Question about Cisco Spa 502g Ip Phone Spa502g
Recovery failed: cannot find the specified device
I just ran the recovery disks to cure a severe
Do you have separate installation driver disks for those items? If not, you can use a friends PC to go on line and download them. You can also get more information under control panel - system - hardware - device manager. The PC will show you which items are having trouble and any information it can get from the component. If it shows unidentified it is very likely the driver is not installed. But note - are you sure it was a virus and not a failing hard drive. If problems return now that you are going it is more likely the HD.
Apr 21, 2010 | Gateway 5200X PC Desktop
Error code 13 and 16 on my xbox 1, cannot launch the dashboard and error files.... cannot find a hdd recovery disk at the net help me find one plz...
Hello Sir
13 - kernel - Dashboard launch fail (due to missing/bad key, or anything else that would prevent it from running) and the dashboard didn't specify why it failed.
16 - dashboard - Other files to do with dashboard / dashboard settings (specific dashboard error)
Mar 02, 2010 | Microsoft Xbox Console
The system cannot find the specified file
It seems as though your windows is corrupted. To solve this I would recommend a recovery back to factory settings but this will delete all the data of the computer.
You can save your data by
using an IDE/ATA to USB adapter on another computer or take it to computer store.
To begin the recovery
Remove all external devices like printers, mp3 players etc
Ensure the laptop is running on ac power
You can start the Recovery from outside Windows by holding down ALT and F10 on the Acer BIOS splashscreen on power up.
Jan 19, 2009 | Acer Aspire 5920-6727 Notebook
Recovery mode
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted. http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe You need to put the device into "recovery mode" before you run the tool. - Turn the device off (hold power for 20 seconds) - Slide the hold switch into "hold" position. - Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer. Then run the recovery tool. Select format when prompted. Best of Luck.
Oct 02, 2007 | SanDisk Sansa e250 MP3 Player
Cisco Spa 502g Ip Phone Spa502g Logo
78 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
