Question about Pitney Bowes Office Equipment & Supplies
PB Model FD40 Folding machine... I cant seem to get rid of the 'stacker error' code. I have removed the fold plates, I have pressed the reset, enter, etc... and to no avail. All other troubleshooting suggestions have been tried. Please help!
  • 138 Answers
SOURCE: Machine Error 17 Brother
I am assuming that you error listed above is actually a "Machine Error 71" not a 17 as their is no such 17 error. The error 71 is a problem with the Polygon Mirror (laser scanner). The scanner is going to require replacement. The part is available at Seattle Platen, Dale 1-800-221-2388.
Hope that helps you.
Posted on Aug 30, 2008
SOURCE: I am looking for a service manual for a Pitney Bowes FD40
http://www.pitneybowestsg.com/public/Opguides/Fd40u036.pdf
Posted on Mar 20, 2009
  • 244 Answers
SOURCE: I have a duplo DF-520
Found access to a service manual...a little more in depth than the users manual - small cost though, I believe 7.95 /EUR
http://www.nodevice.com/user/register.html
HTH,
Mike...
Posted on Dec 09, 2009
  • 9 Answers
SOURCE: Where is the limit switch fb2 on a pitney Bowes
contact me if you still have problem. i'm a pitney bowes field techinicien and i know how to resolve your issue with your folding machine
Posted on Mar 18, 2010
SOURCE: Our Pitney Bowes 1810 Folding
You have a paper jam. You will need to remove the upper cover from the machine and get the jam out ( 4 screws). Be careful and do not bend any of the guide plates when you do this, and make sure that you remove all the paper ("Reassemble" the jammed paper and make sure you got it all!) Work with the machine unplugged so that you do not accidentally turn it on with the rollers exposed. When finished you should be able to turn the knob and use the machine.
Posted on Jul 01, 2010
Pitney Bowes FD40 error top cover open
Locate the top cover switch that is apparent stuck in the open position. Fix or bypass it.
Oct 20, 2016 | Pitney Bowes Office Equipment & Supplies
Xerox docucolor 240-250 not stapling/folding, error codes 012-243, 012-229, 012-225
Koday Hero 7.1 carriage jam. Stuck to the left side. No paper jam can be found but can't get the carriage to move.
Nov 15, 2013 | Office Equipment & Supplies
To remove 1993 mustang conv. top cylinders should top be up or down? thanks, bill
don't have 93. here's 94
Motor Assembly, Convertible Top Removal and Installation
NOTE: The folding top hydraulic cylinder rods should be in the fully retracted position.
Use absorbent rags or a container to catch any hydraulic fluid that leaks out when removing the fittings.
  1. Remove motor and pump assembly as outlined.
  1. Loosen each folding top motor upper and lower hose fitting on the sides of the folding top hydraulic lift motor and plate kit (533A00) .
  1. Remove the folding top hydraulic lift motor and plate kit .
  1. Remove each of the service folding top hydraulic lift motor and plate kit plugs one at a time and attach the tee fitting to the replacement folding top hydraulic lift motor and plate kit . NOTE: Make sure that the o-ring is installed in the bottom of each folding top hydraulic lift motor and plate kit port before attaching the hose tee fitting.
  1. Connect the folding top hydraulic lift motor and plate kit unit to a 12-volt power source and cycle the folding top hydraulic lift motor and plate kit in and out several times to purge the air from the folding top motor upper and lower hoses (53390) . Some noise squeal may be noticed due to the air. srb~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not overfill or the reservoir seal could be blown out.
  1. Carefully remove the rubber fill plug from the back and the reservoir and check the fluid level. The level should be at the bottom of the filler hole. If necessary, add Synthetic MerconĀ® Multi-Purpose Automatic transmission fluid E6AZ-19582-B (ESR-M2C163-A2) or equivalent.
  1. Replace the fill plug with a new fill plug.
  1. To install, reverse Removal procedure.
Section 01-17: Convertible 1994 Mustang. Workshop Manual
REMOVAL AND INSTALLATION Lift Cylinder, Power Top Removal and Installation
NOTE: The cylinder rods should be in the fully-retracted position.
