Question about Iview Cyberpad 756TPC Tablet
Broken charging port in tablet - Iview Cyberpad 756TPC Tablet
If the charging port for my zeiko 10 inch is broken,what other way can I charge
Some tablets have a charging port and a usb port. If your tablet is so equipped it should charge while connected to another computer by usb or to a usb charger.
If your tablet is only equipped with a usb port and that is broken, it will need a repair before the battery can be charged.
Jul 11, 2016 | Tablets & eReaders
Keeps saying connect charger even wben charger connected.iam trying to charge tablet
probably your charger is broken or your charging port is broken. either way, if the charger is broken, its cheap to replace. if the port is broken, its cost a bit more
Dec 05, 2015 | Dragon Touch Touch 7 Purple Dual Core Y88...
I CANNOT CHARGE THE TABLET THRU EITHER PORT- THE REGULAR CHARGING PORT OR THE USB PORT THAT I FOUND ALSO CHARGES IT. WHAT COULD BE WRONG AND WHAT ARE POSSIBLE SOLUTIONS?
could be software issue reset it would fix it:?
damage to ports both broken sounds unlikely
try usb plug into a different computer
the cables inside the tablet are loose or not connected
check for damage to ports and loose connections inside device
Jun 29, 2015 | Proscan PLT7223G 7" 4 GB Wi-Fi Black...
Have to push power adapter hard for tablet to charge
The power port is damaged - most likely the solder joints are loose or broken. You need to find a store where someone can open the case, order the new part for the tablet and then solder the new power port to the board.
Then it will be as good as new.
I have replaced power ports on laptops, phones and tablets.
May 24, 2015 | Tablets & eReaders
The charging port is broken off, will the pad still charge wireless?
No. The wireless charger has to connect to the charging port via an add on cover on the device. Powermat Wireless Charging Pads from Duracell
Get a new tablet.
Mar 11, 2015 | Irulu 10.1"tft Wifi 3g Android 2.2 Tablet...
Power port broken
you can charge it through USB from any laptop or multichannel charger, if it's 7 inch or 10 inch you can use any charger for car toys for kids it will work fine.
Jan 13, 2014 | Tablets & eReaders
Thecharging port on my Toshiba tablet is broken, is there any other way to charge it?
I'm afraid there's no other way. Is there a physical damage on the charging port as evidence that you're saying it's broken? It might be the charging cable itself (hopefully).
Sep 22, 2013 | Toshiba Tablet. Excite 10.1 in. Android...
Iview Cyberpad 756TPC Tablet Logo
73 people viewed this question
Top Iview Tablets & eReaders Experts
Are you an Iview Tablet and eReader Expert? Answer questions, earn points and help others
