Question about Hugo Boss Watches
Removing back cover - Hugo Boss Watches
Where i can replace the battery of my Casio watch,.Casio hunting timer AMW 705
The battery of my Casio 1846 W-71 was dead, so I tried to replace the battery by myself.
First, you need to get a hand on a CR2016 3-volts battery. It could cost you 5$ or 10$, but I got 5 of them for 1.50$ at an electronics discount store...
Get a precision screwdriver, remove the 4 screws. Be careful when you remove the cover, there's a tiny spring. Remember where it is, then remove it. Remove the watch from the shell.
Using a flat mini screwdriver, remove the cover that holds the battery. You'll need to unclip all 4 corners. There are centers to unclip too, not sure if there was 2 or 4 of them.
Remove the battery, place the new one. Clip the battery cover back, and put the watch back in the shell.
I closed the cover. The watch was showing time, buttons were working, but no sound at all. Looked on the Internet, and read that you need to short circuit it.
Look carefully, there is a label "AC" near a small hole. (Inside the hole you'll see the gray spike of a welding). Just touch something metal inside the hole (e.g. the welding spike) and then touch the positive (top) side of the battery. Put the cover back in place, press a button and listen for the beep.
Screw the cover back in place.
Aug 23, 2013 | Watches
How do I remove the back of this watch?
I have seen other burberry watches and the back should pop out .
1- Locate a very small tab or recessed area on the edge of the back cover 2- Pull out the stem, which releases the back on some watches.3- Get a small flathead screwdriver it needs to be a thin inflexible tip 3- Very carefully slide the blade under the tiny metal protrusion on the back cover (or across the length of the recessed area, depending on which type of cover your watch has). 4- When you replace the cover, make sure you line up the stem slot on the cover with the stem of the watch. This information is on wiki: http://www.wikihow.com/Pry-off-a-Watch-Backing-Without-Proper-Tools
Feb 19, 2013 | Burberry Authentic BU1321 Womans Swiss...
Remove back cover
If the watch back has about 10 groves on it take it to a watch repairer.NO groves then a sharp knife like a small Pearing knife find the grove between watch and cover put knife in and gently prize open.
Aug 16, 2012 | Timex Expedition Watches
How do you change battery for casio 1174 CMD-40?
I like these little RC IR watches. They're great fun!!! For this tutorial, you will need....
  • A small Phillips heads screw driver
  • A pin (or needle)
  • A replacement CR2032 battery
Instructions :
  1. Remove the 4 screws from the back of the watch
  2. Carefully remove the back plate, do not damage the delicate rubber seal
  3. Carefully remove the delicate rubber seal
  4. Use the pin to remove the small rubber block from the battery cover clasp.
  5. The pin should then be inserted in the gap of the white plastic lug, where the rubber block was removed.
  6. Use the pin to gently pull back the clasp of the battery cover.
  7. The battery cover will then open with a 5mm gap approx. It does not need to be removed.
  8. Use the screwdriver to remove the battery.
  9. After the battery has been replaced, just follow the instructions backwards.
I hope this little tutorial has helped.
Feb 10, 2011 | Casio Watches
How can i check the serial number on verify there authenticy?
mcdevito75 here, The serial number is the number off the movement itself. You"ll have to remove the back cover of the watch or have a watch repair shop remove the back cover and record this and all info on the watches movement. Any info on the back cover of any watch can help somewhat but you need the info off the movement itself for accurate info regarding any watch.
Oct 23, 2010 | Watches
I have a columbia watch cl 7204. does the back pry off or rotate?
mcdevito75 here, Basically there are 3 ways to remove the watch back, If there are 4 screws holding the back onto the caseing you"ll need jewelers screwdrivers to reove the screws and cover, if there are square holes going around the edge of the back cover you"ll need a special tool called a case back remover tool available on ebay to un-screw the back cover, or the cover simply prys off. Look for a tiny tab on the back cover you may need a magnifier glass available at most Dollar stores or there may be a **** between the back cover and case of the watch to pry off the back cover, use a sharp knife and carefully twist the knife oncwe you find this tab or ****.
Sep 21, 2010 | Columbia All Sport watch
I have a fossil arkitekt how do u take the back of
mcdevito75 here, Look very closely at the back cover for any groove that line up with the case and the back of the watch, if so place a sharp blade knife in that groove and gently twist cover off. Also look for a small tab comming off the back cover, if so the knife blade ios placed under it and gently twisted to remove back cover.If by chance you see square type holes around the edge of the back cover then it"s a screw on back and you"d need a special tool to un-screwit, see a small watch repair shop for this type of back cover.
Jul 05, 2010 | Fossil CH2331 Wrist Watch
Unscrew the back of a lorus watch
mcdevito75 here, Most Lorus watches use a press fit back cover on their watches, simply us e a knife with a sharp edge between the case and cover and with a slight twisting motion the cover should come off, Also Look for any slots in the cover that match a slot in the case, or a very slight extension or lip on the cover, this is where you"d place the knife and use a slight twisting motion to remove the cover. If there are screws on the back cover you"ll need to remove those screws to get the cover off. Your Local small watch repair shop can help out.
Jun 20, 2010 | Watches
I cant seem to get the back of the watch off. How do i change the battery in my Columbia watch.
Remove the back cover.
On some watches, the cover will pry off using a very small flat-bladed screwdriver or will have screws holding the cover on. On other brands the entire cover will unscrew. Examine the edge of the back cover. If there is one small depression along the edge of the cover then the cover will pry off. If there are screws present, the cover will lift off after the screws are removed. If the cover has a raised edge with flat edges opposite one another then the cover will unscrew.
Mar 25, 2010 | Columbia Elkhorn Light-Up Watch - Large
Get cover off the timex watch indiglo w30m watch
Try removing the rubber washer or the black band on the cover then try snapping it back on. I removed the washer and placed it on the back of the watch before I placed the cover on and it just snapped back on.
Sep 14, 2009 | Timex Watches
Watches Logo
Top Hugo Boss Watches Experts
Sloop Johnb
Neal Marrison
 steve
steve
Are you a Hugo Boss Watch Expert? Answer questions, earn points and help others
