Question about Fender Music
Serial number id
Squier fender tele
  • 1137 Answers
SOURCE: Need Fender Squier Bullet 1 w/3 pickups, 1 vol, 1 tone wire diag
I think this is what you are looking for:http://www.squierguitars.com/pdf/current/Strat/Bullet%20Strat%20with%20tremolo-%20Service.pdf Please let me know if this helps.
Posted on Dec 10, 2009
  • 5603 Answers
SOURCE: I have a Fender Squier Strat. The Whammy bar is
There are MANY tricks to remove a threaded piece like this:
1. With a Dremel tool and a cutoff carborumdum disc cut a shallow slot in the remaining piece and use a straight bladed screw driver to remove. This can only be done if the screw is above or flush with the surface.
2. Carefully drill a small hole in the piece fairly well centered. Use an "EasyOut" to remove the broken part.
3. Carefully drill several small shallow holes on the top of the broken part in a line so as to form a slot for a screwdriver.
4. Carefully drill a hole JUST the right size into the broken part and then drive an Allen wrench into the hole to turn the broken part. The hole has to be just the right size so the wrench can peal tiny pieces off to grab the broken part.. this is tricky to get the size just right.
5. Use a detist drill to cut a slot.
In all these use a penetrating oil or CRC226 to make it easier to turn.
Posted on Mar 09, 2010
  • 61 Answers
SOURCE: have a fender squier 4 and wondering if you plug one side can you get full mano output?
What do you mean by "Plug one side"? Your guitar is mono....you plug into the channel with a mono signal cable....as long as you're panned to center on your channel strip, you would have full mono sound out...ie sound equally from both speakers. Usually you would be running your board in mono anyway.
Posted on Aug 19, 2012
  • 168 Answers
SOURCE: fender serial number lookup
I think it is from 1976 You will need to take it to a music shop to get the value.
Posted on Mar 08, 2014
  • 37 Answers
The easiest remedy is to buy and install a used Squier tremolo (trem) block - they are very cheap and unscrewing the bridge is less work than trying to remove a broken threaded rod from a tight and barely accessible space. If you want to increase the sustain and have a more responsive tremolo, replace the small alloy block with a solid steel block or a brass block. They aren't that much but the sustain difference is worth every penny.
Posted on Feb 02, 2015
What year and model is my fender squier sn.CCA-0020707453 model # 093-0300-149. Howmuch is it worth? Excellent condition.
Try this site, they have a lot of serial number info...
http://www.guitarrepairbench.com/guitar-dating/fender-serial-number.html
Typically a Squire guitar is worth around $100 less for a used one...
Hope this helps?
Mar 17, 2015 | Fender Music
How much is my Fender electric guitar worth?
It varies depending on condition and your particular market, but in my market a used Squier Standard in good shape runs $125-150.
Nov 12, 2014 | Fender Music
I have a Fender Squier Stratocaster Standard HSS. Serial number: ic071104059. i am trying to determine the year and specifications
It was made in 2007. If you call Fender directly they can sometimes id the exact model version from the serial number. The records they keep on Squier guitars is a bit sketchy, but sometimes they can help.
Oct 11, 2014 | Music
I have a fender strat with serial number snic9055475 can you tell me if it is authentic or where it was made
It is an Indonesian made Squier from 1990. It's doubtful anyone would fake an Indonesian made Squier.
Sep 28, 2014 | Fender Music
Squier serial numbers
According to my Squier book the IC prefix is Indonesia and the first two numbers are the year of production. So it seems to be a 2000 or 2001.
Aug 14, 2014 | Fender Musical Instruments Corporation...
Fender squier serial numbers cgs1041980 what year
http://intl.fender.com/en-CA/support/ Click on Squire at the top or this link:http://intl.fender.com/en-CA/support/articles/?section=articles&category=product-dating
Jul 27, 2014 | Fender Music
Music Logo
11 people viewed this question
Top Fender Music Experts
dave nyman
Level 1 Expert
Matthew Spark
Matthew Spark
Larry Stiles
Larry Stiles
Are you a Fender Music Expert? Answer questions, earn points and help others
