Question about Yamaha PSR-E413 Portable Keyboard
Keyboard comes on but doesnt produce sound - Yamaha PSR-E413 Portable Keyboard
Psr 330 no sound when playedbut demo works perfect& produces sound
Most likely the keyboard connection is broken. This will need to go to the shop, it's not user fixable.
Jan 07, 2017 | Music
Why do keys produce no sound?
Hi Kyle:
Have a look at your manual.
Sometimes you'll find that there will be an "input" setting required.
You might also try google with his link.
https://www.google.ca/#q=Williams+Allegro+88-Key+Digital+Piano
Hope this helps.
Cheers.
Oct 13, 2015 | Williams Allegro 88-Key Digital Piano
The ACMP function doesnt work when I play, even tho it says it is on in the display window
Check you have selected 'sync start'. The ACMP selection activates the automatic chords but not the rhythm, so each note produces a droning chord. Sync start activates the automatic chords and rhythm you have selected when you play anywhere near the bottom end of the keyboard. Alternatively you can manually press play to start the drums by themselves and then the chords will begin the moment to play with your left hand.
Mar 12, 2015 | Yamaha PSR-E413 Portable Keyboard
Yamaha psr 300
I'd suspect power supply first - filter capacitors may have leaked/dried out. That would be an easy fix for someone familiar.
Mar 05, 2014 | Yamaha Full-Size Keyboard
KORG SP-250. Keyboard powers up, you can change all selections, five or six random notes sound, but the other keys produce no sound at all.
There is probably a cable loose that connects the keyboard itself to the processor... OR the key contacts have been contaminated by spilled liquid. The keys are scanned as a matrix. The contacts will be a conductive rubber pressed against circuit board traces. Clean contact "pills" and the circuit traces with ONLY 99% isoprophyl alcohol.
This is NOT for the unskilled to attempt a DIY other than carefully opening and looking for a cable that has come loose.
Mar 22, 2011 | Korg SP-250
Just purchased, certain keys produce no sound
Are the silent keys random or in a pattern (e.g. a group of adjacent notes, every B and G or just all over the place)?
Unless you have got a keyboard split in operation (dividing the keyboard into two separate sections so that you can have a different 'voice' in each part) and have failed to allocate a 'voice' to one of them you have to suspect either a faulty keyboard module or a faulty processor.
If you bought it from new take it back under warranty. Otherwise it will be a job for a qualified engineer with the appropriate test equipment.
Feb 10, 2011 | Casio Ctk 496 Electronic Keyboard with 61...
Keys not responding on my keyboard.
It needs to be plugged in to a computer with a DAW to produce sound. The DAW converts the information sent by the controller about which key is pressed and how hard and converts it into sound with a virtual instrument
Jan 19, 2011 | M-Audio Axiom 49 49-Key Semi-Weighted USB...
1 key is not producing any sound its D.. n the midde c.. is sumtimes producing a sound n sometime its not.. kindly tell wat has happend to my synth psr i425
Key contacts are dirty. You will have to service the unit. The contacts (two per key) are conductive rubber "pills" that press down on circuit traces under the keys. Use ONLY 99% isoprophyl alcohol and Q Tips to clean both the black pills in the silicone domes and the circuit traces themselves. Be gentle when doing this. When opening the unit, be careful of all the cables as they are easily damaged.
Nov 01, 2010 | Yamaha YPT400 61 Key Portable Keyboard...
Casio keyboard lit up, no sound, no responses
Unplug for several minutes and try again.
If that doesn't work, look up the "factory reset" procedure for your particular model via google and follow that procedure. It usually involves holding certain buttons down before and during power up.
Jul 20, 2010 | Casio Music
No Sound
You didn't give any specifics. Possibly it is just broken due to a loose cable to the keyboard (which you could look inside and check) or a burned out semiconductor (harder to check).
If it is a MIDI keyboard, usually symptoms like this are due to a "MIDI Channel ID" problem. It is sending the keyboard on one MIDI channel and whatever is producing the sound is listening on another. For this sort of thing, you can substitute devices to narrow down the problem or try to reset everything, removing all the batteries, if any, and checking the manuals or website for reset instructions. Of course, you may lose stored settings that way.
Jul 01, 2009 | Music
Yamaha PSR-E413 Portable Keyboard Logo
14 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
