Question about Mitutoyo Measuring Tools & Sensors
How do I adjust the ratchet on a mitutoyo 468-957
How to reset depth micrometers , any style , easiest method for Mitutoyo line
The nut on the end of each rod is for calibrations. On a clean flat surface check your reading at "0"and see if adjustment is needed either left or right on the nut for getting before zero or after zero readings. Adjust the nut as little as possible and re check for zero multiple times because the nut is sensitive. hope this helps.
Jun 29, 2011 | Mitutoyo Depth Micrometer 0-6"
How do adjust a mitutoy pro 360 ?
Hello. There are two listings for the 360 pro (seriues 950). here is the link to both, you should be able to get the information you require from these.
http://www.mitutoyo.com/ManualsForm.aspx?group=1438
Failing that, here is the link to Mitutoyo, support services. They will be able to assist you.
http://www.mitutoyo.com/template1.aspx?id=5
Hope this helped, if so please rate a four thumbs up. Thank You.
Mar 29, 2011 | Mitutoyo Measuring Tools & Sensors
My mitutoyo O.D. mic measures .001 bigger than it should. How do I correct this so it will be back in calibration?
If you are certain that everything is clean and otherwise in good condition, adjust it to read correctly by rotating the graduated cylinder with a special spanner wrench typically supplied with the mic. The graduated cylinder will rotate in the frame.
Oct 16, 2009 | Mitutoyo Measuring Tools & Sensors
Large mitutoyo micrometers
I would recommend that you set each rod to zero using a set of jo-blocks to be perfectly accurate. I've been in the trade for 40 + years and this would be best for you. hope this helps you
Oct 15, 2009 | Mitutoyo Measuring Tools & Sensors
I need to adjust a 293-761-30 mitutoyo micrometer.
there should be a small silver spanner with a couple of pins protruding to do that with comes in the box if you haven`t got it come back to me
Aug 15, 2009 | Mitutoyo 293 831 Electronic Digital...
Adjusting the angle of the contact point on a Mitutoyo 513-402
By simply pushing it (the contact point), it may be stiff to start but should ease up over time. Remember if your doing precision work (0.001mm or seconds of a degree) changing this original position will affect your reading so refer to booklet within original packaging or visit mitutoyo website's (Japan, USA, UK) between them they have most instructions available it's just a question of finding it, Good Luck.
May 09, 2009 | Mitutoyo Dial Indicator-Graduations:0....
How to adjust Mitutoyo 505-101 caliber
You don't. What you did to adjust zero is what you do to adjust zero. Do not "go inside to adjust the dial". If the dial reads zero when the jaws are shut there is no problem.
Mar 18, 2009 | Measuring Tools & Sensors
Missing Thimble screw
You can most likely get one at a clock repair shop if Mitutoyo won't help you out.
Jan 22, 2009 | Measuring Tools & Sensors
Measuring Tools & Sensors Logo
Top Mitutoyo Measuring Tools & Sensors Experts
Glenn
Glenn
Dragan Manojlovic
Dragan Manojlovic
Level 1 Expert
Are you a Mitutoyo Measuring Tool and Sensor Expert? Answer questions, earn points and help others
