Question about Kenwood KDC-MP528 CD Player
Unable to transfer songs from itunes to ipod
Ipod options does not appears on computer.
0 characters
1 Points
Trying to play flash drive in USB port on stereo
Make sure that the music files are indeed mp3 format. An iPod will play several different formats but most av head units only play mp3. A lot of the songs that are downloaded from iTunes are actually mp4
Jun 08, 2014 | Pioneer DEH X3500UI - radio / CD / MP3...
I have an early Ipod classic 60 gb that won't workwith my Alpine
Try looking in you itunes folder for a previous version of the software for your ipod if it worked before. The old copies are saved, unless you deleted those folders also. If you deleted them try searching the web for the old software.
Apr 13, 2010 | Alpine CDE-9850Ri CD Player
USB-IPOD play is stuck. The receiver reads the ipod and tells me what song is up, but will not play. No error message and was working perfectly with same ipod before.
I have the exact same damn problem. It tempermental, whenever it wants to. I never had a problem until a few days ago. Sometimes I turn on my car and it will play a few songs and than when a next one starts it stops, sometimes right from the get go it won't work. Same thing as you though, it displace the song name but doesn't play it. Its so frusterating.
Dec 28, 2009 | Pioneer DEH-P4100UB
I have a jvc kd-g720 stereo in my car and when I plug my iPod into the usb port it says "do not disconnect" and even though i have about 2,000 songs on my iPod the stereo will only play the same 49 ones in...
if you are plugging your ipod into the usb port of the kd-g720 it won't play all your songs because this particular radio only plays mp3s through the usb port. ipods play both mp3s and mp4s. so those 49 songs you're hearing are the mp3s on your ipod. in order to play all the songs on your ipod you must buy the cord that plugs in the back of the radio that will connect to your ipod. sorry for the bad news man. i had the same thing happen to me.
Sep 01, 2009 | JVC KD-G720 CD Player
MP3, IPOD, CD doesn't appear when I press "Source"
If you read your owner's maunal, page 26, the USB is designed for a flash drive (up to 4GB), not an Ipod.
If you would like to play your iPOD, purchase the IPC008 (Ipod Lead) and you're done!
Feb 24, 2009 | Eclipse CD1200 Car CD/ MP3 Player
Alpine CDA-9886 error 1
Try turning off the password lock or password if you have one. That fixed mine. I had an identical problem.
Jan 10, 2009 | Alpine CDA-9885 CD Player
Usb/ipod-no sound
Sounds stupid but did you turn up volume on ipod?
Aug 04, 2008 | Car Audio Receivers
Ipod connection
As far as iPod connections - they will work with a regular iPod and an iPod Nano. You have two options depending on how much you want to spend and how much convenience you want.
Option 1 - Use a Pioneer CD-IB100 adapter. This will plug into the docking port on the bottom of the IPod, charge it, offer control and song information on the head unit. You need to use this one and not the newer CD-I200 cable because your head unit is not compatible with the newer piece.
Option 2 - Use a Pioneer CD-RB10 adapter and a 3.5mm to RCA cable that will plug into the headphone jack of the iPod. You will only get audio input to the head unit but this option is somewhat cheaper.
As far as the clock settings - hold the 'source' button to shut the unit off(key still has to be on). Push the 'function' button until options appear - you can switch between options by repeatedly pushing the 'function' button and adjust settings by using the up/down/left/right arrows.
Dec 29, 2007 | Pioneer DEH-P6800MP CD Player
IPod will not work.
restoring factory settings won't revert the player back to previous ipod software. Check with the alpine website product support and see which ipod software versions are compatible with the car deck you installed. I would think the latest version would be supported. then go to the apple website and download the most recent version of itunes that alpine says is compatible. connect your pod and open itunes. upgrade the pod to that itunes version and try it again with the car deck.
Jul 30, 2007 | Alpine CDA-9883 CD Player
Error message E-60
First, run a chkdsk (or scandisk) to your Ipod from your computer (like any other hard disk drive on your computer)since it is probable that the Ipod's hard disk drive may contain errors. Then, follow these steps: 1.) Disconnect the Ipod from the KCA-IP500(the Ipod interface) 2.) Press and hold the middle button and the top button at the same time. 3.) The Apple Logo should appear. 4.) Reconnect your Ipod to the KCA-IP500 5.) The head unit should display loading and then respond to the IPOD interface.
Nov 08, 2006 | Kenwood KDC-MP232 CD Player
Kenwood KDC-MP528 CD Player Logo
506 people viewed this question
Top Kenwood Car Audio Receivers Experts
xxxxxx xxx
Pablo Gonzalez
Are you a Kenwood Car Audio Receiver Expert? Answer questions, earn points and help others
