Question about Janome Sewist 525S Mechanical Sewing Machine
Where to drop oil for a janome 525 s - Janome Sewist 525S Mechanical Sewing Machine
Oiling the janome sewing machine?
Follow the instructions in the manual, especially if it is a computerized machine. These machines require little, if any, oiling. Additional oiling can damage the machine.
Mechanical machines--use only fresh, good quality sewing machine oil. Gently wiggle the handwheel and apply a drop or two of oil every place that metal rubs against metal.
May 29, 2017 | Janome Sewing Machines
How do I oil mysewing machine? It's a janome excel 5024
You don't oil this type of machine. It's not like an old one that needs oiled every two hours of sewing. You can place 1 drop of oil under the bobbin case in the center to the hook. (One drop of oil on the wick in the center of the magnetic ring.
Feb 26, 2015 | Janome Sewing Machines
Does my Janome Sewist 521 model require oiling?
One drop of oil under the bobbin case in the center of the hook, on the wick. Your machine doesn't need oiled like a vintage machine. Taking it in for service once a year is plenty.
Feb 22, 2015 | Janome Sewing Machines
Which parts on my Harmony 8080 (Janome) sewing machine do I oil.
Do you have a manual? Most Janomes have a sealed oil system meaning you don't ever oil anything besides the little wick under the bobbin case, just one drop now and then.
Sep 30, 2014 | Janome 8080 Computerized Sewing Machine
Cant thread the bobbin - janome 525,Hello kitty, its like the chamber below is out of alignment.
if it's out of alignment then it will have to be fixed at a sewing machine repair shop
Feb 26, 2012 | Janome Sewing Machines
I have a Janome 4623 LE Plus. How, where, and how often do I need to oil this machine? Thank you so much.
Oil any movin g part that you can get to and only a couple of drops of oil before you use it.
Aug 10, 2011 | Janome 4623 Mechanical Sewing Machine
I have a Janome Sewist 525 and I love it, I've had for about 3 years and never had any problems. I have a question though. I have the manual that came with it and nowhere in the entire manual does it say...
some machine are self oiling, when they are run & they parts get warm to hot then the oil come out of the parts & it's self oil.
contact a janome dealer & ask if your model is self oiling
Nov 17, 2010 | Janome Sewist 525S Mechanical Sewing...
Where drop oil
Open the PDF for this model (Janome mechanical) and see if it is the same - http://janome.com/index.cfm/Machines/Sewing-Quilting/TB12
If not, contact Janome for a manual.
Apr 20, 2010 | Janome 2049LX Mechanical Sewing Machine
Janome Sewist 525S Mechanical Sewing Machine Logo
52 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