  1. Remove pump and motor as outlined.
  1. Remove the upper and lower hose fitting from the folding top hydraulic cylinder (50600) . Use absorbent rags or a container to catch any hydraulic fluid that leaks out when removing the fittings.
  1. Remove each of the service cylinder plugs one at a time and attach the hose fittings. NOTE: Be sure each fitting is installed in the correct position on the folding top hydraulic cylinder .
    NOTE: Make sure that the tetra seal is installed in the bottom of each of the folding top hydraulic cylinder ports before attaching the upper and lower hose fittings.
  1. Connect the folding top hydraulic lift motor and plate kit (533A00) to a 12-volt power source and cycle the folding top hydraulic lift motor and plate kit in and out several times to purge the air from the hoses. Some noise squeal may be noticed due to the air.
Jan 21, 2011 | Ford Mustang Cars & Trucks
Eurovox 'Maestro Series' 10 stacker displaying 'E-99'
CD ERROR DISPLAYS
CD Changers
E01:
The disc magazine is not inserted in the cd changer
E02:
No disc is inserted in the disc magazine
E04:
The disc is dirty, or the disc is inserted into the disc magazine
upside down
E99 RESET PROCEDURE:
Remove CD magazine by pressing eject button on changer.
Remove all discs from magazine and re-load empty magazine into
changer. Using the Radio RESET CD system by pressing and
holding the “ON”/”POWER” button for about ten seconds, or in
earlier models the “EJECT/6” button.
FM/RF Remote Controls
E99 RESET PROCEDURE FOR REMOTES:
Remove disc magazine from changer by pressing eject button.
changer. Press RESET button on interface unit
WAIT:
The temperature is exceeding more than 55c(130f) and the cd
changer cannot be operated. When the cd changer cools off, this
wait disappears. When the RESET button on the interface unit is
pressed, this WAIT appears for a few seconds
IF THESE ERROR CODES STILL KEEP APPEARING
CONTACT YOUR DEALER.
Jun 14, 2009 | iLO CA3000V CD Player
Wing mirrors on 06 plate Golf TDi
Has it ocurred to you that your wing mirrors are not the electrically folding type, most are not. The switch on the drivers arm rest for adjusting the mirrrors will have a separate position for folding if yours fold. The resistance to fold by hand is very stiff as you have to overcome the spring tension, even when folded by hand they do not fold as flat as you might think.
I purchased a 2006 Golf 5 GT Tdi last year it had £5000 worth of factory fitted options but did not have electrically folding door mirrors - hope this helps.
May 14, 2009 | 2006 Volkswagen Golf
Our Pitney Bowes 1810 Folding Machine hums & the document dial for the folding style does not move! Help!
Problem is not fixed. It does not involve a fax machine, it involves a Pitney Bowes 1810 document folding machine. Not interested in paying for "service" - it appears as though your service would be of any help.
Thank you
Jan 26, 2009 | Office Equipment & Supplies
Convertible top
here's some info
Symptom Chart Condition Possible Source Action
  • Folding Top Does Not Raise and/or Lower
  • Blown fuse(s).
  • Circuitry open/shorted.
  • Damaged folding top switch.
  • Damaged raise/lower relay .
  • Damaged folding top hydraulic lift motor and plate kit .
  • Parking brake not engaged.
  • Go to Pinpoint Test A.
  • Top Hesitates and/or Comes Up Uneven
  • Damaged folding top motor upper and lower hose .
  • Damaged folding top hydraulic cylinder .
  • Damaged folding top linkage.
  • Go to Pinpoint Test B.
  • Top Does Not Raise or Does Not Go All the Way Up
  • Go to Pinpoint Test C.
  • Hydraulic System
  • Damaged fluid reservoir.
  • Go to Pinpoint Test D.
  1. Carefully remove the rubber fill plug from the back and the reservoir and check the fluid level. The level should be at the bottom of the filler hole. If necessary, add Synthetic Mercon® Multi-Purpose Automatic transmission fluid E6AZ-19582-B (ESR-M2C163-A2) or equivalent.
Jan 04, 2009 | 1989 Ford Mustang
41 people viewed this question
Top Pitney Bowes Office Equipment & Supplies Experts
Victorman
Victorman
richie46
Are you a Pitney Bowes Office Equipment and Supply Expert? Answer questions, earn points and help others
