Question about BenQ MX710 3D Projector
The projector is powering off every 5-10 mins, then restarts after the next 5 mins.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 729 Answers
1,the color starts to go out, it become the white and black ,
2,then,the projector running off after only a few minutes,
it is a general issue:the inductor need to be cleaned
Use a cotton swab moistened with alcohol to clean the inductor.
the inductor (Sensing element),is near to the Color Wheel.
the industor : is a black little element,as little as a sesame seed
any questions, feel free to ask me
have a nice day!
Jerry Lampdeng Limited
Posted on Mar 04, 2014
My InFocus SP5000 projector does not power up instead the power button flickers to the beat of a rapid ticking sound which is coming from the speaker on the projector. The lamp does not illuminate nor does...
Before I changed a lamp (expensive) I would try these techniques:
Clean the fan filter under the unit. It is little porous pad under a vent. Vacuum it or Wash it, let it dry THOROUGH:LY replace it with a factory filter, or make a new one out of garden variety air conditioner filter material. Reseat the filter and the cover.
Plug in power cord.
Restart projector. Hold down "on" button and see if it lamps up. If not, press "off" button and attempt to restart. It might have gone into a thermal shut down mode due to a clogged fan filter. I do a/v presentations and have encountered these issues on the road and I always try this simple fix first. I also always carry a spare projector.
Mar 12, 2011 | InFocus ScreenPlay 5000 Multimedia...
Mx4000 128mb on xpsp3 problem
in windows power settings, you ajust the time the monitor runs and shuts down one setting is do you want the monitor to stop after 5,10 or so mins you answer never that will cure the shut down
Jul 06, 2010 | XFX GeForce MX4000, (64 MB) Graphic Card
Hitachi ED-X8250 - Turns off after 15 mins LAMP and POWER = RED
try looking for your thermistor usually located near the wind path its a small block the size of two match heads usually mounted off the main board with two wires this is your 'heat switch' so to say, also check your fans are clean and running there is normally more than one.
May 15, 2010 | Hitachi ED-X8250 Multimedia Projector
reset the lamp and filter timers. turn the projector off then back on.
Mar 29, 2010 | Hitachi ED-X8250 Multimedia Projector
Power light blinking red
if the lamp goes out after the red led goes on, there is a fan issue and the projector is overheating or the ballast/power supply can't hold the voltage.
Aug 04, 2009 | Sanyo PLC-XU47 LCD Projector
My Infocus DLP 4805 can't turn on
very possible the lamp is bad. Many projectors will not even power on once the lamp burns out. As for the strange noise, there may be something more serious wrong with it.
Jun 22, 2009 | InFocus ScreenPlay 4805 Multimedia...
Infocus LP 280 runs for 1 min then shuts down, runs again then
are the leds on the top lit or blinking? it could be the lamp, the ballast, or the fans. check the lamp. if there are black spots or bulges in the lamp, replace it. if not, make sure the fans are running. if they are, replace the ballast.
Jun 09, 2009 | InFocus LP 130 Multimedia Projector
Wait time for restarting projector/
You were right about the shut-down time. We had an older InFocus projector at work that had the cord yanked (by the presenter no less...) which cost us a near $400 in repairs. A LOT of heat is generated in these machines and proper cooling is absolutely essential to their operation.
Jun 02, 2008 | Mitsubishi HC3000U Multimedia Projector
EP 757 Intermittent powering down
Pls check if the lamp is not so old that is giving the same problem. If lamp is almost new, then you can have a check with the Ballast unit card and then the loose connection in the Power supply or may be overheating and tripping.
Viren
Nov 18, 2007 | Optoma EP737 - DLP PROJECTOR - 1500 LUMENS...
Projector will not power on
Check your cooling solution wether its a fan malfunction or if it needs a new fan - or h20 cooling system
if not its either the power supply or something serious - send it to manifacture or go to a in-store repair
(it could be the dust protector)
Nov 16, 2007 | InFocus ScreenPlay 4805 Multimedia...
BenQ MX710 3D Projector Logo
54 people viewed this question
Top BenQ Office Equipment & Supplies Experts
Tom Chichester
Electro Med Services...
Tony
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
