Question about RCA 25255RE2 - - Phone
Record greeting on 25255RE2
I can not record a greeting, how is this done?
How to record a new greeting
  1. Go to Google Voice.
  2. Click the gear icon at the top right of the Google Voice window and select Settings.
  3. Click the Voicemail & Text tab.
  4. In the 'Voicemail Greeting' section, click Record New Greeting.
  5. Enter the name for the greeting you're going to record and click Continue.
  6. A "Record Greeting" box will appear. Select one of your forwarding phones from the "Phone to ring" drop-down menu.
  7. Click Connect.
  8. Google Voice will call you on the forwarding phone you selected. Pick up the call and record your voicemail greeting when prompted.
  9. Once you've recorded your voicemail greeting, make sure it's selected in the 'Voicemail Greeting' section of your Settings.
  10. Click Save changes at the bottom of the page.
Mar 17, 2016 | Lands Phones
How do I record a mailbox greeting on Avaya 1408?
Hi Tourmaster,
I have these steps for you on how to do it. Hope it helps.
Mailbox Greeting While the voicemail system will play a generic greeting to caller, prompting them to leave a message, you can record your own greeting.
1. Press the key%20messages.zoom50.png MESSAGES button. Depending on how your system is configured, you may be required to enter your voicemail password and then press the Done soft key. The visual voice menu is displayed.
2.Use the up and down arrow keys to scroll to the option Greeting.
2.Press the Select soft key or OK.
3. Use the soft keys to listen to and record your mailbox greeting.
Listen
Listen to the current greeting or the new greeting just recorded.
Record
Record a new greeting. Note that the greeting must be at least 3 seconds long or the voicemail system will discard it.
More
Switch between the different sets of available soft key functions.
Submit
Submit the new recording as your mailbox greeting.
Delete
Delete your current mailbox greeting. The voicemail will use its default greeting.
Apr 28, 2014 | Avaya 1408
I have the uniden dect 6.0 3 handset. I lost my manuel and do not know how to record my answer message
Which specific Uniden DECT 6.0 phone do you have? There are a number of them. Uniden has the manuals available here: http://www.uniden.com/bin/venda?ex=co_disp-view&bsref=uniden&scat=dectphones_mnl . Phones are listed in alphabetical and numerical order.
If the answering system is off, turn it on before proceeding to the following steps.
If you are at home, there are usually two methods to access the answering system. Some Uniden phones let you set the outgoing message from the base or the handset. Others will only let you set the message from the handset. (Calling in remotely is more complicated.)
To access the answering system menu from a handset, on some models, push the Mute/Messages button. Then let your current message play or press 5 to stop the recorded announcement. Then either use the up/down arrows to select Record New Greeting (or the number that matches the sub-menu item). It's number 8 on the DECT1480. Then wait for the prompt (tone or "Record Greeting") and then speak into the handset clearly. Press 8 to stop recording and press End to save the message. Press 6 to select the outgoing greeting if a default greeting is available.
On other Uniden DECT phones, press Menu and go to Ans Setup. Then choose the line for the greeting (if it's a multi-line phone) and then select Record Greeting. Press Start, wait for the prompt and then press Stop when done. Press Stop again to save the message. If there is an optional pre-recorded greeting, use the Greeting Option submenu to select the greeting to play. (This applies to the DECT4086.)
From the base, you'll do something similar. However, you should stay about 9" from the microphone while recording. Messages can be between 30 seconds and 3 minutes 30 seconds for most systems.
I hope this helps.
(recording a new greeting during a remote call can be done but consult the manual for details.)
Dec 21, 2011 | Uniden DECT 6.0 Cordless Phone ID
HOW DO I SET UP (RECORD) AN ANSWERING MESSAGE?
From the base, press and hold the GREET button until you hear the prompt. Record your greeting at the beep. Press the GREET button when done.
You can download the manual here.
Sep 23, 2011 | Uniden DECT 6.0 Cordless Phone ID
Record a greeting?
Hold down the GREETING button. Record your new greeting at the beep. Release the button when done.
The instructions are on page 9 of the manual at
http://www.home-electronics.net/ge/pc/IB/29871GE3_IB.pdf
Apr 12, 2010 | GE 29871GE3 Digital Answering Machine
The automated recording that comes on when the lines are full needs to be changed and the recording of an employees name on the directory needs to be changed. I have already changed the display name on the...
The persons name is recorded in their personal mail box.Thats done by pressing open voicemail or feature 981 followed by their password, press 8 or admin and press 1 to re record thier name in the company directory.
To re-record greetings, enter Feature 983. if your system has 2 digit intercom #s your default password is 120000 if your system has 3 digit intercom #s your default password is 1020000. once you have entered the password you will see 3 selections you can make .use the three soft keys under the display and select AA (auto Attendant). next press greeting and greeting again. next it'll ask for the greeting number your probably working with greeting 1. press record to start and ok when finished. dont forget to save the greeting or it will be deleted if you exit early. hang up when finished.
Apr 06, 2010 | NorStar M7310 Corded Phone
Record greeting
Press and hold the desired GREETING button. Record the greeting at the beep. Release the button when done.
You can download the manual at
http://www.home-electronics.net/USER-GUIDES/29869_DOM_ES_AN_IB.pdf
Apr 01, 2010 | GE 29869GE2 Digital Answering Machine
How do you set up the message for the answering machine? Lost the instructions that came with the unit. I know the phone has a menu, but not sure if this is where I would program the answering machine.
Greeting message
When the unit answers a call, callers
are greeted by a greeting message. You
can record your own greeting message
or use a prerecorded greeting
message.
Recording your greeting
message
You can record your own greeting
message (max. 2 minutes and 30
seconds). If you do not record a
greeting message, a prerecorded
greeting message is used.
1 {MENU}
2 {V}/{^}: “Answering device” i
{OK}
3 {V}/{^}: “Record greeting” i
{OK}
4 After the handset beeps, speak
clearly about 20 cm (8 inches) away
from the microphone.
5 To stop recording, press {OK}.
6 {OFF}
Using a prerecorded greeting
message
If you erase or do not record your own
greeting message, the unit plays a
prerecorded greeting message for
callers and ask them to leave
messages.
Sep 11, 2009 | Panasonic KX-TG1033S Cordless Phone
Nortstar M7324
In order to record an alternate greeting, you sign into your voicemail. Select Admin, Select Greet, Select Choose (and select which greeting you would like to use eg..Prime or Alt) Once you select the greeting. The voicemail is set to use that greeting. To record that greeting, go back into Admin, Select Greet, Select Rec, and record and save your greeting.
May 30, 2008 | NorStar M7324 Telephone
Changing the message
when your done listining to voice mails go into admin options you can change you greetings there and record new greetings there
Sep 23, 2007 | Motorola Mobility RAZR V3
RCA 25255RE2 - - Phone Logo
48 people viewed this question
Top RCA Lands Phones Experts
Are you a RCA Lands Phone Expert? Answer questions, earn points and help others
