Question about Samsung SafeVIEW Baby Monitor
Troubl shooting no sound from monitor
My 40 inch LCD sanding tv won't turn on for awhile. It keeps doing the clicking sound for about two minutes before it catches and turns on. Shat should I do?
> Shat should I do?
Take it to a qualified TV/video technician, for proper trouble-shooting and repair, because this problem has no "end-user" repairable parts.
Oct 23, 2010 | Samsung SM400P 40" LCD Monitor
No audio device found
This can be difficult if you are not familiar with computers.. First go in to your control panel, and search for something with sound displayed. Click on this which should pull up something about drivers. Like which one you have ext. You may have to manually click on this, and manually install an audio driver. If you go to trouble shooting and type your problem it may have better detailed steps.
Jul 19, 2010 | HP vs15 15"LCD Flat Panel Monitor
No volume this monitor was given to me the volume is all the way up on desktop and I cant see where any speakers can be put.
Are you sure the monitor can handle speakers? Maybe it has it's own speakers, maybe it has no speakers at all. You can always plug the speakers into your CPU into the sound card, it is usually the green audio port.
That said, some things that you can trouble shoot.
  1. Make sure that the volume is all the way up on the desktop.
  2. Make sure that the volume control is all the way up in the control panel sound option
  3. Make sure that nothing has been muted, the control panel allows you to selectively mute a single device.
Apr 15, 2010 | Samsung 226BW Monitor
I have the FPD2275W for 5 years but now it only turns on for a few seconds than goes blank but I can touch the menu options on the side and they make sounds but nothing appears on the screen....Help?
New 19" LCD monitors are as low as $100. Buy a new monitor, or pay a qualified technician $50 to $100 to _try_ to trouble-shoot your current monitor.
Apr 07, 2010 | Gateway FPD2275W LCD Monitor
When I turn my computer on, the lights all come on and i cna hear the start up sound ... but no picture on the monitor
you may have to trouble shoot the ratio andm, screen size of your graphics, and or update the drivers to solve the problem. if this does not correct the issue, you should connect a external monitor to bipass it as a temporary solution, then have the tft looked at by a pc technician to repair it
Dec 26, 2009 | Toshiba Satellite L305D-S5934 Notebook
PC running without anything showing on monitor.
Hi
Sounds like you have somehow deleted the driver for the monitor - - you need to plug another monitor into your PC - you can use the laptop you are using now - then you need to download the driver for the monitor again when you can see on the screen
May 03, 2009 | E-Machines eMachines Desktop PC
No display on dv8320us PC notebook
It may not be your driver causing the problems, it sounds as though it might be your graphics card. Are you pressing Fn + F8 i think it is at the same time to switch between monitors? If that doesnt work, then i would consider replaceing graphics card (if possible)
Dec 21, 2008 | HP Pavilion dv8320us (HP RDV8320US) PC...
Power lite intermitent, panel stays black
The black panel is cliped onto the sliver surrond you need to carfully prize it apart once all the srews have been removed.
Sep 14, 2006 | HP L1702 17" LCD Monitor
Samsung SafeVIEW Baby Monitor Logo
41 people viewed this question
Top Samsung Baby Gear Experts
Jennifer Rock
Jennifer Rock
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Samsung Baby Gear Expert? Answer questions, earn points and help others
