner and have pictures showing how.
here is the text on how to replace.
Adding Toner
1 Open the front cover.
2 Pull down the toner hopper lock lever and pull the toner
hopper out slowly until it stops.
3 Tap on the top of the toner cartridge 5 times. Hold the
new toner cartridge vertically and vigorously shake it
up and down about 20 times, then invert the cartridge
and again shake it up and down about 20 times. This will
loosen the toner and allow it to flow more easily into the
toner hopper.
4 Place the new toner cartridge with the tabs in the
notches as shown.
5 Slide the toner cartridge along the guides over the toner
hopper.
6 Hold the toner cartridge with one hand while pulling on
the sealing tape to remove it.
7 Tap on the top of the toner cartridge 5 times to start the
flow of toner into the toner hopper.
l If the toner cartridge was sufficiently shaken as described in step
3, it will take about 50 seconds for the cartridge to empty. Do not
remove the cartridge until it is empty. If not empty, tap on the top
of the cartridge again until empty.
8 Slide the empty toner cartridge back along the guides
and remove it.
l The cartridge opening will be closed as it is moved back along
the guides.
9 Slide the toner hopper into the copier and return the
toner hopper lock lever into place.
10 Close the front cover.
NOTE:
Add only one cartridge of toner.
Jun 19, 2008 | Sharp Office Equipment & Supplies
Kyocera FS-C2126MFP Printer Logo
48 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
CheckitRight
CheckitRight
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
