Question about Brother MFC-J415W Multifunction Inkjet Printer
Uverse doesn't allow me to receive faxes anymore
Why doesn't my fax work after installing UVerse
Are you sure that the fax is compatiable with UVerse software,you can goto to the UVerse website and trouble-shoot compatiablity.
Dec 22, 2012 | Lexmark International Lexmark X5400 Series
How to receive fax documents
You cannot receive fax using this printer, because this printer doesn't support fax sending/receiving. Only fax supported printers can receive fax documents. You will know if a printer is fax support if you see a Fax button there or if you can see a numpad buttons where you can dial numbers.
These are the photo examples of fax printers
Hope my solution helps. Thanks for using Fixya!
Jul 11, 2011 | Canon PIXMA iP4000 InkJet Photo Printer
I have a lexmark x6570. I have att uverse phone/internet/tv. I have always been able to send/receive faxes. Now i can receive a fax, but cannot send one. When I do, the transmission report says...
Try dialing *82 and then the full fax # you are calling. AT&T sometimes has issues with caller ID functions, and I found that this caused me to be able to receive a fax, but not send one. Post back and advise whether this resolves your problem.
Best,
JudyP
Mar 26, 2011 | Lexmark X6570 InkJet Printer
I need the remote code for a pioneer vsx502 receiver for att uverse remote
I used 5120 to turn off and on the receiver on the Aux button, I am also control the volume on the recevied by assigning the volume control using 955 code. The one thing I lack is a way to change the receiver input between BD, HDMI1, HDMI2, etc. I still have to go to the Receiver remote for that. I know the Uverse Receiver can't do everything, but if I could just get the input to change on the UVerse Remote, it would be awesome. I'm trying to avoid getting a Harmony. The blu-ray and tv also work, which is great! See this reference for the silver remote:
http://www.att.com/support_media/images/pdf/uverse/remote_control_user_guide.pdf
If you have black, you may need to visit the AT&T support site to get the black manual.
Nov 17, 2010 | Pioneer VSX-607 Receiver
I CANNOT GET OR SEND FAXES ANYMORE. IVE TRIED
Go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set. Make sure the phone wire which you insert in fax machine getting proper dial tone and getting out going calling facility.
Have a nice day and do not forget to rate please...!
Mar 25, 2010 | Canon MX310 Office All-In-One Printer
Auto-answer issue: fax beeps on line when voicecall received
Try changing the receive mode from automatic to FAX ONLY and set the number of fax rings higher. You should be able to receive phone calls and if you are not answering your phone it will automatically receive a fax.
Mar 27, 2008 | Office Equipment & Supplies
Brothers 2800
The machine is probably set to "manual receive." Check the receive mode. In "Manual" mode the machine will ring until the start" button is pressed. Fax mode will allow the machine to receive faxes as will the "Auto" mode which will allow both faxes and telephone calls automatically.
Jan 03, 2008 | Brother IntelliFax-2820 Laser Fax
Brother MFC-J415W Multifunction Inkjet Printer Logo
19 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
