Question about Compaq Presario 700 470024-192 Notebook
Userinit.exe gives an application error .. - Compaq Presario 700 470024-192 Notebook
  • ron beram
    ron beram Feb 07, 2014
    After installing "manycam" shareware....the userinit.exe started giving me trouble as well as another dll. Cant get info on what dll's the application may have accessed or registry files? many bad rumours on the manycam software...let me know ifya can fixya!
    Top Expert:
  • Compaq Master
  • 26,730 Answers
Can you go back to an earlier time with restore point? That would be the easiest way to overcome this issue. If you run Advanced System Care or any good quality Registry Cleaner then remove the Malware that is giving you the problem.
Posted on Feb 08, 2014
HAL.DLL is missing or corrupted, xp doesn't boot
if it was running for more than 30 hours, it wasn't doing much. You can try copying hal.dll off of a known, good-working XP pc, and replace it with the one on your broken PC. It's better if you extract it from i386 folder but grabbing it from another pc should work fine.
If you need further help, reach me via phone at https://www.6ya.com/expert/brandon_bf4b4a06876c89a0
Aug 09, 2012 | Microsoft Windows XP Professional
Tip
How to fix system immediately logging off when you log on
The issue is the result of a change of the USERINIT key in the registry under the following registry key:
HKEY_LOCAL_MACHINE\SOFTWARE\MICROSOFT\WINDOWS NT\CurrentVersion\WINLOGON\USERINIT
The correct string is USERINIT=C:\windows\system32\userinit.exe
to do this you will need a bartPE or other cd that is bootable and will give you access to the NTFS files system and the registry. One is the Ultimate Boot CD: http://www.ultimatebootcd.com/download.html
This issue is caused by Malware that has usually been removed from the system but the removal tool did not correct the USERINIT registry key that was changed by the Malware (Usually to C:\windows\system32\winlogon or some variant.
on Mar 05, 2010 | Computers & Internet
How to fix userinit.exe(0*80000003)
use the installation cd or dvd to repair your os
Mar 21, 2012 | Lenovo Computers & Internet
Laptop logs off when i log on. what can i do
Edit these values and type the correct path of shell :
Shell = explorer.exe
Userinit=X:\windows\system32\userinit.exe
NOTE: These files may also be deleted by spywares. You may need to extract them using Windows CD.
Steps for rectifying this problem:
Log on to a networked computer.
Run Regedit.exe
Point your cursor to HKEY_LOCAL_MACHINE
Select File > Connect Remote Registry
Type computer name (infected computer)
Navigate to the following location in registry of destination or infected computer
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Winlogon
Edit these two values in right pane:
Shell
Userinit
Change these two values to
Shell=explorer.exe
Userinit = x:\windows\system32\userinit.exe
Exit from Registry
Restart Infected computer.
You should be able to log on to computer.
if it not work then go to back steps and just copy orwrite the file userinit.exe
Performing the above steps will resolve the issue.
Hope this helps.
Jul 07, 2010 | Dell Latitude D400 Notebook
Help
First I used knoppix to check whether userinit.exe exists in C:/windows/system32, it was there. Then I checked explorer.exe to be there in C:/windows. Then I tried to copy an userinit.exe / explorer.exe of my pc to this pc but this did not solve the problem.
Then I tried to logon remotely to the registry without success.
Finally I used an unix regedit tool to check the registry (used 2nd option under http://www.raymond.cc/... In the registry everything was fine, pointing to "C:/Windows/system32/userinit.exe,".
I also checked permissions on these files with knoppix, everything fine.
Finally I got it working by doing the following:
1) copying C:/Windows/system32/userinit.exe to C:/Windows/system32/userinitnew.exe
2) using tool from above to edit registry and set the winlogon value to point to userinitnew.exe
Jan 02, 2010 | Acer Aspire One PC Notebook
Windows logon.exe error in XP
try thease steps 1. Insert a XP CD (any XP install CD will do for this procedure) and boot up.
2. When asked, boot to the CD by hitting the Enter key.
3. After a short while, a menu will appear.
Select R for repair.
4. Next, you will be asked which Windowsmag-glass_10x10.gif installation to use. Hit the 1 key on your keyboard and then Enter (assuming it is the C drive).
5. You may be asked for an administrator password. At which point you will need to enter it or hit Enter if their is none.
At the resulting C:\Windows> prompt in the recovery console , type 'CD System32' (without the quotes).
6. Next type:
'copy userinit.exe wsaupdater.exe'.
7. Exit and reboot normally. You should now be able to logon. But you're not done yet!
8. Run regedit from the Run line.
9. Find the Userinit key in:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\
10. Modify the entry:
C:\WINDOWS\System32\wsaupdater.exe
so that it reads:
C:\WINDOWS\System32\userinit.exe
May 20, 2009 | Computers & Internet
Hey helpful people!! My Acer laptop has a similar problem:" Userinit logon application" This program is closing down. Now the laptop is on BUT the START MENU is NOT AVAILABLE. Can someone out there post a...
You've got the wrong entry in your registry.
Userinit string should be:
C:\WINDOWS\system32\userinit.exe,
Note the trailing comma which must be there.
Often this entry is damaged by malware.
Ways to deal with this:
  1. Install Windows on a second partition, load the damaged registry hive and fix it.
  2. Boot with a Bart's PE or ERD Commander and fix the registry entry.
Or if you manage to get the register editor running just fix the registry key.
In the register you have to go to:
HKEY_LOCAL_MACHINE/SOFTWARE/Microsoft/Windows NT/CurrentVersion/Winlogon
Find the line named: Userinit
Make sure it points to: C:\WINDOWS\system32\userinit.exe,
If it doesn't exist, make one, if it doesn't point to the same place, change it.
CHeers
Apr 14, 2009 | Microsoft Windows Vista Ultimate Edition
Startup issue
Ok, that rules out the problem some systems with an AMD processor have with SP3.
Before we try anything else, unplug the computer, remove the battery and leave it like this for a few minutes. But the battery back, plug it in and try it.
If that does not work you will need you windows CD.
Put it in the drive & boot to the CD
You need to press R and go to the recovery console
type chkdsk /r
If this does not work, repeat and this time type fixboot
Oct 10, 2008 | Toshiba Satellite A105 Notebook
M3plugin error
Jul 11, 2008 | Intel Motherboard
Compaq Presario 700 470024-192 Notebook Logo
29 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
