Question about Brother MFC 7840W Printer
Brother MFC-8480DN Printer jammming
While using the Document feeder the top corners of the paper being fed become folded
    Habit-Forming:
  • 75 Answers
Try to clean the document feeder, i think there so many scratch of small piece of paper that why the printer is paper jam.
Posted on Feb 09, 2014
BondoFox
  • 40 Answers
SOURCE: Brother MFC - 7420: Paper will not feed!
Does it make the same sound if you feed the single sheet through the bypass with the paper drawer removed? I hate to say it, but your printer's paper feed mechanism may need replaced. Go to http://www.brother-usa.com/AskUs/default.aspx and ask Brother to diagnose this one; I think they'll confer with me and should be able to point you to a nearby Brother-authorized repair center. Let me know what happens!
Posted on May 29, 2007
FixinFax
  • 3085 Answers
SOURCE: I have a Brother MFC 9440CN copier/scanner/fax
Pull up the doc feeder to open. Clean the scanner glass with alcohol
Posted on Jul 08, 2009
SOURCE: Bad Scan Quality Using Brother MFC-7820N Document Feeder
Look to the left side of the flatbed glass for a thin strip of glass by itself. When you scan from the glass, the document stays put and the sensor moves across the document. When you scan from the feeder, the sensor stays in that glass strip and the document moves across the sensor. See what I mean? I would check the small feeder glass for dirt or scratches from staples or other flotsam. Also not a bad idea to blow out the feeder path with some compressed air to ensure the documents is handled smoothly. Hope this helps!
Posted on Nov 11, 2009
  • 1684 Answers
SOURCE: i get vertical lines on scans and copies when
Check out this page on our web site at:
http://www.ccl-la.com/dirty_scanner.htm This page shows you what to do to get rid of the lines on scans and copies.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Jan 12, 2010
pineworks
  • 4041 Answers
SOURCE: problem paper jam printer brother no mfc-490cw
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 27, 2010
Horizontal lines
Most lines will either come from laser cartridges, or and most likly the fuser. If you can see the fuser rollers, see if they have wear marks. If so fuser or rollers need replacing. If a multifunction copier with a top glass check the what is called slit glass(small glass where paper goes over when fed from the document feeder.
Jul 23, 2014 | Brother MFC-9320CW Color Laser Printer -...
My printer showing paper jam n i cant find any paper stuck in the printer checked in n out?
Hello! Welcome to FixYa
Paper jam
means their may be small bit paper jam in side
There are some "micro-sensors" that detect a paper jam. There will be tiny piece of paper, or a lump of dust, inside those sensors, thus "tripping" the sensor and saying you paper jam.
To solve it
Open printer cover and check to make sure no paper or foreign objects obstructing the printer feeder
If you become sure that now really there is no paper, dust or foreign objects then
Turn the printer off, and disconnect the AC power-cable. Open the printer cover & now give the printer a "blow-job" by compressed air.
If still problem exist then best & final option is to just contact to any Brother Printers service provider.
If you have any Confusion, questions or issues regarding your problem do tell me.
Thank you for using FixYa!
Concerned: Angel Bird
Apr 11, 2011 | Brother MFC-8480DN All-In-One Laser...
Brother mfc-8480dn no paper error I have a new brother laser printer and it is telling me there is "No Paper" but the paper tray has paper. I have tried removing the paper and reloading the tray...
Open the file you are trying to print, go to "file", "page setup", "Paper" and choose "Default tray" under paper source. It may give you an error message that the margins are outside of the paper. Click on "Fix this", then you can print. I had the same problem.
Jan 12, 2011 | Brother MFC-8860DN Printer
Original document fed into top feed tray of mfc 7440N model come out with few thin black lines on the mid left of the scanned file. Scanning file from glass has no issue.
You need to clean the narrow glass strip on the left side of the machine when you open the cover. There is likely lint or something on this glass. This is where the auto document feeder pages are "imaged".
May 20, 2010 | Brother MFC-7440N Laser Printer
How to print using ADF feeder?
You take the paper with face to print Up and the top of the paper towards the interior of the ADF. You can also put a stack of papers. When you press the copy/scan command from the machine console or the computer, the automatic document feeder starts.
Jan 06, 2010 | Brother MFC 6490CW InkJet Printer
Brother MFC420cn Document Scanning
Yes, you save it to a pdf file. Configure scan to file to save as pdf, and it will create a single file
Apr 30, 2009 | Brother MFC 420CN All-In-One InkJet...
Brother MFC 8840, Document Feeder is not workting
ITS PROBABLE THAT A CONNECTOR CAME OUT.REMOVE BACK CORNER PANEL AT FEEDER CABLE TO CONFIRM.
Apr 15, 2008 | Office Equipment & Supplies
Paper feeder
Check the paper fed tracks- make sure there are no debris in the channels. Can you hear the feed system working or is it not running?
Jun 06, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother MFC 7840W Printer Logo
109 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
