Question about Samsung SMH1816S Microwave Oven
Samsung microwave oven will not come on
Began smoking and loss power due to breaker switch, reset switch, microwave came back on but loss power after a few seconds of use. Now will not come at all. No power
4 Suggested Answers
MicrowaveSvc
  • 9047 Answers
SOURCE: Samsung MU3250W Shut down
It could have been steam or humidity.
If this is an over the range model, be sure you always use the hood vent exhaust fan when you're cooking on the stove top.
Whether it's a counter top or over the range top, always be aware that the cooling fan is running when it's cooking.
When in doubt feel for air flow through the vents.
Good luck.
Posted on Oct 19, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Samsung MW1080STA Microwave Oven
This is due to a defective or loose magnetron causing electrical interference and disruption in the control circuit board.
If your magnetron was recently replaced, it may have loose mounting nuts or bolts or maybe the wire mesh RF gasket was not installed or got pinched.
It may also need a new high-voltage diode and stirrer, and the cavity may be affected.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
You can order Samsung parts here.
You can find your nearest Samsung-authorized service center here.
To find out if yours was recalled, please call Samsung's Service Division at 800-932-3837.
Posted on Nov 21, 2008
citroenchris
  • 600 Answers
SOURCE: I have a MW5582 Microwave Oven and about a week
Most likely the surge blew one of the 2 diodes inside, if you know basic electronics it it an easy fix
Posted on Jul 15, 2010
Testimonial: "Thank you, is Diodes another word for Fuse?"
No power, no lights, no clock. Nothing works on my Samsung over the range microwave model SMH17138
Your microwave may be plugged into a regular receptacle which is on a circuit breaker often in a cupboard above the range.Check around to see if anything else is not working. Check your circuit breaker box for a breaker that needs resetting. If you see one out of line with the others turn it off and then back on. Good luck..
Dec 09, 2016 | Samsung Microwave Ovens
Samsung SMH9151 trips breaker when plugged in
You have a sort circuit inside, call a repairman or take to the repair shop
Aug 23, 2012 | Samsung SMH9151 Microwave Oven
Microwave stops randomly on its own, dispaly flickers and I get prompted to enter clock settings, what should I do to fix it
When a microwave asks for the clock settings, it has lost power. Check the plug and the outlet for damage or if it is loose. When on, vibrations can cause the plug to reposition if loose enough. Even a very short loss of power will reset the microwave. If the plug/outlet is ok, then check to make sure that the fuse for the outlet is tightened fully (breaker switches do not have this problem). Last, try another outlet as the wiring to the outlet may be loose.
Feb 11, 2012 | Danby DMW773 Microwave Oven
No power to microwave
Hello
Check the Power Cord
Verify that the power cord is properly connected the outlet; the plug might have been removed to make way for another appliance. Do not connect the microwave to an outlet via an extension cord or plug adapter; the oven must be directly connected to an outlet.
Switch the Outlet on
Turn the outlet on, if possible, using the switch on the wall behind the counter or on the plug itself. Some microwaves have a separate power switch that must be in the correct position before you can begin cooking.
Reset the Oven
Unplug the oven, wait a few seconds and reconnect the power. A power surge could have temporarily rendered the oven inoperable. The oven should start up as normal when you connect the plug to the outlet.
Check the Fuses and Breakers
See that the fuse or breaker protecting the oven's circuit is still active. Replace the fuse if it has blown, or reset the breaker to restore power to the oven. Stop using the microwave if it repeatedly blows fuses or trips breakers.
Oct 04, 2011 | Microwave Ovens
Microwave pops hose breakers. Microwave gets
The problem is in the microwave oven, you have a short in the power supply or it could be a defective door switch, either way the unit needs to be checked out.
Feb 27, 2011 | Emerson MW8102SS 1100 Watts Microwave Oven
We lost our electrical power, when it came back on, the electrical panel (clock).. began blinking. The clock re-set with no problem. But, now the microwave won't work. I simply get a message that says...
Sorry to read about your problem, I hope this helps you out.
Anytime the power comes back on, their is a serge of power and things get blown up.
in the future, when you know you have a power outage.. turn off your main breakers,, then after the power comes on, then turn your power, you will not get the serge.
now go to you oven breaker and reset both switches, and see if your door lock corrects.
If you still cant get the microwave working, i have to give you this warning, and only say you have a defective control board.
Microwaves must be serviced by technicians due to the inherent dangers involved in repairing these appliances. Internal capacitors can retain a lethal electrical charge even though the unit is completely unplugged. A microwave radiation leakage test must be performed on the unit following any internal component repair.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 04, 2011 | KitchenAid Microwave Ovens
How do you reset the microwave power? Is there an external circuit breaker if the main house circuit breaker did not switch off?
There is an internal cartridge fuse, as well as thermal fuses. It is not recommended that you attempt any internal repairs on a microwave due to the presence of very high voltages and the danger of microwave radiation if not reassembled correctly. Residential microwaves, if not under warrranty, are generally considered disposable. Parts and service are very expensive.
Feb 25, 2010 | GE Advantium 120 Convection/Microwave Oven
Samsung smh7175wc - dead??
id say there is a bad connection somewhere and is arcing due to that which is causing it to trip breakers. so when you banged it and it started it made a connection and then stopped when you turned it on. open up the back abd just pull the wires anywhere connections are made and see if any are lose.
Jan 13, 2010 | Samsung SMH7174BC Microwave Oven
Loss of power to Whirlpool over the stove AccuWave GH5184XPS-4. Checked circuit breaker and GFI -all OK. No other electrical problems known.
Remove unit and check trip/reset switch on unit. Double check GFCI receptacle with plug tester with GFCI test button.
Jan 12, 2010 | Whirlpool GH5184XPQ Microwave Oven
Has no power
If your microwave oven doesn't seem to work at all, check these: Fuses Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it. Door switch If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work.
thanks
Mar 18, 2009 | Panasonic NN-SN657SMicrowave Oven
Samsung SMH1816S Microwave Oven Logo
66 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Henry  Thomas
Henry Thomas
Devabhakthuni...
Devabhakthuni...
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
