Question about Canon MP-25DV Calculator
How do I get the date to print on my tape
I am using this machine for my classwork in college. How do I get the date to print on the tape?
Print receipt casio
Next to the date/time button , there is a button written receipt/on/off
press that one once...good luck
Jul 08, 2013 | Casio PCR-T2000 Cash Register
Activation code for Pastel v11 education pack
You can change your system date to an old date. When you open pastel the company will not be available in the OPEN A COMAPNY window. CREATE a NEW company. Use COPY ANOTHER COMPANY option and copy the last company you worked on. You will be able to proceed with your lesson.
Mar 14, 2013 | Computers & Internet
I have a brand new Epson CX4200 printer that I got this summer with my macbook before college. I got to school and the printer will not work. It keeps saying that there is a paper jam, except there is no...
Considering it has never printed properly. I would power down the printer and unplug the USB cable and power cord and do a complete re-install.
Go here to download an updated driver for your printer and operating system. The CD that came with the printer may have had an outdated driver for your operating system.
Follow the Quick Install Guide . Make sure the printer was properly unpacked and all tape and packing material were removed. Install the new driver and when prompted connect the USB cable. Follow the Guide and on-screen instructions.
Trust this resolves your problem.
Dec 15, 2010 | Epson Office Equipment & Supplies
Date and time reset
To set the time: First set to Rate to "SET" then say for example the time is now 1:33 p.m. enter 13 then hit the decimal then enter 33 hit the decimal then hit the time key and you are set.
Jan 22, 2010 | Sharp EL-1750PIII Calculator
Ican't send my fax to Manatee college. All the time report shows
If it is just thier phone number they may have a fax that is old or not up to date with industry standards. Since this is a college I think they have a newer machine. Thier could be some line noise. I would email or snail mail it.
Dec 18, 2008 | Canon FAXPHONE L170 Plain Paper Laser
My brother is the stupides brother in the hole wide world.
http://welcome.solutions.brother.com/BSC/public/us/us_ot/en/faq/faq/000000/000700/000034/faq000734_005.html?reg=us&Printable=true&c=us_ot&lang=en
Date:06/13/2008 ID:faq000734_005 Print | Close
Title:
Why does my machine's LCD show "NO CARTRIDGE" even though I have already installed all the ink cartridges? Description:
An ink cartridge is not installed properly. Check that the ink cartridges are installed properly and reinstall the ink cartridge following the procedures below:
  1. Open the ink cartridge cover door.
  2. Push the 4 colored levers down to release all four ink cartridges from the machine.
  3. Each color has its own correct position to match the color of the cartridges with the color of the levers. Insert all of the ink cartridges in the direction of the arrow on the label until it clicks into place.
  4. Close the ink cartridge cover.
  5. If you replaced an ink cartridge, the LCD may ask you to verify that it was a brand new one. For example, Did You Change Black? For each new cartridge you installed, press the up navigation key or 1 or "+"(Yes). If the ink cartridge you installed is not a brand new one, be sure to press the down navigation key or 2 or "-"(No).
If you mix the colors by installing an ink cartridge in the wrong position, clean the print head several times after correcting the cartridge installation.
Once you open an ink cartridge, install it in the machine and use it up within six months of installation. Use unopened ink cartridges by the expiration date written on the cartridge package.
If you have followed this procedure and still have the same error condition, make sure you are using Brother Genuine Supplies. Generic supplies can cause this error condition.
If the problem continues after verifying the cartridges are installed correctly and that you are using Brother Genuine Supplies, then there may be a problem with the unit. Please contact the appropriate Customer Service Center.
Sep 26, 2008 | Brother MFC-5840CN All-In-One InkJet...
Date and Time Setting
You can download the manual for the 1260-3 which I guess is very similar from the link below: http://www.victortech.com/admin/images/products/1260-3%20manual.pdf Here are examples of the date & time setting: Set DATE to September 14, 2004 (09-14-04) 1. Depress the C or C/CE key.Your display with show 0. and the tape will read 0.C. 2. Depress the TIME/DATE key and hold until the display is flashing. 3. Enter the month, in our example, 09. Your display will show 9. 4. Enter the day, in our example, 14. Your display will show 914. 5. Enter the year, in our example 2004, as 04. Your display will show 91404. 6. Tap the TIME/DATE key to set the DATE. Your display will now show 09-14-2004. 7. To PRINT the DATE, depress the (#/S) key, your tape will show # 9.14.2004. Set TIME to 4:37 PM 1. Depress the C or C/CE key. Your display with show 0. and the tape will read 0.C. 2. Depress the TIME/DATE key and hold until the display is flashing. 3. Tap the TIME/DATE key to go to Time Mode. 4. Enter the hour, in our example 16 in military time. Your display will show 16. 5. Enter the minutes, in our example 37. Your display will show 1637. 6. Tap the TIME/DATE key to set the TIME. Your display will now show P 04-37-00 and the seconds will begin counting. 7. To PRINT the TIME, depress the (#/S) key, your tape will show #?04?37. Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 17, 2007 | Victor 1260-2 Calculator
Print Report for Specific Date
I haven't found a way to print a TX report for a specific date. However there is a way to set the machine to generate an activity report at a certain time each day. Press "MENU" , 2-4-2, and you should be able to select the interval for your report by pressing the "OR" key (24 HOURS in this case). Hit "MENU" again and then enter the time you wish the report to print (24 hr format). "MENU", "STOP" and that should give you a report you can use each day.
Apr 23, 2007 | Brother IntelliFAX 2800 Laser Fax
Canon MP-25DV Calculator Logo
41 people viewed this question
old marine
old marine
