Question about Samsung Vivace Mini Split Heat Pump AQV12VBCN - 12K Btu
Fan motor/capacitor not working.
I have a Samsung AQV12VBCN mini-split. The fan motor stopped completely and I got an error code of E1 54. I replaced the fan motor and it worked for a few minutes and then the unit shut down and I got the same error code again. Where is the capacitor located so I may replace it?
  • 121 Answers
SOURCE: i have a samsung ht-tx75 and it keeps shutting
Protection is very likely caused by an over heat condition, even with the fan working if the receiver is in a very enclosed place that warms up and is not ventilated it will cause the problem. The solution is to provide more ventilation so that the receiver can cool itself properly.
Posted on Feb 26, 2009
louislevel_2
  • 374 Answers
SOURCE: Samsung Ac compressor stops after 20 minutes and fan keep running
eventually,cycling process is doing done if the thermostat sense the configure temperayure set up it will trigger to stop your compressor motor as well as the blower fan,blower fan independenly to you compressor.if your thingking that your compressor is tripping off,check your operating current on one line using clamp ammeter and compare to the rated current that tag on
motor compressor body,if the current flow is higher than the rated current specified on compressor motor,well problem occured it will trip your compressor,because overload protector is becoming your thermostat.but if you got same current result it was cycling process.If tripping off maybe air is present in your system call qualified ac tech, to purge out air in system.
Posted on Mar 16, 2009
chipsandnuts
  • 70 Answers
SOURCE: fan chk problem too
it means the home theater is over heating and the unit will shut down to prevent any damage. This can happen if the unit is stacked along with other electronic devices or the unit is in an enclosed area that prevents the unit from cooling properly. To decrease the chance of overheating, relocate your home theater to a more open area.
If the home theater display reads PROTECTION every time you turn it on, no matter where or how the unit is placed, it needs service. To set up service call Samsung Customer Care at 1-800-SAMSUNG (1-800-726-7864). Have your model number and serial number on hand to set up service.
Posted on Jul 08, 2009
Slinteriors
  • 8617 Answers
SOURCE: HLM507W #1 Fan Problem
Yes the set isnt recognizing that after market fan thats why the Fan error is flashing.
Posted on Jul 12, 2009
SOURCE: my samsung split system a/c keeps shutting down,
I have a MH050FX A2 that is two head unit and they run only one at a time, when I turn both on, one will shut down. I get an error code of E2 01 with a, I beleive correction code of U C8. Can you help me with a diagnosis??
Kelly Sheehan
Posted on Jul 27, 2009
Comperasor running e5 problem
Change capacitor motor and outdur working almost
But 3 minute working ok
After E5 error show display screen on indur with outdour fan stop but compressor sound
Apr 23, 2015 | Haier HSU18VC7-G Mini Split Wall A/C Unit
What is a code c1 on a samsung mini split?
Error code = C1 or CH1
Fault = Indoor temperature sensor open or closed circuit.
Jul 26, 2014 | Samsung AQV12VBCN Vivace Mirror Finish...
E4 error on screen
Check out door unit. May be weak in Running capacitor/Fan motor capacitor/Condensor coil dust blocked. First clean and run, if still problem check speed of fan motor, if less replace fan-capacitor.
May 07, 2014 | Midea 24,000 Btu 17 SEER Inverter Mini...
Samsung Vivance mini split flashes E101 and E416, I looked up explanation, but do not understand what it means and how to solve issue
Check and replace room sensor. Once it gets rectified, automatically E416 will go off which means not running of blower motor
Nov 14, 2013 | Samsung AQV12VBCN Vivace Mirror Finish...
Hi I have a goodman MSG-18HWN1 heating and cooling mini-split unit. The unit keeps going on and off on a cycle of about 5 minutes. 5 minute, unit not started, unit starts for about 5 minutes, stops for...
Due to abnormal temp of out door.Check outdoor fan motor and compressor and also sensor.
Fan motor not working- rectify/replace fan capacitor.
Sensor defective-Replace it
Compressor high amps-Replace running capacitor.
Sensor misplaced or defective-Place correctly or replace it.
Jan 05, 2011 | Heating & Cooling
E3 ERROR COMING IN HUKE MINI SPLIT A/C
E3 Outdoor activation of high pressure switch. Due to over charged gas/condenser block/less rpm fan motor.
If overcharged release the over charged gas./clean condenser/replace fan capacitor.
Dec 19, 2010 | Heating & Cooling
Error code Ch 07 ?
Ch-07 Splits = Compressor Over Current or discharge pipe temp high.
Reasons: LC condenser block-Clean it.
Less rpm of fan motor.-Replace capacitor.
Discharge temp sensor defective -Replace it.
Hope, is it helpful?
Dec 17, 2010 | LG LS-L1210CL Mini Split Air Conditioner
Mitsubishi Mr Slim mini split outdoor unit fan.
Check the capacitor. Rating must be within 90% of rated microfarads. If it is a dual capacitor test between C and FAN. Set your meter to read microfarads (uF).
Aug 13, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Condensor fan motor spinning slowly, sometimes in wrong direction? then it stops and goes in right direction but slowly?
it has to be a bad capacitor for the motor. the capacitor is a round or oval metal cylinder with 2 connections on it. it should be 5mf, 7.5mf, or 10mf. the compressor will also have a capacitor sometimes they share a capacitor called a dual run capacitor. the markings on this cap are. herm = compressor, fan = condenser fan motor, and commune = power in. hope this helps.
Jun 16, 2009 | Sanyo 24KS62R Cool Mini Split Air...
Lg split system ch 05 error outside fan not working
Solution # 1, Check Condensor Fan Motor Capacitor 4uf or MFD
# 2, Check Motor Windings
# 3, Check Relay OR Defination Contactor
# 4, Check Connection Terminals
hope will help u 2 solve this
GOOD LUCK
Jan 26, 2009 | LG LS-L1210CL Mini Split Air Conditioner
Samsung Vivace Mini Split Heat Pump AQV12VBCN - 12K Btu Logo
Top Samsung Heating & Cooling Experts
billconfused
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
