Question about Takamine G Series 340CLH Left Handed Acoustic Electric Guitar
Can't find a case to fit my guitar
I bought a guitar case recently and it said it would fit but it didn't.. Now I want to be sure about the case size before I buy one. It is a Dreadnought Cutaway left handed guitar. Can you help?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 5 Answers
You are looking for guitar case and fitted to your guitar. So my suggestion is that you have to visit our website you find all things what you want for your guitar. Salvage Custom Shop Building Inspiration Since 2012
Posted on Jun 02, 2016
I lost the cable to connect the guitar the the amp
The connector should be a 6.3mm (quarter inch) mono jack plug. And don't buy the curly cable.
Oct 04, 2012 | First Act 222 Electric Guitar Pack Black
Fender Deluxe Active Jazz Bass buzzing when i don't have my hands on the strings
Try reversing the wires in your input jack. Please repost results. Thanks!
Nov 12, 2011 | Fender Deluxe Active Jazz Bass Electric...
To hook guitar to sound source fendercd60ce
You must have the matching input jack and connecting the guitar cable to the amplifer INPUT and selecting the source will let you play on the guitar.
Check the cables and see they fit correctly.
Oct 18, 2011 | Electric Eyeware Fender Cd-60ce Black...
I tune my bass guitars on the tuner no problem, i have recently tried to tune an electric guitar, but the tuner locks up... any suggestions please.... Thanks ... J
Make sure you have adequate input level to the tuner... some guitars MAY have inadequate output to be recognized CONTINUALLY by the tuner.
Jul 05, 2011 | Korg GB-1 Pitchjack Plug-In Guitar and...
Hi i recently bought a Takamine EG 260c G Series acoustic electric Guitar with TP-4T preamp installed in it. Now the problem is when i connect my guitar to an amplifier, the sound comes through it only...
That is working backwards from what it should be. I suspect a wiring error. Since this is a recent purchase, do NOT risk voiding your warranty. There isn't any real good documentation on the tuner.
I am not sure which tuner you have HOWEVER with one type, the FIRST press will turn on the tuner with the sound going out as well till the tuner goes off. The SECOND press silences the sound and is tuner only, the THIRD press turns off tuner and passes the sound. This is different than a lot of tuners and you will need to do three presses to restore sound instead of the usual two.
May 02, 2011 | Takamine 1 NEW Takamine EG350SC G-Series...
Hi, I have a guild guitar with d-tar pickups. When I plug in a lead (any lead) the batteries overheat massively. (I'm talking about too hot to handle) I don't play this guitar much through amps, but...
Plugging in the guitar cable closes the battery circuit in the guitar. The circuitry in there has a short that when the battery is connected draws massive battery current. The circuitry needs to be troubleshot to find the short. You can troubleshoot this wit just a multimeter. Of course if you have a warranty, exercise it. The short could be most anyplace and since unit is new, it may even be a wiring error. A visula inspection may uncover a solder bridge or a pinched wire. Forst investigate warranty.
Mar 17, 2011 | Guild F50R Vintage Jumbo AcousticElectric...
Need size of truss rod wrench. i need a manual
Takes a standard 'Allen Key' hexagonal wrench (I'm not sure of the size for your specific guitar but most are around 5 or 6mm)
Basic Epiphone manual here
http://www.epiphone.com/images/EpiOwnrsManul.pdf
Feb 17, 2011 | Epiphone AJ220SCE AcousticElectric Guitar
I bought a Hagstrom Ultra Swede which sounded very nice when I first bought it but after 3 months I seem to have alot of tuning problems with it. It has been intonated twice and a new set of heavier...
Considerations:
1. Intonation problems can be due to worn strings even if the guitar is set up properly. New Strings can fix this. This is the most common problem.
2. Also, changing string size may effect your set up too. Typically, new guitars come with lighter strings such as (9's) which the guitar is set up for. The positive is that 9's fret easily. The negative is that they bend too easily for some players who either slightly bend them when chording (accidentally), or press too hard on guitars with jumbo sized frets, which in turn bends the string toward the fret board causing detuning. To fix these items folks may suggest you get a heavier string like a (10), but the problem can often be solved by playing with a lighter hand, pressing only enough to make contact with the fret and not pressing the string all the way to the fretboard. Check your intonation using this light touch method and see if it's okay verses pressing the string all the way to the fretboard. If the intonation is okay with the light touch, the guitar intonation is set up properly. You may want to consider playing with a lighter hand or getting a guitar without jumbo frets such as Fender strats etc...
Putting a heavier string on a guitar set up for (9's) would likely cause the buzzing that wasn't there before. In this case you'd need the guitar and neck set up again to accomodate the 10's. So decide what size string you want and set the guitar up for that size.
These considerations are true for any electric guitars.
After consideration of all of the above, you still feel it's the guitar, I suggest you push for a replacement or perhaps credit toward another guitar.
Oct 18, 2010 | Hagstrom Swede Electric Guitar Natural...
Takamine G Series 340CLH Left Handed Acoustic Electric Guitar Logo
20 people viewed this question
Top Takamine Music Experts
armandog07
armandog07
Ted Maxwell
richie46
Are you a Takamine Music Expert? Answer questions, earn points and help others
