Question about Samsung SafeVIEW Baby Monitor
No sound from monitor
Monitor is set to 5 on sound but shows to be muted
I have a Zenith P60W26P 60" Plasma TV that the sound went out. Any ideas? and yes, I tried the mute
Check the audio settings and make sure that you did not set it to external speakers only.
Jan 14, 2015 | Zenith monitor P60W26P User Manual
Looks like the monitor is showing sound on mute....how do I turn it up
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select enable windows 7
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
hope this helps
Aug 08, 2011 | Computers & Internet
One day it was working fine - the next day there is no sound for any device. Mute button was not on, unlugged power, waited 5 minutes, reactivated - nothing
Most machines have multiple outputs and assignments for these outputs. If the assignment is off you will get no sound. There is also features that will turn off sound like choosing the wrong speaker A or B setting if speaker A and B are both in or both out and only one set is actually hooked up it will mute, and there are machines with Tape Monitor feature which will mute the sound for recording purposes. I hope this helps. Feel free to ask for clarification with more details about your receiver if it does not.
Mar 01, 2011 | Denon Audio Players & Recorders
I cannot get any sound from my ViewSonic VA1912wb Monitor. I have everything plugged in the mute turned off showing 100% volume the green jack in back of monitor and green match on computer. No sound from...
You may need to load the monitor drivers.
I assume your PC sound is OK.
When you are plugging the green lead in the Moniotr / PC do you hear any noise from the monitor?? if not may be faulty.
Try plugging a friends set of speakers into the back of your PC.
Mar 09, 2010 | ViewSonic VA1912wb Monitor
Can not get this monitor to play sound on PC using XP Version 5.1. a driver needed?
there is not a windows xp 5.1 so I am going to take a wild guess and you mean you want 5.1 surround sound
If your computer plays sound through its own speakers normally then you do not need a driver.
I took this from the FAQ
  1. Make sure the audio cable is plugged in to the back of the monitor and in to the Green port in the back of the computer.
  2. Press the Right Arrow button on the monitor itself and set the volume to 10.
  3. Double check your audio settings on your computer and make sure nothing is muted.
This is not one of the better monitors in this price range having only a VGA input but is suitable for most people.
Aug 14, 2009 | Sylvania CL772B 17" Flat Panel LCD Monitor
Relisys Sound
CJ,
1. Check make sure the audio cable are plugged in from the monitor to the PC output audio jack (light green).
2. Open your on screen display and go to Volume settings. See if it set on mute or set to 0.
3. Turn of your monitor & PC and unplugged all the cables from your monitor and PC wait for 10 seconds and then replugged it all the cables and audio cable back. Then turned on you PC...
4. If it still doesn't work.. open the back cover see if the speaker cable are plugged in.
5. If that doesn't work...then your monitor AD board built-in speakers are defective.
6. Why not just used a external speakers, it give better sound quality.
Have a nice weekend!
Aug 17, 2008 | Relisys RLT1720 17" LCD Monitor
I can't get any sound out of my monitor. when I push the select I get the speaker w/music, select that.My color on th volume is green. I get no sound. I try to push the 1-2 reset button and nothing changes...
First use a try testing another source of sound, (say an Ipod or cd player) instead of your computer.
If that works the try troubleshooting the mute and volume controls on your computer.
Mar 13, 2008 | NEC AccuSync LCD223WXM Monitor
No sound from the monitor
Plug the monitor speakers into a source of constant sound (mp3/cd player) and make sure the monitor is not muted and volume is at least half way.
If that works adjust the volume and mute settings on the computer
Mar 08, 2008 | Liquid Video E15LCD1 15"
Samsung SafeVIEW Baby Monitor Logo
44 people viewed this question
Top Samsung Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Samsung Baby Gear Expert? Answer questions, earn points and help others
